How to use the remote controls properly for my Clio TV
I havea 46" sanyo model dp46841 lcd tv but the tv wont respond to the oem remote or universal remotes ?
Sounds like the infra-red sensor inside it is either damaged or it do not get proper voltage to work. Check it. If it get proper voltage/s and still not receive any infra-red signal from the remote control, replace it. The part in discussion will look somewhat like this.
25758228-54zq5khwu0nuxgxnhh2yrt4a-2-2.jpg Prior the replace this component, make sure that the remote control you're using works properly, and do emits infrared light rays, during each button presses on it. Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
Jun 23, 2015 | Sanyo Televison & Video
Westinghouse tv, remotes do not work on it
Each tv remote has a code must find the code that corresponds withe the Brand of tv and enter the code then ALL the buttons will function properly
Mar 06, 2014 | Westinghouse Televison & Video
Used universal remote still have sound on tv but lost picture
follow this instruction and fix it. God bless you
No picture
  1. Make sure all power cords are connected.
  2. Try pressing the enter/play key.
  3. Make sure the TV is turned on and the input is set properly.
  4. Make sure the TV source is set properly on the TV (This is probably done on the screen; Check your TV manual).
Aug 01, 2013 | Westinghouse 16093 Remote Control
RCA remote control code for Model L40FHD41yx9 Set purchased at Walmart in November, 09, Remote code was not available at that time.I cannot use my Direct TV remote properly without this code. I was told...
The code is not in your TV; it is in a compatible remote control. Your Direct TV remote control may not work. You can try using a universal remote control to find something that works.
Mar 03, 2018 | Televison & Video
Took radio from car would like to put it back but dont have the instruction manual to imput the code properly car make and model renault clio authentique
It all depends on the radio make+ model.
Most RENAULT have the PHILIPS radio with a remote steering wheel control.
Here are the Code Entry Instructions
Philips Renault Code Entry (For cars with a Steering Wheel Remote Control.)
Note: If your car does not have this remote control, then please ask again for alternative instructions )
Turn on the radio and the display will show 'CODE'
Use the Steering Wheel Remote Controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit
Press the [ ¬] button then rotate the thumb wheel for the correct second digit
Press the [ ¬] button then rotate the thumb wheel for the correct third digit
Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ¬] button for up to 10 seconds to store the code
May 17, 2010 | Car Audio & Video
I need code for URC-3220 Universal remote control for toshiba tv/vcr in one.
I can help you reprogram your URC-3220 Universal Remote for your Toshiba TV/VCR Combo.
The Toshiba TV/VCR Combo codes are 1145 & 0845.
Please review my Fixya Tip posts for:
TV/VCR/DVD Combo Codes
Searching for the proper codes, or
Downloading the URC-3220 users manual / owners guide.
I hope that helps.
Apr 07, 2010 | Universal Remote Control Remote Control
Where is the starter motor on an M reg renault clio?
its attached to the gear box facing into the flywheel
Apr 29, 2009 | RCA DIRECTV Satellite Remote Control
Remote Control #1 will no longer control TV
Remove batteries from remote and put in fresh batteries, this will reset the remote.
Feb 08, 2009 | DISH Network IR Remote Control
Renault clio 1.4 rt 1998 1 of 2 remote control still not working even after changing batteries. light on control enits but still nothing.
Have you tried do a relearn fo the key-less entry remotes, it should be in your manual, if you buy a new remote this is what you must do so the remote will work with the receiver in your car which has a unique signal to your car.
Sep 07, 2008 | Renault Le Car Cars & Trucks
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
