How to work the remote controls what is an SD1 and SD2
HDC-SD1 No Power
Battery could be discharging or worse, power transfer within can is broken
Jul 21, 2014 | Panasonic HDC-SD1 Camcorder
Panasonic HDC-SD1 camcorder will not turn on
Are the Batt's full? because this looks like you have not enough power to keep the camera on.
Jun 06, 2010 | Panasonic HDC-SD1 Camcorder
I have 360 modena how do i reprogramme the remote for the alarm
Remotes have to be programmed by a shop with SD2
Feb 20, 2010 | 2001 Ferrari 360
The volume knob is flashing red on my AX-SD1 amp..no sound.
Unplug the receiver, let it sit for a minute or two then plug it back in. It's either in "mute" or in Protection. Generally, Yamaha's will say "Ck. Spkrs" If it still has a problem, post a comment and I will look up some sources and help some more.
Aug 07, 2009 | Yamaha RX-V690 Receiver
IMovie capture is poor quality.
hello referring to the SD1 from Panasonic, i recommend to deinterlace the captured clips with "JES Deinterlacer" before editing them with imovie. be careful to use "apple intermediate code" at the output of JES Deinterlacer. i clearly get better results this way, max recommendable size at 1280x720p when exporting QT files... kind regards, bruno
May 26, 2008 | Panasonic HDC-SD1 Camcorder
Konica minolta 1216
1. A fan irregularity signal, excessive current draw due to binding. Examine M4 for obstructions which may bind the fan. Check the M4 fan lock signal (main CB, CN26-4) in the 47 mode, input code 42. The voltage should be between 0.1 to 0.2V DC. If 5V DC is present, either the fan is binding or the fan is defective. Replace M4 (p/n 25HA80512).
Note: If the fan lock signal is normal, install the version 17.0 EPROM (p/n 101517-17.0) to prevent false F54 errors as outlined in 1015/1212 Technical Bulletin #15.
2. IC7 on the main CB has shorted due to a failed total counter. IC7 shares the 24V DC control signal line with the exposure lamp, separation solenoid (SD1), registration solenoid (SD2), total counter, key counter, and cooling fan (M4). All loads except the total counter operate in diagnostics.
Replace the total counter (p/n 466088201) and the main CB (p/n 25HE-7312).
3. A poor connection between the cooling fan (M4) and the main CB. Reseat CN73 at M4 (cooling fan) and CN26 on the main CB.
Dec 19, 2007 | Office Equipment & Supplies
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
