Question about Konica Minolta Office Equipment & Supplies
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Posted on Feb 02, 2008
SOURCE: service manual for KONICA MINOLTA Bizhub 210/162
Swithc off the machine Press stop button and hold switch on the machine. problem will go.
Good Luck
Posted on Jan 07, 2009
SOURCE: what does code 2454 mean on the konica minolta
Developing motor for the Black, working in conjunction with Toner Control Sensor.
Posted on Jul 31, 2009
SOURCE: kONICA MINOLTA BIZHUB 750 SHOWING C3803 ERROR
You have a problem with the fusing unit. This is the assembly that gets hot and "fuses" the toner onto your paper. This error code means that the fusing unit did not warm up properly. You will need to have a service company come out to diagnose and repair the problem then reset this code as service mode entry is required in order to reset. It could be as simple as cleaning the thermistor, replacing the thermistor, thermal fuse etc. I would estimate the cost at around $200.00.
Here is the section from the service manual that deals with this code:
Thermistor /1 (TH1) detects a low
temperature when a specified
period of time elapses after the
fusing heater lamp is turned ON
for the fusing ON control.
Posted on Jun 09, 2010
Apr 17, 2017 | Konica Minolta Office Equipment & Supplies
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
Aug 22, 2016 | Konica Minolta bizhub Office Equipment &...
Jan 22, 2016 | Konica Minolta bizhub Office Equipment &...
Jan 26, 2015 | Konica Minolta bizhub Office Equipment &...
Jan 11, 2015 | Konica Minolta Office Equipment & Supplies
May 28, 2014 | Konica Minolta bizhub Office Equipment &...
Dec 12, 2013 | Konica Minolta Bizhub C360
Jan 14, 2010 | Konica Minolta Bizhub-200 Minolta Printer
Nov 12, 2009 | Konica Minolta bizhub C250 All-In-One...
301 people viewed this question
