Question about Hisense Televison & Video
Hi my Hisense EN-31611A won't connect to the tv. Has worked previously and the remotes red light lights up
IrishDruid
  • 2712 Answers
SOURCE: hisense remote does not work with hisense tv
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
SD Tech
  • 14553 Answers
SOURCE: my hisense LCD 37V88N 37 inch is not turn on only red light is on
You really have two issues here.
First is the red light is set is in standby mode, its not making it to on--this could be a power supply problem which would at the least require opening the set and looking at the board for puffed up caps or damaged parts. I will attach a few photos of what bad filter caps look like. If bad caps are found (a look will tell if bad) that can be a easy repair.
Second issue is the brand: This company is in China and has gone out of business at least two times---parts and service information is almost non-existent----They make sets with no intention of them being fixed.
Posted on Dec 19, 2012
gopakumarg43
  • 75311 Answers
SOURCE: I want to watch you tube videos from my iPhone on
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchased a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ If you see these sites by "MOSAIC" or "Magazine" view will make surf easier. Or type in the brand name of your device in the search box, and press "Enter".
Universal remote controls are available at most of the electronic spare part selling shops.
Posted on Jun 29, 2014
Coldcut
  • 1554 Answers
SOURCE: I have no volume on my 47 inch hisense tv. can I use the remote to fixi it
check the input 1st , or change cables , use an rca cable to test sound. other than mute thats all the remote can do but there is one more
in the settings the tv can be set to internal speakers or ext or both
Posted on Jan 05, 2015
gopakumarg43
  • 75311 Answers
SOURCE: I have a Hisense remote (EN- 31624A) I've tried to use it on my Hisense TV but it does not work. Is there any code or steps to take to reprogram the remote to the tv?
If the remote control is the original one; you needn't to program it. It will be already pre-programmed to work with the TV. Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://www.youtube.com/watch?v=F8oYoZslgbs
Posted on Dec 19, 2015
How to get Hisense EN-31611A remote control code number
You have this backwards. Codes are stored in the remote control. We need to know what you are trying to control with what remote.
Jan 26, 2018 | Hisense Televison & Video
Having trouble finding out whether it's my remote or TV that is the problem? Need help!...I have a Hisense led lcd 32" model number HL32K160L. long story short, I turned the TV on at its main power button...
Hi sounds like the remote control unit as it is a transmitter not a receiver, have you tried rubbing your hand firmly over all the buttons on the remote just in case a button is stuck down.
Hope this helps
Oct 21, 2017 | Hisense Televison & Video
Remote will not let me turn the tv off sound & changing channels no problem new batteries in remote the model on the remote is EN-31611A
Dec 11, 2015 | Hisense Televison & Video
I have a Hisense TV with original remote working fine until recently. The remote lights up and is obviously on, however it is not controlling the tv at all anymore, no idea why. Any ideas on how to fi
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. Ome among its posts have details about it. Surf the site in "Mosaic" view. It will make surf easier.
Mar 20, 2014 | Televison & Video
Hi my hisense tv won't turn on. The power is connected as the red light shows on the tv and and the blue lights light up on the side panel when I press the buttons- but the picture does not come on. It...
tv's without on switches has the same problem consider the signal to your tv from the remote and please keep the life span of your tv by switching it off completely.
Jul 14, 2017 | Televison & Video
I need the code to program a rca systemlink3 remote for a hisense tv
0748...but if its like mine it wont work. these HiSense remotes are JUNK!!!
Aug 17, 2009 | Televison & Video
Need remote control code for hisense EN-21660A
Does anyone know where I can get a remote for a Hisense 22" TV? I've bought a universal remote but after reading other people's experiences with the Hisense remote, I'm reluctant to even try it.
Dec 23, 2008 | Hisense LHD3206US Television
Televison & Video Logo
32 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
