My Elna 6000: the needle does not want to move forward or backwards
The needle never moves forward/back on its own for most sewing machines. The needle bar goes up and down. The fabric moves due to the action of the feed dogs. First remove the fabric from under the presser foot. Check for tangled thread wrapped around the feed dogs or fabric/thread going down into the bobbin area in a tangle. Next check if the feed dogs are up. (When the feed dogs are down or covered (on some machines), the machine is in darning mode. The fabric will only move if you move it yourself.) With the fabric out of the way, rotate the hand wheel and check if the feed dogs are moving. Open up the bobbin compartment and clean out any lint, thread or other debris that may be tangling the mechanism. Take off the throat plate and check the feed dogs. A damaged throat plate can stop the feed dogs from moving properly. You may need to replace the throat plate.
For some machines, you may need to make sure that the unit is not in bobbin wind mode. This is usually obvious since the needle bar won't move either.
I hope this helps.
