Question about Sewing Machines
When i start stitching an error message shows on the width screen
  • Sewing Machines Master
  • 10,766 Answers
And what is the error?
You can search for:
Make Model error (code)
or consult the Troubleshooting section of your manual
Posted on Apr 17, 2017
How do I get rid of the stitch width safety message on a Viking husqavarna designer 2
try this link might help you out just scroll down the page and you might find something that might help you... How do get rid of the stitch width safety message on Viking husqvarna...
Oct 26, 2017 | Sewing Machines
Control Panel shows the following error message: ][ How can I re-set it?
] [ = usually means that your bobbin winder is on. Move the bobbin winder post/shaft from the right position over to the left to switch the mode back to sewing, then try making your stitch selection again.
Jan 12, 2016 | Singer 7256 Fashion Mate Sewing Machine
How i can adjust the stitch ?
A zigzag can be adjusted by the width and length of the stitch. If you start with a straight stitch it is easy to see what the length of the stitch will be. The width is adjustable. By adjusting the two together you can have a large choice of quality stitches.
Feb 07, 2015 | Sewing Machines
I have a Singer 7285Q sewing machine that comes up with a "E-7" message and the machine won't work. It only happens when I use "back stitch" button. My instruction manual has no mention of an
E7 means
The start/stop button, reverse/reinforcement stitch button
or the thread cutter button was pressed while no thread
cassette was installed. If the start/stop button is pressed before the sewing machine is correctly set up or if an operation is performed
incorrectly, an error message appears in the stitch indicator. Follow the instructions that appear.
If you press (Stitch selection key) or do the operation correctly while the error message is displayed, the
message disappears
Oct 30, 2014 | Singer Sewing Machines
How do I increase the width of a stitch?
there is a dial showing the width of a stitch . Just turn the dial until the width is set according to your needs .
Aug 16, 2014 | Sewing Machines
Stitch width knob
What's the model? Do you have the stitch selector set on straight stitch, or on a stitch with a width component, like a blind hem stitch?
Some machines consider straight stitch to be a zigzag stitch of width=0, while others have separate settings for a straight stitch and a zigzag (or other) stitch.
Feb 11, 2014 | Elna Sewing Machines
Setting stitch length
Get some scrap fabric. One dial is for the width of the zig zag stitch, the other dial is for the length of any stitch. First set both to ZERO. It won't move then set one to half way. This will show you which dial is which. If it is the width dial. You'll get a bar tack. If it is the length dial you'll get straight stitches.
Aug 01, 2012 | Sewing Machines
Cannot get rid of stitch width safety get double beep
In my case the problem was an error in the User Guide.
Press SET four times so that it displays SET 4. At the bottom right of the screen, where the User Guide shows a blank area, there is a setting for the maximum stitch width. If this is set to 0.0 you can only stitch straight. Change it to the other setting, typically 6.0.
Now go to ADJUST. At the bottom of the screen, the middle control is the actual stitch width, which you can set anywhere from 0.0 to the maximum. Set it to whatever width you want for the zigzag.
Oct 07, 2010 | Husqvarna Designer I
Sewing Machines Logo
23 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
