Question about Kenmore Washing Machines
How to fix my kenmore dryer that doesn't heat up model 97812 this is a stackable dryer on top
docjohn174
  • 943 Answers
SOURCE: Need to replace the heating element in stackable Kenmore model 417.98702891
hi thanks for the question just underneath the dryer on the front theres a panel remove this panel the element is on the right thanks for the question the appliance doc
Posted on Sep 15, 2008
TheMobilian
  • 8220 Answers
SOURCE: Squeaking Kenmore Stackable Dryer
Your rear drum bearing has worn through the plastic and is now hitting the metal support underneath it,
soon it will act like a guillotine and slice of the ball, the drum will fall backwards into the heating element and short to ground causing the fuse to blow the heater element to burn intwo and the whole thang will be dead in the water.
Posted on Mar 07, 2009
  • 1122 Answers
SOURCE: No heat in a Kenmore stackable washer dryer
there should be a small fuse on the heater box,if that is not working the element will not work also-mike
Posted on Apr 16, 2009
SOURCE: Kenmore stackable
washer issue is lid switch. need new one. dryer sounds like either the main breaker to unit (only 110v passing thru to dryer instead of 220...then spin with no heat will occur), the heating element is bad or a thermal switch got hot and failed (cheap to replace). There is not much to a dryer, and that covers all the possibilities.
Posted on Sep 06, 2009
SOURCE: Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Posted on Nov 15, 2009
How do I replace the fuse in the dryer for stackable Kenmore model 417.98702891
This is an excellent source. Click on the link
http://www.repairclinic.com/Shop-For-Parts/a17b6d632276-x6d6f64656c/Model-Model-41798702891-Kenmore-Washer-Dryer-Combo-Parts
Jan 18, 2015 | Kenmore Washing Machines
I have a Kenmore Stackable washer & dryer Model # 417.93702200 and my dryer will come on and spin but it doesn't get any heat to dry my clothes. what could be the problem? Where can I get the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 19, 2011 | Dryers
How do i replace the heating element on my kenmore stackable washer dryer 98702 machine
Could you please post the model number of the unit? It will be under the washer lid, in the dryer door, on the top, or the side of your unit.
Dec 25, 2010 | Kenmore Washing Machines
Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
hi..
When your dryer drum isn’t turning anymore, it’s usually a broken belt. Tearing the dryer apart is usually straight-forward enough but stringing the new belt on the motor and idler pulley can be tricky. The Complete Encyclopedia of Dryer Belt Configurations shows the belt configurations for almost every dryer brand you can think of.
this will fix ur problem..
thank u rate me
May 25, 2009 | Kenmore 93702 Top Load Stacked Washer /...
Apr 16, 2009 | Kenmore 88752 Top Load Stacked Washer /...
Mar 12, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stackable
Dryer probably element or thermostat, washer sounds like a suspension arm collapsed. Price up the parts & then decide if its worth it! Regards
Apr 09, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
29 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
