Question about Krups Coffee Makers & Espresso Machines
Krups XP9000 The main fuse blows when using frothling nozzle. Sometimes even just when turning on the machine.
I have tried to change the cord when I thought that was broken. No luck. I have cleaned the nozzle manually with a cuetip as far up as it goes. If I'm lucky, the machine will work for a couple of coffees but suddenly when using nozzle, the main fuse blow. Please advice how to fix it. Thanks
    Top Expert:
  • Krups Master
  • 49,191 Answers
Blowing a main fuse is an indication of a short or insulation failure
have an accredited electrician test the unit to find the fault
Posted on Apr 17, 2017
Testimonial: "Thank you, I guess that's whats left to do. I might have a check inside the machine to see if I can find where the problem is. At least to be able to take photos of what I find. I do love my Krups and want to keep it. Don't want to have to buy a new one. Thanks!"
  • Anonymous Apr 17, 2017
    I opened the machine again and can see nothing unusual. All cables that I see looks good and connections where I guess they should be. Took a lot of photos for later.
  • Anonymous Apr 18, 2017
    Edit. Today I ran the machine wide open and at the rinse water process I saw a connection leaking, dripping water into the machine.
    I guess I found what is causing the short circuit. I will let it dry completely and try again. I fixed the leak and hopefully it will work after some drying.
    It was a good idea to open the machine up to see what happens inside when problem occured.
    I filmed what happend efter fixing the leak and lots of smoke came up and main fuse blew.
    At first I was not prepared, I was focusing on the connection that leaked before. It had stopped after me taking the parts apart and together again.
    Guess it was the old leakage that caused the short circuit.
It always shows fill up beans but the beans container is full.. how to fix this problem for a Krups Xp9000
somewhere I read that there is a window /sensor that needs cleaned really good so it sees the beans
Jul 19, 2015 | Krups Coffee Makers & Espresso Machines
Hello, I have Krups XP-7220. When I try to make a coffee, machine start to ask me for refilling. And this process is endless.
Check the water float in the tank, it is common for them to cease floating sometimes. Krups solution is a new tank, my solution is to jam something plastic underneath it to lift it up so that it activates the sensor. Even if tank is empty it will no longer ask you to fill it up.
Feb 04, 2015 | Krups XP Coffee Makers & Espresso Machines
Krupps XP9000 won't accept date so therefore won't switch on
Are you attempting to put the date in in the wrong format. USA = month and then day, normal folks day and then month. Check language setting.
Mar 28, 2013 | Krups XP Coffee Makers & Espresso Machines
When machine is turned on from the off position it does not go into rinse mode message comes up to hot please wait and yet the machine has been turned off for at least 20hrs
the power on sequence for the XP9000 is
1) Internal diagnostic
2) if no cold water, display notice and wait for water level in cold water tank
2) if water heating block is not hot, display notice and wait for block temperature
3) display "Rinse Press Hot Water" notice and wait for button press
4) rinse
5) display "Select Beverage" and wait for button press, ground coffee flap, or other input switch state change.etc...
in short... its doing what its supposed to.
Please consider reading the manual supplied wih your XP9000 or downloading the manual if you don't have it.
Nov 10, 2011 | Krups Super Automatic XP 9000 Espresso...
Krups xp9000 will not brew, but grinds beans.
I also have the same problem with my xp9000. The beans are grinding but no coffee is expressed.... Any advice????
May 14, 2010 | Krups Super Automatic XP 9000 Espresso...
Krups XP 9000 - Check Collecting Tanks
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={EBDB947E-33FB-42E0-B662-0E13E8D1D4FB}&SelectedProdRef=XP9000
here is a link to the manual. u need adobe to open it
Feb 26, 2009 | Krups Super Automatic XP 9000 Espresso...
My krups 9000 keeps on setting off the saftey switch at the main powerboard off my home
you mean house breaker i guest you tried the machine somewhere else and if still blowing breaker check the power cord open it maybe with vibration power wire are toughing themself inside machine cheers
Jan 26, 2008 | DeLonghi EC140 Espresso Machine
Coffee Makers & Espresso Machines Logo
61 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
