How do you get other things and clothes unlocked
How do I unlock my nook when the screen wont respond to touch when you swipe to unlock
Turn off and wipe screen with a damp (not wet) cloth and then wipe with dry cloth!
Dec 28, 2014 | Barnes & Noble Nook Tablet
Whirlpool duet sport front load washing machine
F-01 is a communications error between the CCU and EEPROM. The first thing to try is unplugging the machine for 5 or 10 minutes. If that doesn't fix it, you'll need a new CCU (probably need to replace that anyway). Though if you just got it 2 days ago, call the store you bought it from - they should replace it (and help you get it open to get your clothes out).
Sep 07, 2007 | Washing Machines
Zanussi Washer Dryer wont wash!
Sounds like the switch that tells the controller that the door is closed and locked is actually bad or the plastic molded part holding the switch is broken. Inspect the interface for cracks.
Nov 22, 2014 | Zanussi Washing Machines
Unlock iPhone 3GS permanently via IMEI using unlock code
there are many software available to unlock iphone and i unlocked it by remote unlocking..there are many online providers who provide the of my friend got unlocked his iphone from Mobileunlocksolutions by remote unlock..and the important thing remote unlocking is available for some country and network providers only so if you are interested you can try from them before that see whether remote unlocking is available for your country and provider.
Dec 24, 2011 | Eforcity Apple iPhone 3GS 16GB / 32GB...
Door wont unlock once a wash cycle has begun
that is correct ,. pump water out then the door will open.
May 20, 2011 | Kenmore Elite 45986 Front Load Washer
Washer will not spin clothes dry...full of water and wont work. f-21 keeps flashing.
your drain pump is clogged,So the first thing you need to do is,Push the start button again you well hear the machine come on you well hear the pump its trying to drain after about 30 seconds,It well shut off,so push button again watch the machine when the water goes down a certain level.The clothes well start to spin. Now after they get done spinning,push the cancel should be able to hear the door unlock,remove the clothes.Now put Draino Max gel or Rooto-Routor gel in tub of machine and let it set for about 1-2hrs.Now star cycle on heavy-duty wash hot water,it may take a couple of times but it well clean your machine don't mix any othe soaps or bleach during this time. then rinse machine out again to get rid of gel.see if this work for you,are machine does the same thing,its because of dog or cat hair,or something was in a pocket like tissue,or strings from clothes.thanks
Jul 29, 2010 | Kenmore HE2 Plus Front Load Washer
Amana front load washer door wont unlock
Nd is drain error.
Check inside the control assembly, you may have a technical diagram with instructions pocked in there.
You will need to check the drain pump hose for blockage.
If that is not enough to fix the problem, then the fault may be the pressure switch, the pump, or the control assembly.
In that case the best thing to do is calling the support number listed in the owners manual to contact Amana.
Dec 13, 2009 | Amana Washing Machines
I wanted to take some clothes out during the cycle but don't know how to stop it properly and get the door unlocked
your mach depending on model and cycle selected has a 3 to 5min "add a garment" feature.that means in the 1st 3-5mins of cycles when add a garment light is lit you may hit pause button once and the mach will stop and unlock door.after add a gament light is off,if u hit pause the cycle the mach will drain water and reset cycle..hope this helps
Mar 29, 2009 | Kenmore 42822 Front Load Washer
Maytag MAH8700 - NP error code - Door locked and won't open
I don't know if you are aware of this, but Maytag did a recall on this washer in March 2007 where there was a risk of water leaking into the control panel and shorting out the board. You can follow this link to see if your washer was affected based on the serial number:
Here is a link to your user manual to see if it offers any help. The only thing I saw was to use the Cycle Selector button to unlock the door.
I found this on the Maytag site:
Is the door locked and the Add A Garment or Add Clothes light off?
If the Add A Garment or Add Clothes light is off, then the washer door will unlock after the Pause/Off or Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
You could also try their customer service number to see if they have a script for this problem: 1-800-688-9900
The only other solution I can offer is to disassemble your washer if its that urgent and you can't get a repairman out there.
Jan 10, 2009 | Maytag MAH8700AWM Neptune Front Load...
Whirlpool Duet won't run
The trouble could be with the door interlock. When the clothes were jammed in the door it could have caused the door latch to put strain on the interlock.
Oct 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
