Question about Red Video Game Consoles & Games
Red light flashing and beeping on portable oxygen concentrator
  • 619 Answers
Hi, the aircondationer compressor was stuck , the thermal control open the red light on , you may call fixya authorized repair service near you you just enter zip code .
Posted on Jan 30, 2008
  • 558 Answers
SOURCE: Red light flashed and beeps continually when I
have you tried it on another pc.If it fails the drive might be bad.
Posted on Sep 11, 2009
  • 1272 Answers
SOURCE: I have mislaid the manual for my'Freestyle
You may download the required manual from the below link:
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on Feb 22, 2010
  • 2382 Answers
SOURCE: my mc4490 oxygen concentrator keeps
Hi, you have to troubleshoot the Oxygen Concentrator by following the instruction on page 8 of the user manual on this LINK..............
Posted on Jan 16, 2011
  • 456 Answers
most sequal units that i can see draw between 10 and 15 amps depending on the setting used.
if you can tell me the model of the unit and the normal setting used, i should be able to give you a better idea of the current needed.
you may want to check with a lincoln dealership about the rated output of the cigarette lighter as most cars i know of are only rated for 10 amps through a cigarette lighter so you may be on the limit for this.
some accessory outlets are rated higher though and this should be confirmed with the dealer who should be able to find the official ratings for you car.
Posted on Feb 25, 2011
What is Pulse Flow and how is it different from Continuous Flow ?
Pulse and continuous flow (or pulse dose and continuous flow dose) refer to how the oxygen is delivered to the patient. A pulse flow machine delivers oxygen only when the patient inhales and is triggered by inhaling. A continuous flow machine delivers a continuous flow of oxygen. Most continuous flow machines will deliver BOTH pulse and continuous flow. Here is oxygen tank process
Portable Oxygen Concentrators How They Work How To Choose Them
Dec 19, 2016 | Cars & Trucks
I need a battery replacement for this this unit (MO-H04CD EGET portable oxygen concentrator) but cant find it anywhere. Can anyone please help me?
having no idea as to the make,model you tie our fingers .some hide them under the back seat , buick in particular
Apr 20, 2016 | Oxygen Portable Oxygen System
Check fluids and filters, make sure there is no restriction on tubing, air intake. some times take out the filters etc. then reinstalling them will help. Also unplug for a while then plug it back in and see where that takes you.
Apr 22, 2014 | AirSep FreeStyle Portable Oxygen...
I recently puchased an EGET MO-H04CD portable oxygen concentrator and I am having problems charging the Lithium batteries that were supplied with the unit. There are no instructions on how long you have to...
Red light normally means that the battery needs charging. The green flashing light can mean the battery is charging or has charged, and the same with the solid green light. Green in this case is good.
Charge the unit overnight and see what the indicator state is. It should not take more than 8 hours of charging for a Li-ion battery. Once you know what the full state light looks at, then you can tell what the charging indicator looks like.
In all cases, ensure you are using the proper charger with the unit.
May 14, 2011 | Health & Beauty
P-B Companion 590 Oxygen Concentrator is beeping. What should we check and fix to repair the unit? Can you provide a link to the manual or troubleshooting guide for this unit? Thank you for your...
When these units are beeping it indicates they are basically not running. So you first need to ensure who ever is using it has access to o2 if they require. There isn't much you can do to fix these at home. You can first try going over the following. Not really that helpful but might help you sort it out. If you can't spot anything obvious ie unplugged no power etc then first contact anyone local such as the medical supply place. That would get you the fastest repair or help. If you don't have one of those to call then don't be afraid to call the 1-800 number below and ask the company.
The local company or even your doctor might be able to help you get bottled O2 while your unit is getting fixed.
If there is an audible alarm -- concentrator is not running: • Is unit plugged into a working outlet? • Check circuit breaker -- Right side of unit, behind a small door on the Companion 590 and 429a -- Back of the unit on the Companion 492 -- Between the on/off switch and flow meter
If there is an audible alarm -- concentrator is running: • Concentrator cannot be fixed by consumer • Call 314.362.0720 or toll-free 800.456.9366
There is a visual alarm on the Companion 590 with oxygen concentration indicator: • Green Light -- Normal -- Oxygen concentrations are correct • Yellow Light -- Below Normal -- Oxygen concentrations have fallen below an acceptable level • Red Light -- Not Operating -- Oxygen is no longer being produced; audible alarm will sound and concentrator will shut down
Apr 04, 2011 | Health & Beauty
Hi I'm using the devilbiss 5 lts Oxygen concentrator from past 4.5 years. Recently from past 2 months it is giving some problem, during night while using machine within 2 hrs it is showing low oxygen (with...
please check if the model of Concentrator is 515HKS or aks if u have any idea to open the screw it can be very easily opened ,check if the fan which will be under compressor is running ,or any leakage from the tube point which starts from the copressor or there will be muffler connection to the compressor which will be ball shaped,
if u have any doubt after checking with this please mail me to
Jan 03, 2011 | DeVilbiss 5 Liter Oxygen Concentrator with...
Amana AC
Jan 30, 2008 | Amana AP099R Air Conditioner
Video Game Consoles & Games Logo
Top Red Video Game Consoles & Games Experts
ray gallant
Are you a Red Video Game Console and Game Expert? Answer questions, earn points and help others
