Question about Garden
Does castration stop burns on the grass - Garden
  • 100 Answers
I assume you are talking about a dog and not your partner.
The answer is no...
Posted on Apr 17, 2017
My zero turn mower will run a while and then stop. i will then crank it and it will run for a bit and then stop
try a new spark plug. be sure the fuel lines are away from the engine as much as possible. sounds like when it gets hot the fuel is getting to hot to burn or the plugs or coil may be breaking down at high temperatures. be sure the air vent on the engine are clean and not full of grass and dirt.
Mar 24, 2017 | BIT Garden
How canI castrate myself
not the best plan
talk to medical practitioner and the right specialists
there other options available
No Scalpel Vasectomy
Surgical castration is bilateral orchiectomy (excision of both testes),
chemical castration uses pharmaceutical drugs to inactivate the testes.
gender orientation fix
gender change is a better solution
Nov 01, 2016 | Miscellaneous
On my trroy-bilt lawn tractor pony i was in high grass it seem to stop cutting smoke came from the deck stop cutting the handle that engage the blade become reaaly easy to move nothing happened
It sounds like you got into a job that was too big for the machine, and you may have either burned up the drive belt, or toasted the transmission or clutch.
Someone knowledgeable about such things should be able to raise it up in the air and look underneath and discover which problem you have.
God bless your efforts.
Jul 08, 2016 | Garden
PTO stopped working. What can cause this to happen?
bad safty switch or bad switch or pto burned out pto cost 200.00 switch engagement 15.00 or bad safty switch 15.00 pto dont go out that often not unless your mowing heavy grass
Aug 29, 2014 | Garden
Blades won't stay engaged in any length of grass
Sounds like a broken shear pin in the drive pulley. Check the belts and see if they are slipping. Broken shear pin will not let the blades spin under pressure. .
Aug 09, 2017 | Toro Garden
I tried to mow the grass even though it rained this am. our grass was really high and i saw a little smoke come out of the lawnmower. is that because the grass was still a little wet or the grass was...
Nope. If the grass is too high, knock it down to size with a weedeater first. These electric mowers cannot handle the tall, high stuff. If you do, you will surely burn it up.
Aug 14, 2011 | Black & Decker 18", 6.5a Electric Mower
Lots of smoke when I engaged stuck blades - now runs roughly
Most likely what you did was burn one or more spots on the belt. When the blades and belt stop turning, like in tall grass, the engine doesn't stop and will burn flat spots on the belt at the engine pulley. Every time the flat spot hits a pulley, it will jump and can set up a bad vibration. Run your hand around the sides of the belt or take it off and you will feel or see the thin spot(s) on it. Replace belt.
Jun 09, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
