Question about Quantum Health & Beauty
Quantum edge 6 wheelchair. Joystick is showing a fault indicator and attendant control.
We checked connections and unplug joystick and replug. Still same. Is there a breaker switch? Charging ok
UKXLNC
  • 11 Answers
SOURCE: Saitek X52 Joystick
Try deleting the drivers for the joystick, visit Saitek website get latest drivers and re-install the joystick, might fix the problem.
Posted on Nov 25, 2008
  • 103 Answers
SOURCE: My Jazzy wheelchair will not charge or run
First have the batteries tested to be sure that they are good. Just because they are "new" doesn't mean they are good. Then with the batteries disconnected plug the charger in and turn the chair on. This will tell you if the charger is good.
If both of these are good then you have an electrical problem. You need to call a local tech.
Posted on Mar 09, 2009
dalek963
  • 5 Answers
SOURCE: joystick will not work with Combat Flight Simulator WWII Europe
Some joysticks are not compatible with certan games for expmple when i am using flight simulator and change to my combat flight simulator i have to change joysticks
the only other thing i would think is try deleting the currently installed driver for the joystick and then download a driver for a joystick that is surported, it wont work as well but at least it might accully work
Posted on Mar 22, 2009
dromtonpa
  • 40 Answers
SOURCE: lights just flash on controller and wont move jet 3 wheel chair
Do they flash in series? Like ten flashes then a pause then ten flashes?
Posted on Mar 30, 2009
dromtonpa
  • 40 Answers
SOURCE: problem with joystick on Jazzy 1103 ultra
You will need to take it in for repair. 8 bar flash usually means you have a bad joystick/controller. They can sometimes send it in to the manufacturer to have it repaired. Find a reputable dealer and relay this info to them.
Posted on Apr 01, 2009
Can any one tell my the solution of error code #35 ,#37 and #36 of quantum pride 610?
This indicates a joystick problem. Check the wiring connection and the joystick neutral. There may be a mechanical or electrical problem with the joystick. Test by swapping out the bad joystick with a good one. Hope this helps.
May 11, 2016 | Pride Health & Beauty
I have quantum pride 610 chair when l power on it show me an error . The errorcode#36 release joystick .please l want some help
i think you will have to ring your support team and carers asap
get someone to test the power control module under the seat or the joystick controller
the batteries must be charged to get the error message
this the quantum pride 610 user manuals
http://www.pridemobility.com.au/default/assets/pdf/Owners_Manuals/US_Q610_Aug13.pdf
Apr 30, 2016 | Pride Health & Beauty
Push power button wont go but all the adjustments legs back tilt works
quantum 600 wheelchair troubleshooting Questions ... - Fixya
www.fixya.com > Forum > Tags
quantum 600 wheelchair troubleshooting chair won't go all i get form joystick is a picture of a ... around in a square there should be a rest button on the rear of the chair ,push ... Question about 600 E Electric Wheelchair - Used Power Chair.
[PDF]Pride Quantum 600 Owners's Manual - Scootaround
www.scootaround.com/.../Pride%20Quantum%20600%20Owner's%20M...
Quantum 600 .... The symbols below are used on the power chair to identify warnings, mandatory actions ... Pride will not be held responsible for injuries and/or property ...complete stop by releasing the joystick, then push the joystick forward slightly to .....breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600E Owners Manual - Scootaround
www.scootaround.com/.../Pride%20Quantum%20600E%20Owner's%20...
Quantum 600E .... The symbols below are used on the power chair to identify warnings, mandatory ... chair. Pride will not be held responsible for injuries and/or property ... complete stop by releasing the joystick, then push the joystick forward slightly to ..... breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600 Series - Pride Mobility Products
Dec 30, 2015 | Quantum 600 E Electric Wheelchair - Used...
Permobil C 300 joystick showing joystick error and code 0E00 how to correct?
0E00 Joystick Error Joystick Error Right System fault Joystick Error
that is the info from permobil documents, it may be an error of the right motor / wiring "check all connections, unplug and plug in again all connectors, if still persists then it would seem to be an error with the controller its self, this maybe the pcb or the joystick its self, some times if you give the joystick a good workout (moving it to its limits over and over again for a couple of mins and then turn on and see if error clears) if that fails then it looks like a new joystick or the whole controller might need replacing, if you know some one with the same controller on there chair see if they will let you plug it in to your chair just to confirm it is that.
hope that helps, and if so please click "Helpful" to let others know
have a great xmas all
Dec 01, 2014 | Health & Beauty
Lock key keeps blinkinglights blink 9 times
Depending on the controller type being used you either have a controller solenoid brake fault (sticker on bottom of joystick will say "PG Drives" and have 9-bars flashing) or a communication error between the controller and joystick (Dynamic Controller flashing wrench).
Repair for PG Drive is to replace joystick/controller.
Repair for Dynamic is to clean, remove and reseat or replace joystick cable.
Nov 12, 2013 | Pride Jazzy Select 6 Indoor Power...
Our church has 2 Jazzy's one is blinking the code all lights flash 7 times the other 9 times all lights flash can not find what I need to do in our book. Can you help is there a web site I can get a...
mtp see the below list
The listed Flash codes are pretty standard and are applicable to powerchairs only not scooters:
1 flash User Fault (do not touch joystick) and turn back on
2 flashes Battery Fault Recharge batteries or replace
3 Left motor fault check connections or replace
4 Right motor fault check connections or replace
5 Left park brake fault check freewheel lever or brake connections
6 Right park brake fault check freewheel lever or brake connections
7 Remote fault check connections and wiring replace remote(joystick) (Check cable to the joystick unplug connector at rear of chair and plug back in then try turning on to see if you are getting same code)
8 Controller fault Check connections and wiring replace controller
9 Communication fault check cable replace (almost same problem as 7) try same fix if doesn't work joystick will have to be replaced
10 and 11 are unusual and will not be seen if at all Hope this helps you
Apr 04, 2011 | Pride Mobility Products Health & Beauty
I have invacare pronto m51 with surestep the spjis flashing 9 times what is the problem
The 9 flash error code indicates a communications fault. The communication fault relates to the communication between the joystick and the control module. The joystick on the arm mount is connected to the control module in the base. When there is a break in the wiring of this wiring harness, also called a bus cable, a fault occurs. This trips the computer and the computer sends out a flash code to the joystick. Simply stated there is a broken or pinched wire between the joystick and controller. Look physically at the wire and check for cuts, breaks or pinches. The best short term repair is to repair the broken wire with solder and heat shrink or tape. You can also use **** splice connectors and tape. The best long term repair is to replace the harness with a part available from Invacare. The most definitive way to diagnose this problem is to read the fault log of the controller using a hand held programmer available to dealers and certified technicians. The number and type of fault codes logged in the controller is another indicator of which
component(s) has failed. Hope this helps.
Nov 19, 2010 | Invacare Pronto M51 Power Wheelchair
What hapens when your hover round wont start.
What happens is you won't go anywhere!
Seriously, it is usually a case of bad batteries. Each battery should show at least 12 Volts DC across the terminals. If one or both don't, replace, recharge and you should be good to go. If the batteries are good (over 12 volts), and you get no lights on at all, first check that the circuit breaker isn't tripped. It's a small button located on the base with a flexible cover. Push it to reset, and try again. If it's still dead, then remove the seat and the shroud cover and unplug, and replug every single snap-on connection to insure good contact, and check all fuses. If it is still dead, this means the power controller or the joystick are shot ($$$$$$$$!!!!!!!!!). Hoverounds usually have a combo joystick/power control module made by PG Drives, and a new one runs about $1,300.00. If you go on Ebay and search for a PG drive controller, make sure that it is one that has identical connections for your chair, or it won't work. You can usually pick them up for 300-400 bucks. They are very easy to install, just unplug, inplug, and go. If you can find somebody in your area with a similar model, you can unplug their joystick and plug it into your chair. If it works, its the joystick control, if not, it's back to a bad connection.
Jul 05, 2009 | NRS Hoveround MPV 5 - Used Power...
I have a invacare The joystick mk5 will not lite up batt. are new
Some chairs, like the M91 are a real bear to replace the batteries and connectors can get knocked loose in the process. First, using a voltmeter you need to see if the controller is getting power. On the DC setting, use voltmeter at the three-pin female connection at the joystick that is the charging port. The two pins that are opposite each other are the "hot" pins, and your meter should read about 25 volts, +- 2 volts. If its 0, there is a connection that isn't made from the batteries through to the controller, or the controller or joystick is shot. If you do have power to the joystick, then it's probable that the joystick is shot. A new one from Invacare is pricey, around $1,000.00 I have found a new site that can repair most makes. I have not used them, so cannot vouch for their work, but give them a call and see what you think.
http://www.flightsystems.com/cart_controls/wheelchair_powered_scooter_market_cart_controls.htm
If you don't have power, start at the terminals from the battery, and follow each wire back to the power control box, unplug and replug firmly as you work your way back. Check all fuses on the way. Then check all of the other connectors inside the chair, unplug, and reconnect again. Unplug and reconnect the wires leading into the power control box, and then restart chair. If no lights still, then the power control module is probably the culprit, but the address above fixes those too. The joystick and the power control module work together to make the chair operate safely. Good luck
Jun 19, 2009 | Electric Jazzy 1115 Power Wheelchair
Health & Beauty Logo
73 people viewed this question
Top Quantum Health & Beauty Experts
Scooter Doctor
Scooter Doctor
Robin Hill
Robin Hill
Are you a Quantum Health and Beauty Expert? Answer questions, earn points and help others
