Question about Light Office Equipment & Supplies
Eclipse plc red light flashing and beeping - Light Office Equipment & Supplies
Sanyo plc xu115 new bulb wont fire. power light turns green at first but after a few seconds it turns flashing red. the old bulb exploded on this projector.
Could be a burnt capacitor on the circuit board. Replace capacitor if you can determine which one it is. There are only a few.
Apr 20, 2011 | Sanyo PLC-XU115 Projector
My Sanyo PLC XE31 wouldn't switch on, bulb replacemetn lamp was lit. Changed bulb and now it switches on, green light shows, fans run, and then after approx 30 seconds the red light flashes and it switches...
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Jan 24, 2011 | Sanyo FOR PLC-XE31
Plc-xu105 will not restart. red on, no fans
SAYA MEMPUNYAI SANYO PLC XU105 , JIKA DIHIDUPKAN POWER LAMP MENYALA HIJAU BEBERAPA DETIK KEMUDIAN LAMPU WARNING LAMP MENYALA, KIRA KIRA KERUSAKANNYA DIMANA YA..? TOLONG YA SOLUSINYA..THKX
Feb 19, 2010 | Sanyo PLC-XU105 Projector
I have a model PLC-XT11 and when I turn the power on the temp light and green ready light begin to flash. The red lamp light is on steady. I replace the lamp but no luck.
one or more of the fans may not be working right. also, the temp sensor may be shot. if the last time you used it it wasn't shut down properly, it may still be in cool-down mode.
Nov 06, 2009 | Sanyo PLC-XT11 Multimedia Projector
Flashing red Power light, but unit won't start
I had a similar problem, but with no lcd lights showing and the technician diagnosed as being caused by a faulty Ballast which he said caused the bulb to fail. He didn't test the bulb but his experience indicates that even if the bulb was not blown it would have been stressed and it would only be a short time before it fails completely.
When these fail there is no real reason for it it seems but it has been suggested that a probable cause could be not cleaning the filter, at least every six months. The result of a dirty filter would be overheating and this could be the cause of the failure. Perhaps you will have to check the ballast for problems
Jul 28, 2008 | Sanyo PLC-XU58 Multimedia Projector
Sanyo PLC-XU47 seems to power cycle
Welcome to resolve the problem if you please say what are the solution to me the same problem
Jun 07, 2008 | Sanyo PLC XU35 Multimedia Projector
It doesn't start up, only beeps and red light flashes
pls try to use another compatible memory stick.
then confirm the status of your micro processor
Apr 21, 2008 | HP Compaq dc7100 Ultra-slim PC Desktop
Top Light Office Equipment & Supplies Experts
richie46
Are you a Light Office Equipment and Supply Expert? Answer questions, earn points and help others
