Question about Video Game Consoles & Games
Troubleshoot joystick - Video Game Consoles & Games
How to bypass the joystick on a jazzy select powerchair?
If you want to test the motors you can apply 24v momentarily to the motor to see if goes. Otherwise bypassing the joystick and its safeties is not recommended. the Joystick plugs into a controller box, without the joystick you have no control because the controller relies on the signal from the Joystick. If you are turning this into a hobby you might try ebay for a joystick and have fun. Strege Mobility
Jun 07, 2015 | Select Health & Beauty
Permobil C 300 joystick showing joystick error and code 0E00 how to correct?
0E00 Joystick Error Joystick Error Right System fault Joystick Error
that is the info from permobil documents, it may be an error of the right motor / wiring "check all connections, unplug and plug in again all connectors, if still persists then it would seem to be an error with the controller its self, this maybe the pcb or the joystick its self, some times if you give the joystick a good workout (moving it to its limits over and over again for a couple of mins and then turn on and see if error clears) if that fails then it looks like a new joystick or the whole controller might need replacing, if you know some one with the same controller on there chair see if they will let you plug it in to your chair just to confirm it is that.
hope that helps, and if so please click "Helpful" to let others know
have a great xmas all
Dec 01, 2014 | Health & Beauty
Thanku sir i can fix joystick to the toshiba c640 laptop and i can play gta game
Hi Yes you CAN use joystick controller for your Toshiba c640 laptop.
It is compatible for your Toshiba c640 laptop. You can connect cord of the joystick controller going to your laptop USB port. And once you have the joystick controller you will also have the instruction along with the joystick controller and its going to be more easier for you to install the joystick controller for you laptop.You can check the price online just type USB joystick controller on the search box of or
I am pretty sure that you will enjoy playing GTA . Please rate my solution here at fixya. Thank you and good luck : )
Oct 26, 2011 | Dell Latitude C640 Notebook
My computer is unresponsive to the joystick; I plugged it into the usb port a message confirmed it was installed and ready for use but nothing happens when I move the joystick in a flight simulator or...
Hello, Here's the solution to your problem, you have to configure the games you're playing for the joystick to work, I believe all games have this option, ussualy in the "configure keyboard and mouse" options menu, click on any funcion you want your joystick to use for each button, and then press the button you want for that function, do that with all buttons of the joystick you want to use, some games need the joystick axis to be configured, just click on left/right and move your joystick in the desired direction, same procedure to up/down, if your joystick has a throttle wheel, do the same for it (if needed).
Procedure is simple and most games has small variants of this procedures I gave you, but they are simple to figure out.
Hope my solution helps, have a nice day :)
Apr 14, 2011 | Trust Predator TH 400 (12629) Joystick
Both my joystick are not working
Try Other Games... If That Still Doesn't Work Loan An Additional Joystick Just To Check If It's Joysticks Fault, If The Additional Joystick Doesn't Work Then It Must Be A Broken Port Or Something...
Nov 21, 2009 | Sony PlayStation 2 (PS2) Console
Here are the Master Reset codes for your phone.
Master Reset / Codes
Accessing the Service Menu - Move joystick right, press * key, move joystick left twice, press * key, move joystick left, press * key.
Checking Firmware Version - Move joystick right, press * key, move joystick left twice, press * key, move joystick left, press * key, press 1 key twice.
Show IMEI # - press * key, press # key, press 0 key, press 6 key, press # key
Manual brightness adjustment - While in camera mode, press and hold * key and move joystick to lower brightness, press and hold 0 key and move joystick to increase brightness
Quick ScreenSaver - Pressing # and * at the same time
Show screensaver and lock keypad - press * and lock keys
*#0000# - Reset language back to english
Hard Reset -Hold power for 10 seconds
May 28, 2009 | Samsung SGH-D500 Cellular Phone
Joystick will not work with Combat Flight Simulator WWII Europe
Some joysticks are not compatible with certan games for expmple when i am using flight simulator and change to my combat flight simulator i have to change joysticks
the only other thing i would think is try deleting the currently installed driver for the joystick and then download a driver for a joystick that is surported, it wont work as well but at least it might accully work
Mar 22, 2009 | Logitech Attack 3 Joystick
Psp joystick
well psp were built to have its own joystick, other joystick are usually generic versions, so the chances of them being faulty for psp are high
Feb 10, 2008 | Sony PlayStation Portable (PSP) Console
Cant go left on joystick last solution no good
see buuddy if u have allready triesd with blowing out the dust from joystick part than go for the change of the keypad(joystick). the problem might be with the joystick it might have got broken so change the joystick and than try.
Oct 11, 2007 | Nokia 6600
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
