Question about Intex Boating
Intex mariner 4 motor mount kit is able to hold 4hp Yamaha outboard or can I customize the kit ?
5 Suggested Answers
SOURCE: what is the correct fuel/oil mix for evinrude 4hp ?
the proper mix is 50 to 1 or 16 oz to every 6 gallons,in my little boat I put 4 quarts in the 48 gal tank and its been running for 22 years,your running way to rich and your plug is probaly fouled,take it out clean it up/dump your fuel and mix it right,thats a great motor you got,I hunted with it for years,oh yeah when you get started run it till all the smoke is gone or you will have carb problems ,if you dont have them all ready,a little carb cleaner wont hurt but get it running first,or all that trash will foul you out,have a great trip bartriley1
Posted on Jan 05, 2009
finish line
  • 207 Answers
SOURCE: 1999 Mercury Mariner 9.9hp outboard motor
should be on the side with a lever but could you give me more info please
Posted on Jun 27, 2009
SOURCE: Can Intex mariner 4 carrie an engine Yamaha 8 HP
no. my 28 lb 3.5 tohatsu strains the pvc material that the tubes are made out of pretty well. the weight and thrust of the motor pulls pretty hard on these tiny little rubber "feet" glued to the tubes. I usually dont even run full throttle as it looks like i will pull the motor mount feet right off the tube. I couldn't imagine a bigger, heavier motor than what i am running working out well in the long run.
i have the intex mariner 4, btw.
Posted on Dec 08, 2009
SOURCE: Looking for a gasket set for my 1988
top gasket kit pt. no. 3L663D
Posted on Jan 14, 2011
A sucking noise by the carbuerators on a 2000 100hp yamaha outboard
Are any vacuum lines missing or broken cracked etc? Are all unused vacuum ports capped?
Jun 24, 2016 | Seloc Yamaha Mercury Mariner Outboards...
How to find model number on mariner outboard 4hp 2stroke engine
Mariner 4hp are identical to Yamaha engines.
You should find a sticker on the port bracket with serial and model number.
If that sticker has disappeard, an aluminum piece is stamped in the side of the cilinder. The numbervstamped in that round pieceis the serial number. I can convert that serial number in a year/model number...
Feb 27, 2015 | Mercury Marine 4hp & 6hp Stroke Outboards...
How do i replace shift lever on a mercury 6hp 4 stroke
shift lever has a bolt in it and shift rod you need to remove powerhead complete to access also remove gearbox !
May 04, 2014 | Mercury Marine 4hp & 6hp Stroke Outboards...
Yamaha 4 hp outboard steering friction swivel screw does not work
That's a current problem.
OR the screw is rusted in place. So then use WD40 or eqivalent to free the screw.
Or the parts inside are worn. Remove the friction screw. Then, remove the 4 bolts holding the swivel cap. Remove the entire engine from the swivel to prevent it fall on the ground. Replace the worn parts.
Jan 18, 2014 | Clymer Marine Maintenance and Repair...
Yamaha 4HP outboard - cannot pull starter cord - jammed.
Engine or gearcase seized...
Remove the recoil starter ( 3 bolts and the startingear link)
If you can turn the flywheel slightly: Gearcase seized
If you can't turn the flywheel at all: Engine seized.
In both cases: If you can't disassemble and have the job done yourself, forget that motor...
Dec 09, 2012 | Clymer Marine Maintenance and Repair...
Is it compatible 3.5 HP engine with the boat? (mariner 4) if yes , when i used %30 of power just alone back side go down and can not control properly . engine is TOHATSU M 3.5 S
Your motor is too large.
For the Intex Mariner 4 Intex recommend an absolute maximum of 3HP (2,2kW) and the motor must not weigh more than 40lb (18,2kg).
Those limits assume that you are using the Intex motor mount kit (Part No. 10658) and that the boat is correctly loaded and inflated.
In reality and from experience I would personally recommend 2HP maximum power and to keep the motor as lightweight as possible. Although the Intex Mariner 4 can take a motor mount, it's really a rowboat and is not suited to using a motor for extended periods, but just as a convenient tender to a larger boat it's fine.
Dec 15, 2009 | Intex Mariner 4 Boat Set
Can Intex mariner 4 carrie an engine Yamaha 8 HP with a modificated mount if the engine have 60 pounds?
Oct 15, 2009 | Intex Mariner 4 Boat Set
Boating Logo
44 people viewed this question
Top Intex Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you an Intex Boating Expert? Answer questions, earn points and help others
