Question about JVC Car Audio & Video
My jvc car radio KD8568T has no sound on the am or fm radio channels. A message appears from time to time saying device not found. Any help would be appreciated.
  • 8 Answers
SOURCE: Car Radio, Casette Player and CD Player not working
Hello Lei,
It sounds like the antenna has came loose from the back of the radio and the wiring harness is loose.
Make sure you have a good ground going to the radio, or this will cause a short and make the radio do strange things, the fact you sometimes get a signal tells me the radio is in working condition.
Posted on Sep 22, 2008
  • 95 Answers
SOURCE: How to set FM Frequency on XM Radio Delpi SkyFi
is this a skyfi 1 2 or 3. if its a two or three if you go to the menu button and scroll down to fm frequencys and select that from the drop down menu. then scroll through the built in frequencies and determine which one comes in the clearest. if its a skyfi one then your gonna have to put in a wired fm modulator because the first one doesnt come with a wireless fm transmitter.
Posted on Feb 17, 2009
  • 2004 Answers
SOURCE: I need the Toyota AM/FM radio model 37409 Security
Good luck.
Posted on Oct 22, 2009
  • 2200 Answers
SOURCE: go 730 not sending a fm signal
If you have made a recent update this may be the reason you may have lost your FM transmission!!
Tom Tom disabled silent FM transmission on these units to comply with the law in certain countries which prohibit these FM transmissions. Later updates configured the units to output lower strength FM transmissions.
There is a possible workaround for this - see this link for a discussion on the issue.
Hope this helps. Thanks for using FixYa
Posted on Dec 27, 2009
  • 3 Answers
SOURCE: Can't change channel of a Motorola Visar
The Visar has a channel lock feature. If you hold down the two channel buttons at the same time, it will do one of two things depending on the settings. Either the channel will lock, or the channel numbers in the LCD will flip.
If you press the channel button and the "popples" "pop" (for lack of a better word) then the channel selection buttons re most likely OK. To fix it you just press both channel buttons at the same time for about 5 seconds. It will beep and you should be able to change the channels. If not, then it needs to be repaired.
Posted on Mar 29, 2010
How can I listen to the radio without the head set?
Hi Arthur, unfortunately you can't as the wired headset acts as an antenna!
Since the FM radio uses the provided wired stereo headset as its antenna, before opening the application, connect the headset to your phone's the audio jack.
9.3.1 Opening the FM Radio
1. On the Home screen, touch
2. The first time you open FM radio, touch Auto tuning, which automatically scans for
available FM channels, saves them as presets, and plays the first FM channel
May 01, 2016 | Huawei Cell Phones
JVC RX 515 receiver
The fault is on the tuner section of the receiver. FM radio signals are processed by one IC in the tuner section. Since you can hear the station, it won't be that one. The only other is the Stereo Decoder. The radio signals are passed to this and that splits the signal into the left and right channels. If you can't here one of the channels then the Decoder IC will have failed. If you are lucky the board will label the IC, otherwise find the tuner section (look for coils). Then read the numbers of the IC's. If there are several enter each number into Google and find what it does. If you find one that says "decoder" or "FM multiplex" that is the one you need to replace.
Jan 06, 2014 | JVC Audio Players & Recorders
We have two Motorola t6310 two radios with the FM radio feature. When we turn the FM radio on, we get nothing. No static sound comes out. What could we be doing wrong? Thanks!
Here is a link to the user guide for the T6300 series.
The instructions for tuning the FM radio feature are on pages 22-23. You can have the radio scan for available stations, or you can do a manual search .01khz at a time. Once you have found a station, you can save the location.
Best regards.
Nov 17, 2012 | Motorola Talkabout T6310 (14 Channels)...
Jvc KD-R531 ipod
Contact JVC customer service please.
Dodge 2005 diesel truck has a Pioneer DEH 96200BT radio. The AM/FM radio part works but the sirius says "no device
Did it ever work? Sounds like you have an interface problem. Make sure the radio is connected to a Sirius XM satellite. If your device is not connected to a satellite, your device will display an error message such as "Searching for Signal."
Jul 05, 2011 | Car Audio & Video
How to memoriese radio channel. my jvc car radio whenever I set the station and when I switch off engine next time I have to tune again.pls solve my problem
Hello my name is Israel. The problem is with the wiring connection. You will need to make sure that the yellow wire is connected to a positive 12 volt source at all times. What is happening is that the wire is connected to a switched 12 volt. Reconnect wire to a constant 12 volt source. Good Luck.
Iwave fm stereo transmitter
This is a device that "Sends" FM stereo & Transmitts Radio waves, and sends sounds/music speech etc, over the airwaves to a suitable reciever an the same "Channel" You can hook up say your Ipod to it and say tune your Car radio to the "Station" it sends on and listen to ya compilations, in the car, thru the car stero system. The radio just "Sees" it as another strong station.
Jan 24, 2010 | Pyle PIFMDK6 iPod Car Stereo FM...
Jvc kd-sx750 head unit has power but puts out no sound
bro to me it sounds like your radioi is bad you got everything hooked up right to get sound from it maybe the ant. hooked up but you should still get sound thats why I say the amp in the unit is bad!
here a little help: red: ignition when the key is turned on
yellow or orange: all time 12v
black: ground
blue: amp turn on, or auto ant.
Connecting an MP3 player to car radio
The most common way is to use the auxiliary input of the deck or head unit. However I don't believe the JVC model you have has one of these. Don't despair though. Head to your local department store with a music department and pick up a universal FM modulator ($20-$30).
These will 'pretend' to be an FM radio station inside your vehicle. Attach the stereo mini plug to your walkman or other audio device (mp3 player etc.) Then tune the FM Radio to the fm station listed on the FM modulator and you will be able to listen to the device through your car stereo speakers. Now this isn't as clean as a direct hookup but for most its an economical way to listen to alternate sources on your Car Stereo.
Jul 07, 2009 | Sony Car Audio & Video
Car Audio & Video Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
