Question about Cameras
Diffuser cant takeout - Cameras
  • Cameras Master
  • 5,412 Answers
Maybe cook for yourself from raw ingredients ? Far healthier.
Posted on Apr 17, 2017
When I changed Pentair Whiperflo motor with new Impeller & Diffuser seals the new motor shaft does not turn. Diffuser is pressing against Impellor not allowing it to rotate. What is wrong ?
Take the Diffuser off and run it if the impeller turns then might be tightening the Diffuser too much, it just needs to not move, doesnt really need a super waterproof seal or anything like that. If it still doesnt turn with the Diffuser off it might have locked up when replacing the Impeller, you can try to turn the impeller manually or remove the cover plate on the back of the moter and turn the shaft manually back there. OOoorr you broke it
Aug 03, 2015 | Pentair 2.0 Hp Whisperflo Pump
I cant get my Gaggia Classic to work with pods
You need to use the single-serving size one-hole basket, not the double, with the diffuser valve seated beneath the basket. Then the Illy ese pod should be inserted with the decal facing up. Finally, and most importantly, when you lock the filter assembly into the machine, you need to close it firmly. Brown water can mean that the basket assembly is not sealed in tight enough.
Sep 07, 2014 | Gaggia Classic Espresso Machine
Aria diffuser does not emit any mist
Did you find a solution? I just received mine and have the same issue.
Mar 12, 2013 | Young Living Aria Ultrasonic Diffuser
I have a 1 1/2 year old whilepool gold refrigerator model GS5VHAXW. In the upper left rear there is a box...I think it is some kind of damper. There is a continous popping or knocking sound and the fridge...
You are correct this box that is in the upper left corner of the fridgerator towards the rear of the machine is actually termed as a diffuser. Its basic job is to open and close letting the cold air into the refrigerator from the freezer. When you fridgerator is to cold the diffuser, also known as the damper assembly in other units, closes and when the frigerator is to warm it opens the small fins on the door letting the cold air back into the refrigerator side of the unit. There is also a control for this diffuser located in the ceiling of your fridgerator as well. Around this time of year do to the tempreture getting hot outside I do notice more diffuser's that I have to change in a week more then diffuser controls. Is this the area that is makeing that poping sound on you? Carefully remove the diffuser not breaking either of the two thermostat lines and inspect to see if you have an ice build on the inner fins of the diffuser if you do it is best to replace the diffuser itself instead of opening it or proping something on the inside of it to keep it open. If you have any further questions message me back. And please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks
p.s the part number for the diffuser is W10128734
Jul 02, 2011 | Refrigerators
Dodge daytona 89
just remove the caliper and bracket. then pull off rotor, if it dont just come loose its rusted on and you will need to beat it off with a hammer. one big hit is better [less damage] than several little hits. then just beat out broken stud. put new stud in and find some washers or nuts that go over the new stud so you can "****" in the new one with a lug nut.
Apr 10, 2010 | 1989 Dodge Daytona
How to replace light globe in Chateau Grange rangehood
I have a 600mm Chateau range hood with the same problem. To access the globe chamber, you need to first remove the plastic diffuser from the underside of the rangehood. Located at one end of the diffuser will be a small slot approx 10 mm long. Insert a small flat blade screwdriver into this slot and carefully depress the plastic tongue of the diffuser by gently pushing the head of the screwdriver away from the diffuser. As the tongue disengages from the frame you should be able to grasp the edge of the diffuser and pull it away from the frame. Once the diffuser has been removed from the frame, you will be able to change the globe.
To reinstall the diffuser, insert the plain end of the diffuser into the frame of the the rangehood (above the globe) and gently push the clip end back to its flush position.
Nov 17, 2009 | Kitchen Ranges
Cameras Logo
41 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
