Question about The Audio Players & Recorders
I have a receiver already and I have the plug all I need is a AV cord for it
My onkyo HT RC330 will not power up at all. Have had problems past couple of months with starting it but if you played around with swith it would start. Now nothing.
Try resetting the AV receiver To reset the AV receiver to its factory defaults, turn it on and, while holding down VCR/DVR, press 8 ON/STANDBY. "Clear" will appear on the display and the AV receiver will enter Standby mode.
It is possible that the protection circuitry has been activated. Remove the power cord from the wall.. Disconnect all speaker cables and input sources, and then leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect only the power cord and set the volume to maximum. If the AV receiver stays on, set then the volume to minimum, disconnect the power cord, and reconnect your speakers and input sources. If the AV receiver turns off when you set the volume to maximum, disconnect the power cord, and contact your dealer.
If the standby light is lit it and the unit will not boot it is most likely that the protection circuit has been activated. If there is no standby light then check the fuses. These units check that the power supplies are operating near specification. If a capacitor or resistor in the circuit, or a broken solder connection the unit will shut down. Because of the temperature the thermal cycling around the power supplies a broken solder joint can occur. This will make for an intermittent operation.
Hope this helps.
26289825-owoa52fq3dbvw0lom3ojbzgr-3-0.jpg Failed resistor or capacitor
Sep 23, 2016 | Onkyo Ht-rc330 5.1-channel Home Theater...
How do you plug in a nintendo 64 to my t.v
make sure the correct plugs in the nintendo 64 are in their sockets (not that hard to do, as one is massive and the AV cable is small) and then make sure the other side of the massive cord is plugged into the power point, then plug the correct AV cords into the correct colours of the AV receiver (red to red, white to white, yellow to yellow) hope this helps
Jan 15, 2012 | Nintendo 64 Console
I cant hook it up to the tv
Run a three color AV cord (red, white, yellow) from the output of your surround sound receiver to the "DVD" input on your TV. The yellow is for video and the red and white are for audio so make sure you plug the tips into the same color ports. Now look at where you put the 3 color cord (AV cord) into the TV, which "input" did you use? Video 1 or Video 2 more than likely. Now turn your TV on and in the menu settings select the same video input you hooked the AV cords into on the back of your TV. This will get your theater set up. The remote is slow to process after you push buttons so give the remote a few seconds to respond.
Mar 22, 2011 | Protron PDS-2315 Theater System
Zenith TV has no place for yellow, red, white composite plugs
This TV doesn't have an AV input, so there are no input jacks other than the antenna connector. If you want to connect a device that has only AV outputs (your red, white and yellow plug) you will need an RF converter. This will take the AV signals and convert them to a channel 3 or 4 signal you can tune in on the set.
But since you don't seem interested in spending any money, you'll probably not like to hear that the converter runs around $15 most places. Take heart, there is an alternative. Find a VCR (if you don't have one already) that has an RF output. Many of the the newer DVD/VCR combos only have AV outputs. You're looking for one that has an "out to TV" threaded connector on the back. These units already have an RF converter built in. Connect your AV plugs to the line in jacks on the VCR and switch to that input, and you can use your video game or DVD player through the VCR.
Jun 20, 2009 | Zenith SY2549S TV
Need a new power cord....misplaced mine...
i did the same thing. replacement at radio shack.
Jan 17, 2009 | Technics SA-EX140 Receiver
Yamaha av receiver rx-359
go to best buy and buy a new recever
Jan 12, 2008 | Yamaha HTR-5560 Receiver
Plugged in 220v by mistake
Did you check trafo? Do you get any power on secondary coil?
Oct 09, 2007 | Aiwa AV-X200
Hook up all my components together
Hi knit, You need a 4 port A/V switch. Ebay has one:
Oct 05, 2007 | Sony PlayStation 2 (PS2) Console
Top The Audio Players & Recorders Experts
Jose Ma DM.
Jose Ma DM.
Level 1 Expert
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
