Question about Refrigerators
C255 defy fridge freezer not working - Refrigerators
    Habit-Forming:
  • 94 Answers
1. DIRTY CONDENSER - CLEAN THE CONDENSER COILS AND FAN
2. TEMPERATURE SETTING TURNED TO LOW - TURN TEMPERATURE SETTING TO COLDER
3. CIRCUIT BREAKER TRIPPED - POWER SPIKE - RESET CIRCUIT BREAKER
4. COMPRESSOR WON'T START - FAILED CAPACITOR - REPLACE CAPACITOR
5. COMPRESSOR NOT STARTING - BAD RELAY - REPLACE RELAY
6. DEFROST TIMER MALFUNCTION - REPLACE DEFROST TIMER OR COMPUTER CONTROL BOARD
7. FAILED DOOR SEAL - REPLACE WORN OUT DOOR SEAL
8. FAILED COMPRESSOR - REPLACE COMPRESSOR
Posted on Apr 17, 2017
What is the problem if i fit a new domestic defy fridge thermostat with the same part it still stays running and not cycle.
what temp is in the fridge around 4 degrees and freezer -18 degrees and does the eveporator fully flood with with refrigerant if yes then try checking defrost timer is moving from its position also check is both fans runs
Oct 04, 2016 | Refrigerators
Defy fridge freezer freezer door a draws freezIng up with ice it is set at 2
Check if rubber that seals door is in tact and does not lift somewhere.
Feb 26, 2015 | Refrigerators
My double door firge frezeer is not icing and the red alarm button is alarming all the time
Glori,
you mite need to replace your thermostat,...... the alarm button is
telling u that your fridge is not cold enough, there is also probably another prob but u need to b a electrician to sort it on the top of fridge there is a panel,.. under that there is a fusible link if one blows it will need to b replaced its soldered in no job for u unless ur a electrician hope this helps
Oct 24, 2013 | Red Defy Helmet Youth 2012
Defy fridge f640 wiring diagram faulty compressor or thermostat
Hi my name is jp. Got a defy f640 the freezer not working. Trips power. Wires been removed at back of the compressor. Need to know where the wires need to go
Dec 22, 2012 | Refrigerators
I have defy fridge/freezer combo c380, freezer gets cold at bottom but fridge above does not want to, what can be the problem?
Defrost cycle has problems. Could be defrost timer, heat element, or defrost stat. temporary solution, if you can see ice accumulated inside the fridge on the back wall, desconnect or turn it off, until this ice it's gone, can be use for couple days, until service could be done on it.
Dec 23, 2009 | Refrigerators
DEFY C361 Double door fridge that does'nt get cold
We solved this by replacing the thermostat with a new one.
Sep 11, 2009 | Freezers
Fride not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 04, 2009 | Amana ARB9059CS Bottom Freezer...
Defy Side x Side Refrigerator Freezer
Hissing is not good. You could have lost the gas.
Apr 28, 2017 | Refrigerators
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
