Question about Ematic Audio Players & Recorders
I have an ematic digital converter and I'm trying to find the USB update
gopakumarg43
  • 75471 Answers
SOURCE: Lost ematic digital converter box remote got a RCA universal remote I need code's to program
RCA remote control have no set-up code to this device. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
Posted on Oct 08, 2016
gopakumarg43
  • 75471 Answers
SOURCE: Lost ematic digital converter box remote got a universal remote I need code's to program
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
gopakumarg43
  • 75471 Answers
SOURCE: Zenith universal remote needs code for ematic digital converter
Programming Notes
Posted on Nov 17, 2016
emissionwiz
  • 79865 Answers
SOURCE: I have ematic digital converter box hooked up to my tv Can i plug my lg phone into the usb port in front and play you tube videos if so how do i do this through my menu guide model is ematic at103b
I do not think that will work, but try it.
Posted on Nov 18, 2016
  • 5427 Answers
SOURCE: Is the Ematic AT103B Converter Box compatible with Suddenlink cable/digital service?
No, the Ematic AT103B is an over-the-air digital ATSC tuner and will also can convert the digital signal to analog NTSC for older TV tuners. It will not work with any cable service and is for "cord-cutters". The AT103B requires an antenna to receive your local OTA channels. Depending on where you live, you may get some channels with an indoor antenna. You will get better reception with an outdoor antenna. See http://www.tvfool.com or http://www.antennaweb.org for details on the channels you can receive with an antenna pointed in a particular direction.
The Ematic set top box does provide an HD signal output and a DVR (time-shift function) so it is more advanced than the first generation OTA converter boxes. The original (available with the government coupon) converter boxes only gave an SD output.
I hope this helps.
(antennaweb.org gives a very conservative list of available channels but assumes an external antenna. tvfool.com lists the channels that are likely to be received with a variety of antenna strengths. An antenna signal amplifier can improve the reception. (Digital stations will not be seen if the tuner can't lock onto the signal.) However, when the amplifier fails, you may find some channels will not be received at all.)
Posted on Dec 09, 2016
Testimonial: "Thanks for your info. I ordered this converter and never saw the antenna requirements until I received it and was reading the manual! Thanks for help."
How do I upgrade my Emactic AT103B converter box from usb?
As far as I can tell, there is no firmware update available for the Ematic AT103B. If you do have a firmware file for this converter box, plug in the USB drive when the converter box is on. Then press Menu and go to the System Setup (the icon has a gear and is labeled Settings) menu option with the Left/Right arrows. Press the Down arrow and continue down to the Software Update line. Press OK. Select the correct file. (If this file isn't shown, try inserting the USB drive after reaching this line.) Press the right arrow to start the upgrade process. Do not let the unit power down during the upgrade.
See page 14 (page 15 of the PDF) and the preceding page to see how to navigate the System Setup menu. The manual is available here: https://ematic.zendesk.com/hc/en-us/articles/220756147-AT103B . The direct link to the manual is currently: https://ematic.zendesk.com/hc/en-us/article_attachments/208176947/AT103B_manual.pdf .
I hope this helps.
Feb 03, 2018 | Televison & Video
Program my g.e remote control to a A.T.103 gematic digtal box
Tv Converter Box Deals
www.bestdeals.today/tv-converter-box
Digital Converter, Ematic Digital TV Converter Box with Recording, Playback, ...Digital to Analog TV Converter DTV Tuner Box w Remote, Program Guide, PLUS MORE! ... GE Television Antennas Omni TV Indoor Antenna 24731 ... HDMI/HDTV/DTV/RF/RCA/USB Digital Converter Box TV Tuner With Remote Control PVR.
Ematic DVR Recorder Television HDMI Media Player ...
www.altatac.com/p-15751-ematic-dvr-recorder-television-hdmi-media-p...
Ematic DVR Recorder Television HDMI Media Player Converter Box w/ USB ... TheEmatic AT103B Digital Converter box allows your TV without a digital ... Features an electronic program guide, parental controls, and a USB ... Full function remote controlincluded. .... My Account My Account Order Status Track Your Order.
At103b Ematic Converter Digital Atsc
antennadisht.com/at103b
11 ozmiscellaneouspackage contents converter box remote control 1 x user ... Review (mpn:at103b for sale) Digital Converter Atsc Ematic At103b Box . ... You can find your tracking number by ing on my and scrolling down to your purchase with us. ... Features an electronic program guide, parental controls, and a usb ...
Jan 24, 2016 | Televison & Video
My ematic digital converter box is saying boot. How do I boot it?
Hi Lisa, Boot just means turn off then turn on............CHEERS..
Jan 15, 2016 | Ematic Audio Players & Recorders
How do I get a passcode for a ematic digital converter box AT103B
Just use all zeros for the pass code which is the factory default.
Feb 21, 2015 | Ematic Audio Players & Recorders
I have an eGlide XL2 10.1 android tablet when I try to access e matic app store notice say unfortunately ematic app store has stopped, how do I start it again or open ematic app store
after uninstalling app store updates, l went to the reset button(actually a tiny hole) on the back of my ematic tablet, used a head of a needle(paper clip,etc) to press the reset button. My app store came back. Until ematics works out the kinks l just won't install anymore updates.
Jul 29, 2012 | Ematic eGlide XL2 4GB 10.1" Android Tablet
Hello, i have an ematic mp3 and video recorder and i downloaded the video converter but my videoes have no sound or are slowed and split
convert again your video but with lower bitrate video and use sound codec that support with your media player, see the manual to check the video and audio codec that compatible with your media player
Feb 15, 2011 | Beond Ematic EM304CAMB Digital Media...
I need an owners manual for ematic 8gb mp3 player
hi you can download the manual from below link
http://www.retrevo.com/s/Ematic-EM324CAM-MP3-Players-review-manual/id/23146bh138/t/1-2/
Sep 17, 2009 | Audio Players & Recorders
Cannot find music files on my ematic mp3
To do a search on your computer just goto START, then SEARCH. Click on "All Files and Folders". In the search box, type in *.WAV or *.MP3. This will search your entire computer for WAV files or MP3 files. To convert WAV into MP3, you will need to download a program from the internet that cnverts WAV into MP3 files. Just goto google.com and type in WAV to MP3 converter and should be able to download free converters....
May 30, 2009 | Beond Ematic EM304CAMB Digital Media...
Icant put videos on ematic mp3 player?
What you need to do is have your videos set to be converted by the MTV convertor that came with the device. It's usually on a mini disk.
You have to download the software and then input the video you want to convert.
The thing is that not any video will be recognized by the software. You'll need to convert most stuff to .avi files first.
For example, if you download a non-copy righted clip from youtube, you have to convert that to .flv format. (I recommend keepvid.com) Then you need to run that that to an .avi format. For that I would use MediaEncoder from sourceforge.
Feb 13, 2009 | XO Vision EM104VID MP3 Player
Top Ematic Audio Players & Recorders Experts
Lawrence Oravetz
Are you an Ematic Audio Player and Recorder Expert? Answer questions, earn points and help others
