Question about Midea Freezers
Midea HS 241F upright freezer stopped cooling.Is there a reset switch on it. I hear it starting by the box next to the compressor, but after 10 or 15 seconds click and nothing
fridgetech
  • 473 Answers
SOURCE: Whirlpool ev200nxr upright freezer not cooling.
It is most likely the relay and overload or the thermostat.  What is the complete model # on the sticker inside the freezer?
Posted on Oct 15, 2007
refritech08
  • 149 Answers
SOURCE: Compressor Stopping
compressor is running overloaded possible problems bad relay/overload /capacitor dirty or clogged condensers if the unit uses a condenser fan suspect a bad fan. and defective thermostats are notorious for short cycling. id check the coils first and if dirty clean up maybe that can be the major problem.
Posted on Apr 23, 2008
mikeh77586
  • 9 Answers
SOURCE: Kenmore Upright Freezer compressor running 6 seconds every minute
Usually the compressor runs pretty warm anyway. However if you think it's too hot I would start with the condenser coils located either under the unit or on occasion they are located on the back. The air flow across these coils as well as the airflow around the compressor must be maintained. I forgot to ask if the condenser fan is running. Check and make sure that the Fan is running and the air flow is good. Also, When you transported the unit did you move it standing vertically like it normally stands or did you lay it on its side. If you transported the unit on its side you must wait a minimum of 24 to 48 hours prior to start up or the unit could be ruined permanently. The refrigerant has to be utilized through the compressor as a gas. If the unit is on its side liquid refrigerant could be introduced into the compressor and can cause permanent damage. If this is the case I recommend that you turn the unit off at once and wait the 36 hours for the Refrigerant to settle then try it again. This transportation rule applies for any appliance That uses refrigerant, Air Conditioners etc. These units are not that hard to diagnose. The only other item that is usually a problem is the defrost timer. It is not very expensive and can also cause some of the same symptoms that you are eluding to. The defrost timer allows the freezer to periodically shut down to prevent the buildup of frost or ice on he evaporator coils and on the inside the unit. If it is defective, then the unit will either run all the time and cause the evaporator coils to freeze up or will not allow the compressor to switch on and it will not freeze like it should.
Posted on Nov 12, 2008
  • 108 Answers
SOURCE: White Westinghouse upright freezer not cold enough.
Coils are probably underneath. remove the grille at the front (usually you just rotate it down to pull off) and then vaccum inside with a wand. If there aren't any coils there either, pull the machine out from the wall, and remove the lower panel from the back side. Inside you should find a fan next to a coil. Make sure that fan is working, and if it isn't make sure it is getting power.
Vacuum out as good as you can, and if you can use compressed air to blow it clean, even better (vacuum first because it will kick out a lot of dust).
If vacuuming the coils doesn't work, then you probably have a freon leakage problem, in which case it is probably not worth the cost of repair.
Posted on Mar 09, 2009
blueextc3221
  • 15935 Answers
SOURCE: freezer unit not freezing
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 19, 2010
Freezer stopped after power outage
If the sides are hot, look at the defrost timer. Sounds like it has stopped running with the defrost elements on. The compressor has a safety switch on it that opens either if the compressor gets too hot or if it pulls too much current when starting. If your power flickered a lot before coming back on, that triggered the safety switch. Now that it's running normally, I wouldn't worry. The defrost timer is your problem now.
Jul 10, 2016 | Frigidaire 14.1 cu. ft. Upright Freezer...
The fridge isn't getting cold. It has been close to 48 hours since I plugged it in.
You haven't said if you could hear the compressor running. If so then either the compressor is shot or there is a refrigerant leak. If it's not running it could be a bad cold control or the compressor starter. Oh and check to see that you have power at the receptacle that it's plugged into, I've been to calls of the refrigerator not working only to find out the it wasn't plugged in or the power was off at the receptacle.
Nov 02, 2013 | Midea HS-65LB Refrigerator
The freezer just stopped working. HELP!
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 23, 2011 | Frigidaire 12 cu. ft. / 340 liter Upright...
Freezer has stopped freezing
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Feb 26, 2011 | Haier 20.5 cu. ft. / 580 liter Upright...
Model ffu213caw1: my freezer stopped cooling recently.there is power to the uniti hear a small click down near the compressor like it is trying to start and then it stops.compressor is warm to the touch...
Compressor is bad the clicking noise is the Start Relay/Overload is kicking on and off. compressor is warm because it's trying to start but can't Frigidaire is known for bad compressors. I don't think the Start Relay/Overload is bad because the compressor gets warm.
May 20, 2010 | Frigidaire 21 cu. ft. / 595 liter Upright...
The compressor works for a few seconds but then stops. The freezer is over temperature.
Check the condenser fan motor (next to compressor) make sure it is running. Next change relay (inside black box) on compressor.
Apr 27, 2009 | Hotpoint 3.6 cu. ft. / 102 liter Upright...
14.1 upright Kenmore freezer was unplugged to clean after hurricane. We moved freezer to new location, never turning it on its side...plugged in and light works but freezer is not cooling. There are no...
Check to see if there is a reset on the compressor or close to it. Turn your control knobs up and down and see if you hear a "click". You might cause it to engage at that point. Let me know how this does.
Feb 01, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Upright freezer stopped working
That clicking sound is your compressor tightening up(clixon switching on and off.). Pull the freezer out and feel the compressor. If very hot and not running, there is your problem.
Jan 29, 2009 | Freezers
Freezers Logo
116 people viewed this question
Top Midea Freezers Experts
mike cooper
Andrew Taylor
Andrew Taylor
Al
Al
Are you a Midea Freezer Expert? Answer questions, earn points and help others
