Question about Saws
Need a couple of link for an old ladies yellow tone seiko watch 831224
Small yellow tone circular face and circular links (wind up)
  • 67 Answers
SOURCE: removing watch links
Look at both ends of the pin. One will look smooth, the other appears split.
You will need a suitable soft (wooden) support, and a very small dia. punch and a light hammer. The rest of the watch can be protected with a soft cloth.
You place the punch on the end of the pin which looks split, after arranging the watch so the link you are driving the pin from is supported on the edge of the timber. I drill a hole close to the edge of the timber over which I place the pin to be removed. Then by gently tapping the punch with the hammer, the pin should slide down into the hole.
One pin needs to be removed completely, the other can be left in the next link ready to tap back in after the link you wish out is removed.
The important thing is to have a decent punch! The diameter must be such as to fit easily through the pin holes, and the end should be flat. If you cannot make or find a suitable punch, one could be made from something like a darning needle.
Posted on Feb 22, 2008
  • 29 Answers
SOURCE: Dkny watch- repair, need extra links
I suggest calling DKNY customer service @ 1-800-231-0884 This is their return or repair department they should be able to help with links for your watch.
Posted on Mar 12, 2008
SOURCE: i need to add 2
Contact Bulova for additional links, 800-233-3350. You will need the watch model number and the case number (it's in the back beginning with "C".
Posted on Aug 20, 2008
slp11508
  • 43 Answers
SOURCE: Need to add a link to Armatron watch band
You have to call Armitron to get extra links for this watch. You could add them in yourself (if you purchase a watch link remover tool), or you could take it to a jeweler. You could also ask if they have the easy links which just snap on and off available when you call and these can be just snapped on and off without any tools.
Posted on Jan 05, 2009
  • 4 Answers
SOURCE: Remove link from Watch Band
I would suggest that you take it to local jewler or watch repair center, it normally runs less then $10 to remove an unlimited number.
Wal-Mart used to be a good place to go, but have since decided to support only watches that are sold in the store, which are crappy at best.
If you want to do it personally...I would discouage it. It is normally a simple process but without training, can turn into a big problem with minimal effort.
Have a great day!
Posted on Jan 13, 2009
Seiko Ladies watch. S/N 661236 Case # 1N00-0C99 I am looking for info on watch including value
This site gives your watch as made in some year ending in '6'.
They want more info.
See if this helps any -
Seiko Date Finder
Sep 16, 2017 | Seiko Watches
I need help finding how old a womens Seiko watch it has two set of numbers can u help me
Farrah, Contact Seiko or try Google search your watch Seiko # and see what comes up then try the second #. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Ladies Watches
Seiko Ladies Gold Dress Watch Maroon Dial Gold Mesh Bracelet Ca 1970s
Seiko ladies watch Gold with maroon face Google Search
Aug 08, 2016 | Seiko Watches
How do I take out links in a seiko SUR072 watch band.
Without seeing the band design, Seiko has a couple of executions that they use. One is a pin which is flared on one end. There is usually a directional arrow showing you which way the pin gets driven out. You will need a small hard pin. It should tap out, after the flared end is exposed you can pull it out with a small pair of plyers or side-cuts. Push out the next pin in the next link then put the pin back in the way it came out. The flared end is the last piece that goes into the band. If this doesn't work try a store where they at least install batteries. Good Luck hope this helps. Gabe
Dec 30, 2014 | Seiko Watches
Seiko automatic 5 23 jewel
Seiko automatics do not wind just shake it side to side a couple of times then wear it it self winds
Sep 01, 2014 | Seiko Watch SNXJ89K1
Ladies quartz watch stem winder knob lost lost how to remove from another to fix it?
mcdevito75 here, Best bet, look for a small watch repair shop in your area for another knob. As long as the stem is in place you just need the winding knob.
May 23, 2011 | Michael Kors MK5166womenGold Tone...
Ive had my Seiko automatic titanium scuba 200m about 3 years when i got it, i had it sized down by taking out 3 links which the store gave me back and 3 pins that go with , ive put on a few pounds maxed...
Thanks for contacting FixYa.
Seiko normally will send out up to 5 extra links on new watches. I am not sure on watches that are 3 years old but you will need to contact Seiko on this one. MAYBE a watchmaker locally will have some extra peices that will work too.
You can contact Seiko here:
http://www.seikousa.com/support/customer/northamerica.html
Best regards.
Jewel
Aug 30, 2010 | Seiko Diver's Watch
I pulled the stem out completely trying to reset time.
try to a authorized seiko service center!they are not expensive!the only think that your watch needs is anew winding stem costs 3-4$!the job isnt difficult for a good watchmaker!the jwellersin watch service are the same as you buying soap from a barber shop!
May 14, 2010 | Seiko SUJ051 Wrist Watch
if you broke the stem and its left a peice inside the movement then i would ask your repairer for a module exchange this is cheaper than servicing and a new crown 55.00 or send it back to seiko they are very good with there prices.you wont have the tools you need to replace it yourself..
Mar 25, 2010 | Seiko SUJ051 Wrist Watch
I have a Seiko stainless steel ladies watch, 3 years old, only one 'winder' no fancy buttons, analogue style. It has suddenly started beeping every hour - how do I turn it off?
mcdevito75 here, The beeping must be a signal that the battery is weak, have the battery changed. Look for a small watch repair shop in your area for the battery change.
Nov 05, 2009 | Pulsar by Seiko watch PEG665Ladies...
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
