Lost mains power cable for Beko 20LB450 Lcd Tv 50 CM
I have managed to lose the power cable/lead for my Beko 20LB450 Lcd Tv 50 CM and don't know whether they are universal or how difficult it is to get a replacement.
Please can someone help?
  • 188 Answers
It's universal unless it's also an 12V set.
Make a picture of the power connector with a mobile telephone and go to your local electronic store.
Posted on Jul 24, 2009
  • tkavanagh197 Mar 17, 2011
    i dropped the same connector model VE50-1500 its not working does anyone have one for sale .tommy
TV bauhn 50" 127 cm led LCD TV the blue light goes on but no show on TV
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 20, 2016 | Televison & Video
Beko 20lb450 wont start up keeps going back to standby after a about 5 second
Sounds like a main board IC fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 10, 2014 | Televison & Video
Beko 20lb450
If your TV is going to standby, it is most likely not getting a signal. Try using the input button on the remote to check other inputs. Also make sure the source (DVD, Cable, etc) is on and plugged in properly.
DRIVER FOR BEKO LCD TV MODEL: NR 15LB450
What cable are you using? I'm not aware of any driver? Try the settings in the TV, select Input, select the port you have connected to the computer. Take a look at this user manual: http://www.manualslib.com/manual/351949/Beko-15lb450.html
May 13, 2013 | Computers & Internet
The color is distorted there is a psychedelic green around. You can see the color images ok but there is a super imposed green color on the screen. Do you have any idea on the problem do I need to replace...
The tv problems u are decribing are 50/50 it could be the main board tv Tuner signal board is dying and shorting out or the tv LCD screen panel itself are leaking radiation and slowly shorting out.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish main board tv Tuner signal board for the replacement.50/50 could get this tv fixed by replacing this main board tv Tuner signal board.If after u replaced the board and still have the same problems,than u know for sure it is the tv LCD screen is dying and leaking radiation and slowly shorting out.Than u know for sure this tv is not worth as a whole tv anymore,now only as salvages tv for it PCB circuits boards only.U can return the main board tv Tuner signal board to the dealers.Get some money back,but must lose some money,like subtraction like from the shipping and handleling cost and the useually the 10% restocking fee.
Aug 14, 2011 | Proscan 40LC45S 40 in. LCD TV
Hi I have the Beko LCD 20LB450 television and have lost the instructions. I need to know how to removed the base/stand ?
I have the User manual/
instructions in PdF format that you can look in.....
pls send me an e-mail ,I can forward it to you..
Take care and do not forget to rate me too..Thanks
kerguney@gmail.com
May 08, 2011 | Beko 17WLB450S 17 in. LCD TV
Hello i have a hyundai tv plasma HPT 428 1H
Try a computer/electronics store. Ask for a power cable for an lcd monitor. It should be the cable you need.
Oct 06, 2009 | Televison & Video
No fan or heat
Hello..... have you (a) checked that you have power going to the oven...(b)...With the power to the oven switched off open the terminal block (where the cable from your socket enters the oven) check that all connections are secure....(c) remove the rear panel of the oven and check that the safety stat is ok.......(usually small square white or gray unit wit two wires running to it found on rear of main oven...it is usually fixed to a bracket or directly fixed to the cabinet...test for continuity with a multimeter if open circuit ..that is no meter reading relpace it
regards Sir Galahad
Jun 28, 2009 | Belling XOU492 Electric Double Oven
Sky codes for beko 32' tv
on the sky remote press the following
TV
RED + SELECT (blinks twice)
TV
0125
press the volume button,if it works press SELECT if not press TV then VOLUME again repeat this process of TV then VOLUME until it works then press the SELECT button to save the code to your remote.
Enjoy
Littlle Dish Fitter
Dec 27, 2008 | Beko 324250WN 28" TV
Televison & Video Logo
334 people viewed this question
Top Televison & Video Experts
Electro Med Services...
