Question about Sylvania Televison & Video
Screen set-up menu keeps flashing on screen. Didn't start..Can't stop. Sylvania 42
tvtechnician
  • 105 Answers
SOURCE: menu 42PF9630A 42
go to www.ceusasupport.philips.com and upgrade your televisions software to the latest version. this is a very common issue.
Posted on Jan 15, 2008
MNfisherman
  • 11896 Answers
SOURCE: sylvania 42" flat screen won't turn on
First you should check the fuse and the wiring in your tv by removing the back cover. Make sure no wires are bare or touching. If there are any, wrap them with electrical tape.
If you cannot see anything wrong by looking, then it is probably the set has a bad transformer (high voltage)
Posted on Jan 17, 2009
SOURCE: samsung 42' plasma tv,screen keep flashing, blurry,no pics
I'm not really sure what causes this but I might be able to help.
I have an LG 42 plasma which had the same problem. In my case I removed the video and the tuner board (they both were mounted on the same frame which was screwed on the tv chassis) and installed them in a "wooden box" so that there would be no electrical contact with the rest of the chassis except from the cables connected to them. It now works fine.
Posted on Feb 23, 2009
SOURCE: Lock/unlock symbol appears in the middle of the screen
hold the menu button between 10 and 20 seconds until the lock changes to unlock
Posted on Jun 14, 2009
  • 304 Answers
SOURCE: Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
Posted on Jul 17, 2009
My 42 inch sylvania hdtv screen is broken and not showing a picture
If the display panel (PLASMA DISPLAY PANEL--PDP) is damaged or broken etc it is fatal as the cost of the part alone will exceed the cost of a new set.
Oct 15, 2012 | Sylvania 6842THG 42 in. Plasma HDTV
The setup menu keeps flashing on the screen and I cant' get it to stop also the remote control is not working
Reset your TV. Unplug it from AC mains, and pulg it back after 5 minutes of so. This must make it a hard reset. If this do not help you, contact the service center.
Jun 14, 2012 | Sylvania LC420SS8 LCD TV
I have a toshiba flat screen 42 inch. i went to change the channel and now all i have is a white screen and no sound
Hello
The tuner card in your TV is not working I thinks. Anyway set the TV to its factory defaults. It will make all the setting to factory levels. If this also didn't helep you, repace the tuner card.
To restore the TV to its factory setting:
[1] Press Menu and open the SETUP menu.
[2] Highlight INSTALLATION and press ENTER. A new set of installation menu will appear.
[3] Open the SYSTEM STATUS menu. Hilight the SYSTEM INFORMATION, and press ENTER.
[4] Press [ => / [5] Enter your PIN code (or 0000 if no PIN code has been set).
OK
Apr 21, 2011 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
THE MENU KEEPS POPPING UP ON THE SCREEN CONTINOUSLY ON MY 42 INCH
I had an LG 37" LCD that did this to me. Turned out to be bad solder joints on the side button board. Just reflowed and it starting working fine.
But now that I think about, I had another set do the same thing, only it wasn't the button board. I had to upgrade the TV's firmware via the USB service port. Just needed a USB flash drive and downloaded the firmware from the mfg's website. There were easy to follow instructions there too!
Nov 29, 2009 | HP PL4260N 42 in. Plasma HDTV
New TV 9 mos old, Won't stay on after power up? Remote or manual turn on, set keeps turning off after 1-2 second green on and brief screen flash.
I would try leaving the TV unplugged for 30mins so the TV can reset itself.
If that doesn't work, your TV should still be under warranty. I know 95% of come with a 1 year warranty.
The most common problem with Sylvania TVs made by FUNAI, the Backlight Inverter board fails to early in life. ( That's the part that powers the screen)
The Tv can't power up the screen and it turns off automatically. Basically called "Protection Mode" so it protects the other parts inside the TV.
Jun 01, 2009 | Sylvania LC320SS8 32 in. LCD Television
My sylvania dtv wide screen does not show the words to the movie,news ect.i would like to know how to shrink the screen size to veiw the words on the t.v?
Yuo need to access the menu and select close caption, This will begin displaying captions on the screen if the movie,program support it,
Thanks for using Fixya.
Apr 28, 2009 | Sylvania 6842THG 42 in. Plasma HDTV
Sylvania 42" flat screen won't turn on
Jan 17, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Menu screen won't go away but i have sound
I am having the same problem too~ The menu screen keeps coming up!
Aug 24, 2008 | Philips 42PF9630A 42 in. Plasma Television
Blank area on both sides of screen
If you have it hooked up to a cable box, then you should be abl to change the resolution setting through the cable box remote control, if not call your cable provider to access the menu that does the resolution settings
Mar 02, 2007 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Sylvania SRPD442 no picture
Your problem is probably in the power supply as theres a voltage called the sustain voltage that is always keeping the screen charged so the address lines will activate the screen and make it light up Via the Microprocessor and the video processor. This is not a repair for a handy person as this set, you can cause more problems Please seek out a trained tech for this set. Good luck
Jul 24, 2006 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Televison & Video Logo
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
