Question about Yes Televison & Video
I have a Visio flat screen tv, the screen turned green and does not show a picture anymore. Is it fixable? And if yes what might it be and what might it cost?
SOURCE:
SOURCE: Visio TV and Direct TV remote
I bought a 42" Visio LCD from Costco and used code 10030 and it worked. It is the code for Goldstar TV.
Posted on Sep 20, 2008
SOURCE: Blue screen - no signal - turns off [visio tv L42hdtv10a]
With out turning on the T.V., Push the [Input] button on the remote control. The TV should turn on and activate the input menu, just continue to push [Input] until it is set on TV (or HDMI, etc.). this should solve your problem.
Posted on Nov 03, 2008
  • 71 Answers
SOURCE: sanyo 42" flat screen tv green light comes on but no picture
oops u r in trouble.
Posted on Mar 05, 2009
SOURCE: I have no picture, only green screen and audio when I turn on
i have no picture the sceen is green but i have sound can u help thanks.
Posted on Aug 26, 2009
  • 8 Answers
SOURCE: magnavox 37" flat screen model no.37mf23id/37
Yes, he means 2200 microfarret (called uf from here on out). Another important concern when buying a replacement is the voltage. You need to get something that is at least 25v. I recommend a 35v or better. Another notable point is that this may not always fix the problem. As with mine, there was also a 1200uf (microfarret) 35v capacitor that was blown. You can tell this because they bulge at the top. I have both of these caps (2200uf 35v and 1200uf 35v) on order and they will be here tomorrow. If I do not post back here then they fixed the issue for me. I suspect that this will resolve the problem. Look for bulges on top of the caps. This is an indication that they are blown. Most all of you experiancing these symptoms will see the 2200uf cap bulging but you may also see others bulging too. If you do then you need to replace those too. No electrolitic capacitor should be bulging at the top so if its bulging its bad, and if its bad then your tv will definitely not work. Have fun.
Posted on Oct 13, 2009
Vizio tv
Many Visio tv's have the same problem, and also reversed - picture and no sound. The quick fix is to disconnect the power cord at TV - then hold in the power button (usually found on left side 1/4 up from bottom of screen , located on the side/back of the set. a square button all alone) - hold power button in for 30 1,000 mississippi's, yes, that is what a Visio tech told me and it works. I was lucky enough to have the problem start before the 30 return policy ended at Walmart - decided I did not want a product that obviously has a chip failure coming soon! I exchanged for a Samsung and have not looked back!
Jul 19, 2014 | Vizio 42 in. LCD TV
Visio 1080p screen went light
Our Visio 42" flat screen TV did the same thing. It didn't happen that often but sometimes it would go darker or the sound would go off until I changed the channel or turned TV Off then back On. I contacted Visio through my warranty and they sent me a flash drive to install info on my TV. Did not fix the problems. A year later before warranty ended I contacted Visio again. They sent a huge box for me to pack my TV in to send to the warehouse where they fix everything. It took about 2 wks. to get it back. Worked fine for about 4 months and the problems continued. I will not buy another Visio TV. I found out that they had many problems with several models.
May 03, 2014 | Televison & Video
Visio M601D-A3. When turned on no picture just red,green,and blue vertical stripes. Audio is ok
Sounds like a panel fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Screen-shots to defective panels are shown. You can compare it to that of your TV's and can make sure about the fault.
Mar 15, 2014 | HP Televison & Video
Our 42" visio flat screen, bought in 2007, is
Hi:
Yes this can be fixed, it is probably caused by a some faulty capacitors either on the power supply board or the inverter board. Have a technician come out and check the capacitors in both of these circuits.
Sep 08, 2011 | Vizio 42 in. LCD TV
Hi, recently my flat screen tv screen turned a solid green.. i tried to turn the tv on and off and tried adjusting the wires but it hasnt seemed to work.. it does show a picture when i play a dvd tho. what...
The picture turns green if the component input cables are not connected in. Can you confirm that it is what you are using when you get the green picture? If yes can you please clarify the connection sequence of the RBG cables and the repective ports like Yb, Pb,Pr?
Apr 17, 2011 | Panasonic 50 in. Plasma TV
Red lines across screen
had tv that did the same thing after three years but they were green cost me 300 bucks to get it fixed and the guy said every 3 to 5 expect it
Jul 03, 2009 | Sony KP-51WS500 51" Rear Projection...
Jun 06, 2009 | Polaroid FLM-2011 Television
Visio LCD TV - Partial Picture blacked.
Hello! I have a 32" Vizio LCD...within 30 minutes of the tv being turned on, black lines start running through the bottom half of the screen and eventually blacking out the bottom half of the tv screen. It also doesn't have anything to do with the ratio as I have tried that. HELP!
Jan 06, 2009 | Toshiba 42HP66 42 in. LCD Television
Nov 17, 2007 | Televison & Video
Televison & Video Logo
Top Yes Televison & Video Experts
Marvin
Marvin
NOEL
NOEL
ray gallant
ray gallant
Are you a Yes Televison and Video Expert? Answer questions, earn points and help others
