Question about Maytag Washing Machines
Maytag se1000 not draining - Maytag Washing Machines
5 Suggested Answers
FixinFax
  • 3085 Answers
SOURCE: maytag Se1000 can the waqsher be used with out
Yes, it is a 110 volt AC washer.
Posted on Nov 06, 2009
heatman101
  • 43501 Answers
SOURCE: Maytag SE1000 Series 07 dryer wont heat
You need to have 220-240 or so volta ACROSS the two terminals on the element...the 125 can feed across and can be the same leg on both sides...
Check out this tip also..
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Apr 23, 2010
ftw1952
  • 10319 Answers
SOURCE: I have a maytag
The L stands for a faulty level sensor that needs to be replaced
Posted on Nov 11, 2010
  • 679 Answers
SOURCE: Maytag SE1000 washer error code IE will not drain
Symptom Causes Test procedure Solution
1E persists in washer display Lid lock switch With the lid open check for no continuity across the lid lock switch Replace lid lock switch
Posted on Jan 11, 2011
Maytag se1000 Series 01
this will be a timer fault most likely. if you can test for voltage at the valves while the machine should be filling you can tell if the timer is sending power to the valves.
Dec 06, 2013 | Washing Machines
Maytag dryer se1000 runs for 15 minutes then shuts off
Clean your sensors if you have them. They might have junk on them that could be forming a moisture barrier preventing the sensors from feeling the wetness of them clothes. The dryer may think them clothes is dry because it cannot sense wetness.
Oct 05, 2012 | Dryers
Maytag se1000 washer has no plug in wire. How do I make sure that a new plug is wired correctly?
on the back washer plate there should be a wiring diagram this will show the connections. Hope this helped tim
Aug 28, 2010 | Dryers
heatman101
Apr 22, 2010 | Dryers
Maytag dryer drum not turning - suspect belt - don't know how to get to it.
take the back off the dryer, take the back support rod loose, that's the thing that hold the back of the drum up. Then slide the belt back over the drum, the belt rides right in the middle of the drum motor should be in the bottom right hand corner.
Jul 04, 2009 | Boss AUDIO SYSTEMS SE1000 Car Audio...
Maytag haevy duty stack washer dryer unit model # SE1000 series 06
I hope you got this fixed by now but if not I'll put in my 2 cents.. I assume that your dryer is electric and not gas. Assuming that is true then you probably have an open heater element.. similar to this used in electric stoves... There may also be other components that could have failed and in so doing, disabled power to that element. Could be a contactor or temp switch/thermistor.. Hope this helps and that you've already solved the problem...
Jul 05, 2008 | Maytag LSE7806A Top Load Stacked...
sounds like the brake is not engaging properly(locks the tub for agitiation) wouldn't say transmission just yet, don't know the age but probably a few hundred dollar repair, i would recommend a maytag guy to do the repair, requires special brake tools and such,
Mar 06, 2008 | Washing Machines
Washing Machines Logo
27 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
