Question about Cell Phones
How to add iPhone phone book - Cell Phones
How to put the ice
How to Add ICE to Your Cell Phone: 10 Steps (with Pictures)
www.wikihow.com > ... > Phones and Gadgets > Cell Phones
wikiHowAdding an ICE ("In Case of Emergency") contact to your phone can help emergency personnel can locate a friend or family member who can speak on your behalf if you become unconscious or incapacitated. ... Part 1 of 2: Adding ICE to Your Cell Phone. ... Open the address book or contacts ...
How To Set Up An ICE Contact On Your iPhone ' The ...
https://rnn10.wordpress.com/.../how-to-set-up-an-ice-contact-on-your-ip...
Jun 21, 2010 - To access this information even when the iPhone is passcode locked, press and hold down the main key to access Siri, ask Siri 'Contacts ICE' Siri will then display all the information you have saved... 6. Remember this technique on an iPhone 4s as you may now access someone elses ICE if they are in your need...
How to Add ICE (In Case of Emergency) Contacts for iPhone .
Dec 27, 2015 | Sunbeam Microwave High Voltage Transformer
How to transfer Kindle library from iPad to my MacBook Pro
When you register your Kindle app on your MacBook Pro with Amazon, all your books should appear in your library.
Feb 24, 2015 | Apple MacBook Pro Laptop Computer with...
How do I add iphone to kindle account
make sure you register your iphone with your kindle account. click settings and then under the registration section ensure its registered to the correct account.
Jul 29, 2014 | Apple iPhone Smartphone
I cant add or save any numbers in my contacts book on my iphone 4 since installing ios6
Do this:
http://osxdaily.com/2012/02/24/transfer-contacts-to-iphone-without-itunes/
Mar 29, 2013 | Apple iPhone4 4G iPhone 4
Ibooks sync problem
uncheck the sync books box in itunes. Then try to add them manually, if this does not work try the sync again after you have uncheck the box and applied the setting.
Jun 16, 2012 | Apple iBooks
Phone number backup
You can do it via following steps.1.Update iTunes to the latest version if you have not updated recently. To find out if you need to update, launch iTunes and click "File" followed by "Check for updates." If you are on a Mac, click "iTunes" followed by "Check for updates." If you do not have the latest version installed, a dialog box will appear asking you if you want to download the latest version. Click the "Download iTunes" button.
2.Connect your iPhone to your computer using the USB cable that came with your iPhone. iTunes will automatically recognize your iPhone and an icon will appear in the left-hand column of iTunes.
3.Click the iPhone icon and the "Summary" pane will appear.
4.Click the "Contacts" tab located across the top of iTunes.
5.Click the check box next to the "Sync contacts with" field.
6.Click the drop-down menu in the "Sync contacts with" field and select a program to sync your contacts with. If you are on a Windows machine, you can choose from four options: Yahoo! address book, Windows address book, Google contacts, or Outlook. If you are on a Mac, your contacts will be synced with the Address Book utility.
7.Click the "Sync" button and all of the contacts on your iPhone will be saved to your computer's address book. Included in every contact will be the contact's phone number. Subsequent syncing will add any new contacts you have entered manually on your iPhone. Hope it can help you.
Oct 25, 2011 | Apple iPhone Smartphone
How can I transfer ebooks from computer to iphone 3Gs through cable.
open itunes click edit>preferences> enable books>make sure iphone is connected and drag ebooks to iphone.
make sure to select manual syncing by clicking on the device first.
if the ebook is not in the library or has not been downloaded via itunes then you must go to file>add file to library/add folder to library. select from the location on your computer where ebook has been saved and then click ok. it should now be under books itunes.
May 31, 2011 | Cell Phones
Copy contacts from iphone to sim card
You can manually add your contacts by enetering your sim card, by going to Setting, phone, SIM applications, and enter the phone book...
There is no command to copy the contacts directly to your SIM.
Use Microsoft Outlook to copy your contacts to the pc... keeping it safe, backed up
Oct 14, 2009 | Apple iPhone 3G
Sms/phone book crash
Its because you are using an iphone in a different country.
Go to your installer and add this source installer.iclarified.com
Then install appsupport for 1.1.2
Once installed, reboot your iphone and the conacts will automatically match up with your texts and call records.
If your ihpone is not jailbroken or you dont want to install anything, you can just cahnge the phone numbers to the full international code eg instead of 0414141414 in australia you would put +61414141414
That will fix your problem
Jan 18, 2008 | Apple iPhone Smartphone
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
