Question about Fisher and Paykel Washing Machines
How do I remove front psanel of Fisher and Paykel WH7560J1 washing machine
  • 92 Answers
SOURCE: IW712- fisher paykel intuitive eco.
I BELIEVE THAT IS A ROTOR SENSOR ERROR
REPLACE THE ROTOR SENSOR
Posted on Feb 22, 2008
RescueTech
  • 145 Answers
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Posted on Apr 20, 2009
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
  • 3 Answers
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Posted on Feb 20, 2010
  • 3 Answers
SOURCE: Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
Front loading washing machine stuck on pause - won't restart
If your Fisher & Paykel Front loading washing machine stuck on pause, give us a call and we'll troubleshoot it over the phone or send a tech to diagnose it in no time. More info here : http://appliancerepair.biz/brands/fisher-paykel-appliance-repair/
Oct 17, 2014 | Fisher Paykel Fisher & Paykel Traditional...
How do I change the elbow nozzle on a Fisher & Paykel GWL11 washing machine?
two screws at top front under plastic plugs lift top front of machine up there is one screw that hold the washer sprayer in place once removed you can remove elbow
Jun 24, 2014 | Fisher and Paykel GWL11 Top Load Washer
How to remove pump MW512 Fisher and Paykel Washer
Disconnect from power & Bail out all the water you can before removing pump.
Jul 15, 2012 | Fisher and Paykel Washing Machines
Fisher and paykel washing machine becomes
i think that 1 or more suspension rods r faulty. lift the lid and at the front of the machine u will see 2 plastic covers, remove the covers and undo the screws underneath. now lift the front of the hob up gently and u will see the suspension rods. they r easliy replaced. but first see if they havent just popped out. if they have just popped out look at the other 3 and refit to how the others are.if u need more help or u find another problem reply back and i will help u more.good luck
Apr 20, 2010 | Fisher and Paykel WA37T26G Top Load Washer
Fisher and paykel washing machine will not spin
Most likely something stuck in the pump, you need to look underneath to get to it, the pump turns anti clockwise to remove it.
Apr 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel intuitive washing machine not spinning
the pump could have overheated nd burnt out or u could have damaged the controller
Jan 28, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Which wire go where for F&P out of bamace sensor
white to the front of switch
yellow to the side
Hope thats clear Pieman
Jun 28, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Cleaning washing machine
pull dispenser up and off lossen large plastic wing nut in bottom of agitator throat lift agitator off if you wish to remove basket pull plugs out front corners of top remove phillips screws lift top up remove agitator as described remove ring on top of basket it just snaps off lift basket straight up
Jun 13, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
35 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
