Monitor heater M2400 gave E15 error code then would not power on at all after a power surge. We checked the fuses and 1 out of 2 fuses were blown so we replaced but it still will not power on?
  • 6966 Answers
SOURCE: fuse blown repeatedly on CB553H-KL
Re your post/description on an LG CB553H-KL fuse blowing, this is indicative of an over current (>5Amps) flowing through the AC mains supply. If you are comfortable doing component level repair and familiar with electronic parts/circuitry, continuity tester and a soldering iron, please do passive (off-board) test of the following components:
D900 - bridge diode;
C908 (150uF/400V) - filter/power capacitor;
Q901 - regulator.
If Q 901 is shorted, pls likewise check ZD901, D910, R902 & 915.
Just to be sure/safe, check also:
C901, 902 & 904;
TH 901 & 902;
Though unlikely, you may want to check also:
Q706 - Horizontal out transistor (attached to the aluminum wall acting as heatsink;
FBT - Flyback transformer.
Other than the component aforementioned, no other parts would cause enough current flow to blow the fuse. But of course, anything can still be wrong
Hope this be of some help. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Nov 16, 2007
SOURCE: fuse blown
Ours is 3 years old, no longer under warrenty and we just had the same problem. I bought a package of four fuses for $2.99 at Radio Shack. As the man mentioned earlier, follow the power cord to the fuse...very easy to find. Easy fix and saved a $100 service call. TV is working great.
Posted on May 01, 2008
SOURCE: kyocera fs-3820 no power
You don't have to replace the fuser. You can fix it by taking the fuser apart & repairing the thermostat. This is located under the fuser roller. Take the thermostat apart & bend the metal plate on top just a little, then put everything back together. This works prefectly & will save you money. The heat from the roller makes the metal on the thermostat bend & releases the contact on the inside.
Posted on Sep 03, 2009
  • 14036 Answers
SOURCE: Heater blower on 2004 Sebring
Posted on Nov 08, 2010
SOURCE: I have a bosch dishwash e15 check water
I found this solution on elsewhere on fixya. it relates to a little float switch designed to detect water leaks I think. 1. turn off power and water 2. tilt back machine about 45% (have towels ready to soak up any spill off 3. when all the water has emptied, right machine and retry. if the problem keeps reoccurring, you may have a genuine water leak. I had to try a few times but this worked for me and saved me at least 4 days of hand washing over a long weekend. good luck
Posted on Oct 27, 2011
Blown 24v Slow Blow Fuse
Scott, I have the exact same problem. What ended up fixing this? Thanks! - Paul
May 10, 2013 | Honeywell Triangle Tube Prestige Solo 110...
If your dryer works but no heat
whirlpool,kenmore,roper,kitchenaid,inglis,if your dryer works but no heat most of the time it is a blown fuse,or bad heating coil,cause of a blown fuse can be power surge,clogged wall vent,clogged dryer lint vent box,unplug,remove back cover,look to your right and you will see the heater box,look on the left side near the top and you will see a small fuse,this is your heater box fuse,if not the fuse,the heating coil is near the bottom,1 screw on each side,remove and look for broken wire,if you have a meter,you can check the fuse and heater coil-mike
on Feb 11, 2010 | Dryers
My monitor doesn't go on anymore. Las night I had a pop-up appearing on the screen. I closed my computer and started over again. I'm sure I didn't turn off my monitor. Everything went well until this...
First, check to make sure the power cable is plugged properly in the back of the monitor and into the surge protector. You can try a different power outlet, but if you're still having the same problem and the light isn't turning on, it's likely you've either blown the fuse inside the monitor, or you had a power surge and blown something inside the monitor. This happens when you don't use a surge protector and just plug the monitor into the wall.
That said, if the above doesn't work then you have a hardware problem with your monitor and it needs to be serviced.
Jan 11, 2011 | Computers & Internet
What does open heat error mean?
It means that the fuser cannot reach the operating temperature .
Probable causes for this are blown fuses or open thermal cutouts or an open heater.Reasons for this are usualy an overheat contition or a power surge.
May 16, 2010 | Office Equipment & Supplies
Blown fuse on a ilpi-009 power supply
hi, i don't know the exact power board you speak of, most fuses for power supply protect ac inboard power, and backlights. if backlight inverters touch ground or ground out, this will blow fuse. otherwise, the fused circuit is used for main inboard power going to primary capacitor. take an automotive fuse holder and solder test leads long enough to work with, install 4 amp blade fuse and jumper/solder the circuit to the fuse on the board and power on the monitor. if all goes well, probably just power surge or outlet grounded. if blows fuse, check to board for obvious burns or blown capacitors. if not there, unplug backlights and power on, if still blows, check to make sure no direct conact with board and back of screen. just be thorough about looking carefully for shorts if there is one. and don't forget to replace the factory fuse on the board with the correct one after you finish repairing, don't leave that automotive fuse in. good luck.
May 10, 2010 | Emprex LM2201 22" LCD Monitor
Got a new surge protector/power strip. I
Please try the monitor without the surge protector to ensure there are no isues with the protector
If the monitor comes on you know its the protector, if it still fails then i recommned the following
1) ensure the fuse in the plug is ok and not blown
2) Change the 3 pin power socket for another one
If after this all fails then for some reason something has blown in your monitor and you will need to book it in for further inspection
If this has been useful please leave positive feedback/vote/testimonial as this will help me greatly - Thank You again
Feb 12, 2010 | Samsung SyncMaster 731B 17" LCD Monitor
Monitor heater model 2400 is giving a e 15 trouble code what does this mean ??? found that may have to do with low voltage but nothing has changed and it has worked fine for years ????????
The e15 code could also be a control board issue.
The power detector may have been damaged due to years of brownouts and surges.
Also, if you have added anything to the same circuit that the Monitor is plugged into; it is also possible that that is causing the low voltage code.
Unfortunately, it's hard to say without checking alot of different things.
If you have a place locally that services Monitors, it may be a good idea to take it in for service.
Sorry I can't be more help.
_Helping Hands Services_
- Fairbanks, Alaska -
Oct 28, 2009 | Heating & Cooling
Soyo 17'' Monitor (DYLM017A)(VT17N71), identity of fuse.
Orange color of the ring means number 3. Part of marking also contains "3A" so I'm pretty much sure it is 3 Amps rated fuse. But before replacing it measure the resistance on the PCB where that fuse was blown, between common mask (usually metalized mounting holes are connected to it) and the second pad of that fuse. How much is there? If you measure less than 12/3=4 Ohm the new fuse will blow again and you need to find what is shorting the power supply.
Sep 12, 2009 | Computers & Internet
Monitor just went off. no power light. changed fuse but monitor is completely dead
possibly a power surge killed the main board in the LCD. if the fuse was blown i would suspect a power surge. you could replace the circuit board. either that died or the power supply died- depending on if it has internal or external power supply that might be blown as well.
i would take it to a professional LCD/ LAPTOP repair person. they should be-able to test it and let you know what needs to be replaced
Aug 06, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Power Surge problem
First thing to try is unplugging power cord for five minutes, to see if it clears.
When it is the fuse the unit does not start at all (no light), try the unplugging, open all doors and close them back, after power surge some of the sensor can be stuck on error message.
If it does not clear the error you need to call a technician. He will connect a computer with code reader to the copier to diagnose the problem, in case of internal error.
Aug 13, 2008 | Office Equipment & Supplies
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
