NS-50D550NA15 FIRMWARE LOOKING FOR FIRMWARE
3 Suggested Answers
SOURCE: Does exist update of firmware for C
Unfortunately this update doesn't exist. T
Posted on May 15, 2009
gopakumarg43
  • 74887 Answers
SOURCE: Insignia TV picture not working but sound is. Flashlight test picture so assumed backlights. Replaced the board for the lights but is still not working. Model ns-50d550na15 part numbers 170452 172770.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Aug 07, 2016
My Insignia NS-50D550NA15 LCD has no picture but sound what might be the problem
Any one of the TV's circuit boards may be at fault here, a repair manual and testing are needed to figure out which circuit board is at fault.
Jul 06, 2017 | Insignia Televison & Video
Aug 06, 2016 | Insignia Televison & Video
How can I get a manual for NS-40D510NA15
Insignia has the manuals for most of their products on the product page. Click on the Support/Downloads tab. For the NS-40D510NA15, see http://www.insigniaproducts.com/products/televisions/NS-40D510NA15.html . The direct link to the User's Guide (as a PDF) is http://www.insigniaproducts.com/cms/documents/manuals/NS-40D510NA15_14-1088_WEB_V3_ENG_Final_lr.pdf . There is additional documentation available and there is an HTML version of the user's guide as well.
I hope this helps.
Feb 01, 2016 | Insignia Solutions Original INSIGNIA TV...
On the Insignia TV remote, how do I get back to being able to choose channels with Direct TV remote?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code
Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
Nov 28, 2015 | Insignia Solutions Original INSIGNIA TV...
Led power light comes on but screen will not come on.
"Blinks a few times" implies the TV is flashing a fault code at you. If you can find a service manual for your model, count the number of blinks and look it up in the diagnostics section.
However, the most likely problem is a burned-out electrolytic capacitor in the power supply. These are usually easy to identify visually; the top of the can-shaped capacitor should be flat, but may be bulged out and may have brown or black material leaking from the vent scores. The photo below shows a bad capacitor to the right of a good one; both have black plastic sleeves.
If this is the case, replacement capacitors are relatively cheap. However, you should look for the following criteria in choosing a new part:
>Capacitance (uF): same as the original, or 10% higher if the original value is not available
>Voltage: same or higher
>Temperature: Maximum temperature should be same or higher
>Physical size: should fit in the space occupied by the original; if buying a taller unit, make sure it will fit when the back cover is reinstalled, and make sure the capacitor will not touch heat generating parts such as heat sinks, resistors or large transistors.
>Ripple current: get the highest available without compromising too much on endurance. Ripple current may be specified in mA or A; 1 A = 1000 mA. Sometimes you can get a better rating by going to a higher voltage part, but physical size may be a limitation.
>Endurance: Try to get 8000 hours or better.
I usually use Panasonic FR1 series capacitors, although United Chemi-Con EKZN capacitors are also worth a look. 25351068-tkog3zu3xmxabptjkcidpctj-1-0.jpeg
Jan 02, 2015 | Insignia Solutions Original INSIGNIA TV...
Need to download driver
The picture of the player that is showed in the problem shouting has type number NS-DV2GC, see the overview:
http://insigniaproducts.com/productSearch.html?query=NSDV2G&mainSearchButton=Search
No driver available for the NS-DV2GC.
On the mentioned page there's also the NS-DV2G player.
Firmware for the player:
Firmware available starting with NS...
Firmware updater FWUpdater...;
Software for the computer to make media transfers:
RhapsodyBestbuy... version 3 and 4
USB installer for older versions of Windows
nusb31e...
Quick Start Guide in pdf format:
http://insigniaproducts.com/cms/documents/NS-DV2G%20UM%20EN.pdf
User Guide in pdf format:
http://insigniaproducts.com/cms/documents/NS-DV2G%20UM%20EN_SP_FR.pdf
Nov 02, 2009 | Insignia NS-DV2G MP3 Player
May 12, 2009 | Sony DVP-NS430 DVD Player
Computers & Internet Logo
114 people viewed this question
David Payne
David Payne
