Question about Garden
We have a international tractor w6 and can't find where the oil dipstick is located
5 Suggested Answers
SOURCE: location of oil dipstick
The oil dipstick is located at the back of the engine.  If you look at the engine from a top view it is located at about 11 o'clock.  It's black.
Posted on Dec 22, 2008
  • 53 Answers
SOURCE: Where is the oil dipstick located in a 2006 Chevy HHR???
go to http://www.extendedgmwarranty.com/owners-manual/chevrolet/2006-Chevrolet-HHR.pdf if you have adobe reader you will see a picture in pdf format. look at the letter F on the picture. that is where your dipstick is located. now go to your car and look for it by following this picture. good luck
Posted on Jul 08, 2009
tartantyger
  • 73 Answers
SOURCE: location of oil dipstick...
There is no dipstick on a Royal Star. To check the oil level, look for a glass window on the right side of the crankcase marked for high (max) and low (min) levels. Get on hands and knees and look under the front crankcase cover directly beside the right operator's footrest; you'll probably need a flashlight to read it.
Posted on Aug 07, 2010
DIESELMUDDER
  • 2760 Answers
SOURCE: Dipstick or sight gauge location on Kubota Tractor/Backhoe TL421 needed. Changing fluids and cannot locate the level gauge.
motor oil stick is if sitting in seat facing forward , its on right side , just by your right ankle , in a little offset in the block ( loop handle sticks out by right ankle) hydraulic oil level is a sight gauge (glass) they do get covered up with grime over time and need to be wiped off to see them !!! me I look down fill tube with light and measure three inches off tank top (heat expansion room)
Posted on Oct 12, 2016
Oct 12, 2016 | Kubota Garden
Don't know how to read the hydraulic dipstick for a 1944 ford 2n tractor
Ford Tractor Hydraulic System - My Ford Tractors
www.myfordtractors.com/hydraulics.shtml
All N-Series Tractors - Ford-Ferguson 9N, 2N, and Ford 8N ... 6 - How long has it been since you changed the hydraulic fluid? ... If that didn't do it, read on. ... then remove the bottom bolt from the inspection plate that has the hydraulic dip-stick.
Yesterday's Tractors - Fifty Tips for Ford 9N, 2N and 8N ...
www.yesterdaystractors.com/articles/artint268.htm
I'd like to say that the reason I have an 8N Ford tractor is because that's the tractor ... The N tractors have a common sump for the rear end, hydraulic pump andtransmission. ... (Read the label.) .... Take the inspection plate with the dipstick off.
Ford 8N, 9N, 2N, NAA Tractors Information - SSB Tractor ...
www.ssbtractor.com/wwwboard/messages15/
Helpful information and resources on Ford 8N, 9N, 2N, NAA tractors from SSB Tractor, a leading provider of tractor parts, manuals, implements ... 1944 ford 2n: What type of oil to use? and whats the oil pressure should be? ...... N Series Trans/Hydro Fluid - Interesting To Read ... Ford NAA/Jubilee Hydraulic dipstick location?
Jan 01, 2016 | Ford Cars & Trucks
Craftsman lts1500 engine problem.
resecure the dipstick tube fill with oil and restart motor and observe tube at seat for any leaks and listen to motor making sure no internal damage was done if no issues your good to go
Apr 16, 2017 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a briggs 10 hp 392 cc industrial engine in my 67' simplicity landlord garden tractor. The dipstick was replaced with a plain oil plug so there is no way for me to check the oil level. I need to know...
Are you sure the dipstick was replaced with a plug? In most engines of this size, there is no dipstick. There is a plastic oil plug sticking up at a 45 degree angle from the crankcase. You unscrew it to check the oil - you can put your 5th finger in there to see if the oil is up to the lower rim of the hole - and you also add oil through the same opening. Draining the oil is done through a different, usually metal plug, lower down on the crankcase. Hope this helps you!
Jun 07, 2010 | Briggs & Stratton Garden
Need to locate the oil pressure sending unit on a John Deere 1010 Gasoline tractor
looking at engine on oil filter side--the sender is on the left side of oil filter and to the right of dipstick in between both
Mar 03, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Where is the oil filter located on the Husqvarna Lawn Tractor, Model YTH2348
if its a 23 hp briggs and stratton it should be on the opposite side from the dipstick where you check the oil down low.
It may be black with a briggs and stratton label or it may be yellow with the same.
Jun 05, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Missing oil dipstick
Hello:
You can Purchase a New Dipstick from your Local Small Engine Service Center or Online.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Checking fluids
look for a tank reservoir with a dipstick. Locate the pump or cylinder and follow the line back to the tank.
Dec 22, 2008 | Ertl International Harvester Farmall Super...
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
