Cant ise remote ethwr - Computers & Internet
Are there Linux drivers for the Spartan-6 / OMAP Co-processing kit? In general is there linux support for this board, i.e. linux versions of CCS and ISE available?
The CP2102 drivers are already integrated into most kernels. We've worked with Ubuntu 10.4 with no problems. See the Getting Started Guide on the site:
http://www.hqew.net/product-data/CP2102
Not sure of ISE, but I know that CCS4.xx does not work on Linux hosts. Versions of CCS5.x will support both Linux and Windows hosts.
We have been working on systems using virtual machines for the Linux development side, and Windows for the CCS/ISE side of development. Not the happiest of scenarios, but it works. CCSv5 on Linux will help solve a lot of those problems.
Dec 24, 2012 | Office Equipment & Supplies
My phone is in headset mode model 1112?
to gand main le lo ise sale kuch bata to sahi ise hoa kya hai>>>>>>>>>>>>
Jul 19, 2011 | Nokia 1112 Cellular Phone
Insinkerator works but doesn't drain
A clog in the ISE. UNPLUG and look inside the top via the sink. If possible, run a small cleaning snake into the ISE drain and do what you can to clear the drain.
Count your sponges, etc to see if anything might have ended up in the ISE by mistake.
Oct 01, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Leaking water.
If you can not see any "obvious" holes in the body of the ISE, the connections to the sink or the drain connection(s) are suspect. Take a flashlight and look the ISE over good, paying special attention where the drain pipe is connected. If you see any signs of water, tighten the connections but be sure NOT to cause the ISE to be pulled to the side, it must hang straight down from the sink. Also check the basket that is fastened to the sink as well as the heavy metal ring washer that suspends the ISE below the sink. If you see signs of leaking water, you may have to change the washers.
Sep 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Cant program my emerson flay screen tv wiyh dish
Hi tbombertigermy name is Mike Houston of DISH Network and I was going over your post and Isee where your Emerson TV needs to be programmed to your DISH Network remote. Ihave the codes 569, 632, 505, 516 and 004. What you will want to do is holddown the clear TV button for 6 seconds and then press in the three digit codeand the # button. If these keys don't work we do have a step called Power Scanand I will send the link to help with the setup. http://www.dishnetwork.com/SupportSection/power-scan-instructions
Jan 06, 2010 | DISH Network IR Remote Control
Camera not work
when I open the camera .isee this massage( busy.try again later)
my phone is motorola v3x
Jan 21, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Computer Noises....
happens with a mixed ground issue. I had same thing with my laptop. only way to avert this is to super ground your digital sound devices...and connect them to ground/chassis of the desktop, if that's your option.
used to be called 60 cycle hum in olden days.
check your computers warranty here 4 FREE
Mar 09, 2008 | Lexicon Omega Desktop Recording Studio...
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
