Question about Garden
Craftsmen pressure washer won't start 8.5 2800
5 Suggested Answers
  • 124 Answers
SOURCE: I have a Craftsmen 1800 PSI Electric Pressure
Without more information than you have provided, I would think that yoour motor has been damaged by over use or by using too small an electric cord or too long a cord. The overload which is most likely a thermal overload is getting too hot.
Posted on Sep 15, 2009
wireguy212
  • 1627 Answers
SOURCE: pressure washer
You may want to remove the pump from the motor and chec the bolts for tightness.If nothing is loose then you need to purchase a repair kit which should include new o rings,pressure valves and springs as well as any gaskets you will need.The instructions should give you detailed info as to how to install everything.
Posted on Jun 07, 2010
kevin_getz
  • 1031 Answers
SOURCE: Craftsmen 917289233 won't start
How is the quality of the fuel? Was the spark plug replaced? If so, was the gap set correctly? (0.30)
Posted on May 21, 2012
  • 6468 Answers
SOURCE: craftsmen, power washer, 2800 psi, won't start when hot.
when it cuts out check for spark the coil might be bad
Posted on Jun 25, 2012
Won't start
Are you saying that it WONT start or that you cannot pull the rope to get it to start?
May 15, 2013 | Dewalt 3800 PSI Pressure Washer
Craftsman 2400psi 6.0hp briggs & stratton pressure washer won't start
try and start it with starting fluid if so rebuild the carb
Aug 07, 2012 | Garden
May 20, 2012 | Craftsman Garden
Pressure washer won't start. It has gas, oil and I turned the switch to turtle and to rabbit position. Does it matter if water is on first or not? It won't start either way.
Turn the water on, hold trigger down and let water run thru the hose to prime the air out of the hose. If it still will not start check the spark plug and clean it or replace it. A bad spark plug will keep it from starting
Aug 22, 2011 | Briggs Stratton 020273 Elite Series...
Pressure washer
Jun 07, 2010 | Garden
I have a Craftsmen 1800 PSI Electric Pressure Washer, Model 580.752020 and it keeps tripping.
Sep 14, 2009 | Garden
New Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Aug 31, 2009 | Karcher 2500 PSI Pressure Washer
Our craftsmen electric pressure washer stopped working while in use. We have power - red light on gfci and we tested the master switch - has power too. So what can be the problem? One post mentioned a...
The pump switch they spoke of is an internal switch. It is activated by a valve so that when you let go of the trigger, the machine shuts off. This valve is stuck or the switch is bad. Usually the valve is the problem. I would go to Sears and get it looked at
Aug 24, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
