Question about Pentair Pool & Spa
I have a Pentair 7 186237-01 pool pump. the capacitor was replaced 1 year ago. it is acting like the capacitor has failed again. did they put on the wrong capacitor?
    Top Expert:
  • Pentair Master
  • 51,255 Answers
No
capacitors either work or they don't work
being electronic and subject to surges and spikes they can last many years or just months
there are various qualities of capacitors but even that is no guarantee of long life
you can check if the capacitor is correct by getting oll of the details off the plate on the motor( volts, current , rpms , hertz-phase , cycles etc and with that information take the failed capacitor to an electric motor repair shop and they will know if it was correct or not
the requirements are correct voltage and mica/peka farads required to start/run the motor
there is a permissible range but outside that range , the capacitor is wrong
Posted on Apr 17, 2017
    Top Expert:
  • Pentair Master
  • 45,079 Answers
The replacement could have been the wrong value or something that was lying around. It important to use the correct value to adjust power factor and prevent pump overheating and slow starting.
My Pentair pump is just 2 years old and it was working good yesterday I turned off I turned it on in now it humms for a minute or 2 then it just turns off completely how do I fix this
motors that hum indicate 2 things
seized pump or failed start /run capacitor
as it was running recently I would be checking the capacitor
the stopping altogether may be the thermal overload switch cutting in because of the high current draw from the failed capacitor
Jun 05, 2016 | Pentair 2.0 Hp Whisperflo Pump
Pentair Intelliflo vs. Need bearing replacement for front and back bearings
Pentair WhisperFlo Pool Pump Motor Bearings Replaced ...
? 2:03
www.youtube.com/watch?v=qYRNMCh_7kM
Jul 10, 2012 - Uploaded by Pump Repair Supply
More Help & Information: https://pumprepairsupply.com Watch as Joseph shows you how quite your Pentair
Sep 27, 2015 | Pool & Spa
Turned off breaker and pump will not come back on. Not start capacitor
might be a bad breaker, test power at motor you should have about 220v on the line 1 and 2 terminals if the motor is set to run on, there is a daigram on the side of the motor for refrance
Jan 07, 2015 | Pentair 011773 WhisperFlo WF-26 High...
Pentair Whisperflo 1.5 hp motor will only turn with help. Can it be fixed?
maybe bad start up capacitor remove match and replace or replace pump motor or pump
Sep 02, 2012 | Pentair Pool & Spa
Pump switching off for about 10 -20 seconds, then back on. Hapens about every hour
the little house on top of the motor has a capacitor in it 90% of the time thats whats wrong with this motor it's eather a 30 or a 35 mf .
pull this off the motor and search your area for pool pump motor repair, free testing ,use your zip code in the search, ask if they can test a capasitor for you.. wait to take capacitor off till the motor cools off
about a $20.00 fix
hey if'n i was of help vote..thanks ..jay
Aug 08, 2010 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
I HAVE A MAGNUM FORCE PUMP. iT WAS RUNNING THIS
It could be the capacitor again, but most likely if it stopped while running, its not that, unless you had a brief power failure. The motor may have a built in thermal overload which turned the pump off. If it only humms then it could either be locked up by something in the impller, or could be the bearings in the motor have failed. If the motor doesn't smell "burnt" then you might stand a change to disassemble the pump. Disassemble the motor and replace bearings. Replace the mechanical seal while you have it apart. OR you could buy a new motor, as it is 10 years old.
Jul 05, 2010 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
My challenger 3/4 pump has started to sound louder and louder.
Replace the motor bearings before they fail completely and ruin the motor.
Jun 07, 2009 | Pentair Challenger 3/4 Hp In Ground Pool...
Pool & Spa Logo
115 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
