Question about Kenmore Washing Machines
Kenmore 665.13593k600 starting to smell. i cannot locate a filter to clean!
Smell
Hello, In most cases when you have a burning smell a simple fix is your lint lines are dirty. A lot of time when your filter or your hose that goes out the back (by the wall) gets dirty it gets hot and starts to burn. There have been some cases where it will catch on fire, so always make sure lint filter and hoses are clean. Other forms of burning smell can be the dryer belt is waring out or loose, Kind of link when a vacuum cleaner belt gets worn and starts slipping and burning rubber smell. AND Finally could be the main barring that could be going out.
My advice start with simplest first, check vents and lint filter and go from there.
I hope this helps Mike.
Apr 07, 2012 | Kenmore Dryers
Washer smell
If this is a front loader, clean around the rubber "boot" inside the doorway between the front of machine and the drum by pulling out a little to reveal buildup behind it. This can get a funky smell. You can also run the "sanitary" cycle if your unit has one, with bleach, which will clean the tub better.
Jan 12, 2012 | Kenmore Washing Machines
Freezer area smells and ice cubes and butter taste off?
It sounds like the ice maker if equiped. Remove Ice bin and clean out,and try a lite spray of bleach or vinegar (don't mix) If the smell is still happening and comming from ice you may want to install a inline filter.
Jul 26, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
I was given a kenmore quei pack 2 washing machine.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
May 14, 2010 | Kenmore Elite 45986 Front Load Washer
Mildew smell in washer
there is a chemical you can get to help with the smell from SMELLYWASHER.com
Feb 19, 2010 | Kenmore 22942 Top Load Washer
Every time I start my Kenmore HE2t washer there is
If it has a clean cycle that says, "Bleach Only," run it with 1/2 cup bleach right in the machine. If not, run it on the longest, hottest cycle you have. In the future, leave the door open slightly between loads.
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
Rotten smell coming from water dispenser
change your water filter and clean all the lines for water,you must have an algae,mold buildup in there somewhere,and possibly water got into insulation and has startes to mold
Aug 27, 2009 | Kenmore 53632 / 53634 Side by Side...
Bad Smell
start your dishwasher with no dishes in it.
Let in run until it takes on water and start washing.
Then open the door and pour in 8 oz of white vinegar and let it finish the cycle.
If this does not correct the smell...purchase the AFFRESH product and use that.
Mar 12, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Elite front-load
you must remove bottom panel ,,in the center front you will find pump,,remove pump filter,,always unplug first..it has slugg,..than after you clean filter run your unit once a month with a pint of bleach and hot water only..also wipe your rubber gasket or bellows with a touch of bleach..
Dec 27, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
32 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
