Question about Radio Shack Radio Communications
I just changed the battery in my radio shack pocket lazer level and it still won't work. Now what?
5 Suggested Answers
Agent Ken
  • 250 Answers
SOURCE: Battery
Hello janin906,
The battery for this unit (like many MP3 players) does not appear to be end user replaceable. A quick websearch shows that there are several companies offering after market batteries and battery installation services. If you are comfortable repairing electronics devices you might be able to sucessfully replace the battery yourself. However repairing a modern electronic device should not be undertaken lightly. If you don't have experience working with electronics I would recommend contacting SanDisk to arrange battery replacement.
Best Regards
"Go Ahead. Use Us."
Posted on Jun 24, 2008
SD Tech
  • 14553 Answers
SOURCE: radio shack radio dx-392 will not power on
If a CB radio it is protected against the DC being hooked up backwards with a diode. If this has happened take a ohm meter and test from ground lead to the hot lead--if a short the diode is popped and has to be located and removed---with it out check to see if short still there---
Posted on Apr 09, 2012
SOURCE: I have a topcon RL50
aken from Pauldos Personal Laser Blog,
The Topcon RL-50B and RL-60B leveling lasers use a fairly unique compensator arrangement. Most leveling lasers use a suspended compensator arrangement, with a lens or mirror on the pendulum. The pendulum is usually metallic, and inside another metallic barrel, so that an electrical connection between the pendulum and outer barrel indicates to the electronics that the compensator is 'out of range'. The RL-50B/60B has a fluid compensator system where the laser beam is reflected off an interface between the fluid and a window, with the level of the fluid influencing the reflection angle of the laser beam. Because there is no electrical aspect to the compensator, an optical system is used to detect when the compensator is 'out of range'. In the output structure of the laser, a glass window at forty-five degrees is used to reflect a small portion of the beam to a photo detector. When the laser is level, the small portion of laser beam strikes the photo detector.
A common fault with these lasers is to constantly indicate 'out of level'. This occurs when there is insufficient beam intensity on the photo detector. The standard solution for this fault is to clean the 45 degree window. Sometimes, this does not bring the laser back to life. I have stripped down a couple of these lasers to try and figure out what is going on.
At first, I thought that maybe the laser diode could be down on power, reducing the available beam, but I quickly discounted that, because the laser diode output is feedback controlled, so the output power is stable up until the point of complete failure. One of the units I disassembled had cracks in the compensator housing, and the fluid level was low. I don't know whether the fluid leaked or evaporated, but in either case, there was no way the compensator could be repaired. In another unit, I noticed that the fluid was discoloured. Since I don't know what the composition of the fluid is, I don't know what could cause it to discolor. Perhaps extremes of heat or cold may damage the fluid. If the fluid is discolored, that may reduce the available laser power at the output. The question is, can we compensate for this? (pun not intended)
I decided to reverse-engineer the photo diode circuit, and see if there was any way to improve it. There is. The photo detector amplifier is a standard op-amp inverting amplifier. The feedback resistor, surface mount R23, is 470K. I changed this resistor to 680K to increase the gain of the amplifier, and bingo! the laser works like a real one again. Extensive testing in the workshop and in the field shows that the laser functions as originally designed in all ways. I have done this modification to over fifty of these lasers now, and the modification extends the life of the laser anywhere from a few months to a few years, with the average about one and a half to two years. Customers are always happy to not have to buy a new laser for another year or so, so this modification is always embraced when offered. I have never figured out what is going on with the fluid, but since I have a solution (again, pun not intended), I don't care.
cleaning instructions :
Remove the housing. Remove the battery holder. Loosen two small silver grub screws on the turret. Lift turret off. Clean slant window with acetone and a cotton bud. Avoid smearing the glue in the corners over the window. Flatten and curve a cotton bud to clean the inside of the slant window. Clean the folding mirror under the slant window. Replace the turret. Turret has a small amount of play, so align it for best operation before tightening grub screws. Re-fit battery holder and housing. All done!
Posted on Nov 30, 2012
  • 74999 Answers
SOURCE: Reprogram radio shack 2-in-one pocket remote 15-8926 for a citizen tv
Set-up procedure is too much to type in here, and is not practical. Will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
Posted on Feb 22, 2014
Pocket lazer level won't work
If the laser is ok then I would take a look at the battery connections. There may be some corrosion on them or the batteries may not be fitted correctly.
Apr 17, 2017 | Radio Communications
How do I charge my walkie talkie when the charger is only charging on one side
I don't know what model you have. Is it a two-pocket charger with one pocket that is not working? Or is it a single pocket charger only. The only solution I see is to give the radio battery a full charge when you are not using your radio at all. It will charge faster if you make sure your radio is turned off, of course. That's all I can tell you with the info given above.
Feb 14, 2015 | Radio Communications
The dial light does not come on, everything else works great. Paid 8 dollars for it at a thrift shop today. I like it. Also changed battery and nothing comes on with a new battery.
i bought a tiny 12 or 14 v bulb at ametron (similar ones a radio shack) made in taiwan and at radio shack found in the drawer section. i grafted it into the radio, following a post by another party-- and the dial lite lit up...sorry i no have more info as to bulb size but i am not real savvy in electronics, ...the bulb is about the size of a popcorn kernel and has two tiny wires coming out of it; it fits into a sleeve that is green in color; i think radio shack has a tiny green bulb which willl work as well (mine was white)
Sep 06, 2011 | Proton R5A Clock Radio
I have a Radio shack hand help police scanner, when I put the batteries in and turn it on, i just hear this low level static and some small clicking noise. The display finally came on for a few minutes but...
Take the scanner back to radio shack for an exchange. If you have had the radio too long then take the scanner back to radio shack and they will send it to their service center for repairs. Personnally I would upgrade to a digital scanner as things are getting ready to change nation wide. Most goverments will be upgrading to P25 digital to comply with the requirements of Homeland Security.
Jul 10, 2011 | Radio Shack Pro-95 Handheld Scanner
If you replace the batteries with rechargeable NIMH batteries, the scanner might not like them, because NIMH batteries each are 1.25 volts whereas regular alkaline batteries are 1.5 volts each. Some devices have a switch or automatic sensing to change between the two battery types. It might prove beneficial to take your unit to Radio Shack and have those guys look at it. They will be happy to help. Good luck.
Nov 28, 2009 | Radio Shack Pro-97 Handheld Scanner
sounds like you need those lithium battery's . ask for them at wal-mart in electronics or at radio shack .
Jul 09, 2008 | Vtech V.Smile Pocket
Radio Communications Logo
27 people viewed this question
Top Radio Shack Radio Communications Experts
Greg Cann
Greg Cann
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
