Question about Garden
Zero turn mower will not start while cranking, but when you disenguage starter it will start and run.What causes this you crank a long time and it will not start until turning key to on?
    Top Expert:
  • Garden Master
  • 48,419 Answers
When cranking an engine there is a very large drain on a battery so much so that if the battery is inadequate ( half flat or faulty cells ) there is no current left for the ignition system
however at the point you release the key from the start position there is a spike that is enough to fire a motor that is still turning over
Sort of like that will not start of the key but will when push started
have a load test done on the battery
if it is good , check for broken wires for the ignition circuit when the starter is engaged --could be in the starter switch itself not making contact for the run circuit
Posted on Apr 17, 2017
Why does it have an intermittent problem starting?
Electrical connections ! Have the starting system tested , voltage drop test ! Battery cables , connections at starter ! Holes in oil tank ? oil pan or gasket or transmission pan or gasket ! Voltage Drop Testing the Starter Starter Voltage Drop
Jan 19, 2016 | Jeep Grand Cherokee Cars & Trucks
Toro zero turn mower,motor quit running,replaced fuses,no start,crossed post on selnoid,engine cranked,no response with key,just clicking,battery not dead.Ingtion module bad?
Are you sure battery is not worn out? you can have power in the battery but if it does not have 12 volts the starter will not work. If that's not the problem check the starter solenoid.
Oct 24, 2015 | Toro Garden
What should I try next? My mower will not start.
When you turn the key, do you have 12V art the Starter?
If you do, then tap the starter with a small hammer. If it cranks, then your Starter is failing
Jun 25, 2014 | Snapper Husqvarna RZ4623 46" 23HP Kohler...
What is wrong when a Scag freedom z will not crank replaced battery and solenoid switch it ran and cut the yard switched off now will not crank. Clicking noise coming from the bottom of carburator. Two...
Recheck your connection at the battery and the solenoid. The clicking noise is probably the solenoid. The starter may have a shorted out field coil or armature. This will cause a starter crank over sometimes but it will have a bad spot where it will not crank. Check connection at starter as well.
May 07, 2014 | Scag SFZ52-26BS Freedom Z Zero Turn Rider
Engine wont start
Make sure wire from battery to starter is connected and there are no problems with wire ( I.e. no missing insulation, cuts and connection to starter is secure.) Also starter may be bad.
Apr 19, 2014 | Toro TimeCutter Zero Turn Lawn Mower...
Won't start
The click means the starter solenoid is acting. Most starters are like GM autos where this solenoid is on the starter. Often heat adversely effects these parts. Try tapping the solenoid and try to start it. If that works then a rebuild is indicated.
Mar 26, 2014 | Scag STWC48V-25CV Wildcat Zero-Turn Rider
My zero turn husqvarna ran great last week. Know it wont start. I turn the key..nothing. I checked the fuses, all good. Brake is on , steering arms are in neutral..battery charged. I has to be something...
Check and see if your getting battery voltage at the starter terminal when trying to start engine. This may take two people, one to sit on seat while turning the key to start and one to check to see if there is any voltage to starter when trying to crank. If there is battery voltage at the starter when being cranked, you have a bad starter. If you don't have voltage at starter when being cranked, check and see if there is a starter signal going to the starter solenoid. I'm not sure where it is exactly located on this peticular model but it is not that far from the battery. The main positive lead which is red in color goes to the starter solenoid first. Then there is another lead with the same thickness that goes to the starter from the starter solenoid. There should be a small wire between 14-16 gauge going to the starter from the ignition switch. Disconnect that small wire and check and see if your getting battery voltage when trying to crank engine. If you are getting battery voltage to the solenoid, the starter solenoid is bad. If your not getting battery voltage to the starter solenoid when cranking, check all safety switches that would cause the circuit to be interrupted, not allowing the starter solenoid to be energized. Hope this works out.
Oct 12, 2013 | Husqvarna Zero Turn Mower Z5426
Craftsman zt 7000 zero turn riding mower will crank but won't start and the starter get really hot
sounds like a safety switch problem. but maybe you can help me i have the same model do you have a lot of jerking when you start off of turn with yours?
Apr 10, 2012 | Craftsman Garden
I have 42in toro zero turn. turn the key to crank and all you hear is the sound of an electric motor spinning but mower will not engage and crank
There is a small slined wheel that is plastic which serves to enguage the starter and flywheel.
This is mounted on the end of the starters armiture by a configuration of springs , weights and a small bolt / roll pin.
When the starter turns , centrifigul force is used to raise the plastic splined wheel...
It sounds to me that the splines are all broke off , The mechanism that causes the splined wheel to blossom , or the alignment of the starter has been set off somehow.
Sep 29, 2011 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
