Hi my saeco minato has a red spanner with 1 on it
How do I remove a red spanner from the screen of machines ?
It is a descaling meter. Clean with a pure solution of white vinegar. run a few times and then run one pot of plain water.
Jun 02, 2016 | Saeco Coffee Makers & Espresso Machines
How do i clear the red spanner sign on Panasonic fp7722 copier
1 day ago ... i need to clear red spanner on panasonic fp 7722. how do i clear red spanner on Panasonic FP 7722 COPIER. Posted by avatar tonymusaeren ... www.fixya.com/support/t11438197-need_clear_red_spanner_panasonic_fp_7722 www.fixya.com/support/t11438197-need_clear_red_spanner_panasonic_fp_7722
hope this works
Jan 26, 2012 | Panasonic FP-7735 Black and White Copier
My bean light won't stop blinking red!
Hi
Turn you big knob in the bean hopper up all the way to the largest #, then try again. If it clears the and makes a coffee do it 1 more time then turn the big knob back down while the grinder is running but don't turn it down as far as you had it before,(1 to 2# higher)
Mar 30, 2009 | Saeco Incanto Classic Espresso Machine
Saeco magic (sin017 9710639730) bayonette mount (actual metal thread) broke and basket will no longer attach.
use some adhesive solution to attach it instead of trying to thread it again which wont be stiff.
Aug 12, 2008 | Saeco Vienna De Luxe Espresso Machine
Is there anywhere in Ontario that I can get a replacement portafilter for my Saeco Gran Crema esspresso machine?
Try to contact Saeco Canada to see if they can help you.
Saeco Canada Ltée
8145 Boul. St. Laurent
Montreal-Quebec
H2P 2M1
Tel: +1 514 3855551
Fax: +1 514 3855585
E-mail: info@saeco.ca
Visit the Web: www.saeco.ca
Jul 29, 2008 | Saeco Vienna De Luxe Espresso Machine
Steamer leaking
I think you have to replace the gasket in the steam valve.
Here are info to Saeco Canada.
Saeco Canada Ltée
Montreal-Quebec
H2P 2M1
Tel: +1 514 3855551
Fax: +1 514 3855585
Jul 28, 2008 | Saeco Odea Go
SAECO Incanto Rondo espresso machine
I think you have to take it to a Saeco service center, they have to upgrade your power board in the machine.
Jul 22, 2008 | Saeco Incanto Rondo RS SBS Espresso...
Old saeco ideas
Do you have a model number on that machine?
Jul 07, 2008 | Saeco Easy Espresso Machine
I have a saeco expresson machine
Try to take out the dregdrawer for 20sec and put in again.
You can also try to open the steam knob and make a cup of water.
Jun 06, 2008 | Saeco Coffee Makers & Espresso Machines
Red alarm light permanently on!
Hi.
First turnthe machine on.
Then take out everything watertank, dreg draw and brewingunit and have the door opened to the brewing area.
have them out for about 1 minute and then put it back together again.
if this dosent help please check if the machine respond to removing the dregdraw, beanlid.
It will do it by making the constant red ligth flash instead.
if they respond make sure that the watertank is filled to max.
if that is the case it is the watertank sensor that is broken.
May 26, 2008 | Saeco Odea Giro Espresso Maker -...
26 people viewed this question
jasbo
jasbo
