Question about Home
My porcelain sink in my bathroom made a crack sound and I have a long hairline crack now that leaks underneath the sink.Can this be fixed or do I have to get a new sink..??How can I repair this
    Top Expert:
  • Home Master
  • 49,267 Answers
Sorry but a new unit is the answer as it cannot be repaired successfully
probably find that the crack is under the seal at the pipe and it is leaking from there
Posted on Apr 17, 2017
    Top Expert:
  • Home Master
  • 41,875 Answers
Someone tightened the trap nut too much. Replacement is the only practical answer. Tighten the trap nut just enough but not too much.
My porcclain drop in bathroom sink has no clamp tabs to attach clips to,how to fix
Go to Home Depot and buy some sink screws that go into tab that you attach the screw into the wood and the tab over the underside of sink. They also carry other stuff that works even better.
Apr 29, 2014 | Home
TOILET IS LEAKING
Been there, done that. Does it leak all the time? Does it leak only when you flush? Please clarify this. If the gasket is off centered, it will leak there. The bolts could be leaking, got food coloring to use as a dye? You can do this while watching the bottom of the tank, as you flush. Hairline cracks in the porcelain can be seen, get out yur magnifier and look underneath the tank, as you flush.
Apr 15, 2012 | Home
Recently bought ex-display bathroom sink /unit.discovered cracks to underside of sink.can you recommend a repair solution?
I have to presume the sink is made of china and there is no repairing of china. There are two kinds of cracks, hairline from some sort of impact, and shrink. While the hairline crack can be visually disappointing, if it does not extend through the drain hole area it is a safe bet that the lavatory can be installed and used normally. A shrink crack resembles the cracks of a dried up lake bed and rarely cause any problems no matter where they are located. Rarely does not mean never.
Jun 02, 2010 | Oxo Porcelain Pedestal Bathroom Sink,...
PORCELAIN SINK UNDER GRANITE
Hi just unscrew from under sink use construction grade clear silicon screw it back in do not use for 24 hours and it will be ok
Apr 06, 2009 | Oxo Porcelain Pedestal Bathroom Sink,...
Surface scratches in my black bathroom sinks
You might try a vehicle buffer on them. If that doesn't work you will probably have to use a porcelain touch up kit that can be bought at your local hardware store.
Mar 29, 2009 | Home
Cast Iron Sink with porcelain coating. The Porcelain coating crac
Kohler does have a porcelin touch up or you can get it at Home Depot or Lowe's. Not the best solution but it might help. Comes in a little bottle like White out
Kurt
Mar 15, 2009 | Kohler K-5814-4U Clarity White/Color...
Can a hairline crack in a porcelain bathtub be repaired?
If your tub is porcelain over cast iron and the cast is not cracked your ok. If the cast is cracked then the chances of the crack continuing are great, more so with any vibrations and changes in weight distribution.
Feb 19, 2009 | Home
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
