Question about Jabra Audio Players & Recorders
Why won't my Jabra Bluetooth headphones turn on? I used them at the gym, then plugged them in like normal to charge and now they will not turn on.
SOURCE: Not sure if Jabra bluetooth headset or charger that not working
I had the same problem, called support, they told me battery is defective or too old and doesn't accept the charge. Battery in a headset is hardwired and can't be replaced, so the whole thing is trash :(
Posted on Jul 10, 2007
  • 8 Answers
Use your Bluetooth wireless headset or car speaker to make and receive calls: 1. Follow the manufacture's instructions for your Bluetooth device to make sure it is turned on and "visible". 2. From your Sidekick, go to the Phone application. 3. Make sure your Bluetooth device has paired with your Sidekick device by pressing MENU and selecting Settings > Pairing. (If you try to do this and you don't have Bluetooth services turned on, you will be prompted to turn it on.) 4. On the Pairing dialog that appears, make sure your Bluetooth device is listed and has a key icon next to it. The key means that it's paired with your device. If it doesn't have a key, roll the TRACKBALL to select the device name, then press to pair. Once paired, press DONE . 5. Back at the Phone screen, press MENU and select Transfer Sound to > Bluetooth Device Name. 6. Dial your number and send the call. All sounds will be routed through your Bluetooth device.
Posted on Aug 25, 2007
  • 689 Answers
SOURCE: How to pair Jabra BT620s
• At your computer Right click on the Bluetooth icon on the task bar.
• Select “Explore my Bluetooth places”.
• Click on “View devices in range” to see all available devices.
• Right click on the Jabra BT620s and select “Pair device”.
• Enter the four digit passkey: 0000 (4 zeros).
• Right click on the Jabra BT620s and select “connect”.
• The connection will be established automatically, otherwise if the Jabra BT620s is ringing,
press the answer/end button to confirm the connection.
Good Luck
Posted on Aug 10, 2008
SOURCE: Jabra JX10 Bluetooth doesn't/won't charge
Not sure if this is a solution or if it occurred by chance. Like many on here, I put my Jabra JX10 away for a few months while not using it. The time come for me to need it once again and found that it was dead. Made an attempt to charge the unit with negative results. The unit would only show a green "charged" LED indicator as if the unit was fully charged. I tried plugging the unit into the charger multiple times, and took the cradle out of the loop and just used the AC cord alone. Still with the same results. I pulled the outside cover off (slowly), to be sure not to break the small fragile tabs that hold it in place. The battery takes up majority of the space. Removed the battery but DID NOT disconnect from unit. Plugged the charge cord into the unit and immediately got a red LED charging indicator. While charging, placed the battery back inside and put the outside cover back on. The unit continued to charge for a little over an hour before the green LED "charged" indicator came on. I used the unit throughout the day to test it with no problems. Not sure what removing the battery from unit did, especially when it was not disconnected, but it worked. I hope to see similar results.
Posted on Jun 09, 2009
  • 5 Answers
SOURCE: new jabra A210 not charging
I had not used my A210 in a couple years, and when I needed it again now, I TOO GOT THIS SAME EXACT SYMPTOM: where it would light red (charging) only for 2 or 3 seconds, and then be off. Hours on the charger and no charging or difference. I tried plugging it in a few hundred times to see if it would "jump start" for the 3 seconds to add up, no luck. I WAS VERY GLAD to read MightyFrosty could change something inside and get it working. I followed his advice up to "removing the tiny circuitboard on the tiny battery and resoldering". Instead (got the case open with a razor blade, gently) I removed the amber tape that wraps the battery/circuitboard assembly and tried first "jumping" the red to the "+", nothing~ but then jumping the black to the "-" the RED LIGHT came on and STAYED ON! (but only while "jumped". Better yet after some 20 minutes of "jumpered" charging, the RED LIGHT STAYED ON even when I removed the tiny jumper~! (a tiny wire is all, bent to touch the black wire solder spot and the "-" battery lead). so IT APPEARS it CAN CHARGE PROPERLY on its own once the battery has a little juice in it! It is charging completely normally now (red light solid, no jumpers, and with no cuts or circuit removals!). I believe I can reassemble it all tomorrow and have a non-modified operational bluetooth Jabra! Thank you MightyFrosty and good luck to all!
Posted on Nov 12, 2009
The blue light does not blink,it is a steady light that will not turn off and it wont pair up with my phone
The only way to reset your headphones is by charging them and pressing the call button and volume up and it will work like new.
Mar 26, 2014 | AUVIO Bluetooth Headphones
How do wireless headphones work
Wireless head phones works on principle of wireless technology.
The phone has a reciver and tv or Audio system has a transmitter ,.
WiFi/blue tooth are examples.
Feb 15, 2014 | Sony Audio Players & Recorders
How to connect my wireless headphones
got to settings>manage bluetooth devices>register device>make sure your bluetooth device is turned on and it will ask for password on ps3 put password which would be mentioned on your bluetooth headphones pack >> then to device settings and change it
Oct 24, 2013 | Sony Playstation 3 (PS3) Console
My headset will not turn on
Your bluetooth headset is powered by an internal battery. If the battery is not charged,it just won't turn on. Fully charge your battery before use.
Make sure that the power outlet you're using is working and that the cord is fitted correctly into the wall, PC or Car outlet and the Jabra Bluetooth device.
Try unplugging the Jabra Bluetooth device and see if it turns on. If so, use the Jabra Bluetooth device until the battery is completely exhausted. The next time you charge it, check that it is charging properly
If the Jabra Bluetooth device is still not charging, check what happens when you initially plug the Bluetooth device into its charger. If the light on the Bluetooth device flashes on and then off again quickly, it is likely that the battery is no longer working. Batteries cannot be replaced or covered warranty
Dec 30, 2010 | Jabra BT150 Wireless Headset
My s9 headphone not on of work tell me wath i do
make sure you charge the S9 using a motorola mini usb AC charger or a mini USB cord plugged into a live port.
press and hold the circle vertical bar until the light is steady blue and pair it with your bluetooth device. you only have two buttons at the rear of the device under the motorola logo.
Aug 28, 2010 | Motorola Mobility S9 Headphones
Headphone Jack Broken
There is a problem with your headphone wires, you may need to repair the headphone.
Jul 29, 2010 | Acer Aspire One D250 (99802378332) Netbook
Connecting two devices on BT3030 headphones
A method to do pairing in "the second channel."
  1. Trun off BT3030 first.
  2. Continue pushing the power button till "Jabra" mark turns on pink next.
Attention: Continue pushing the power button after "Jabra" mark became the blue.
Mar 11, 2009 | Jabra BT3030 Wireless Headset
Is it possible to use regular headphones on your htc8900 that are not blue tooth if so how do i program it
If you use an adapter to convert the mini usb connection to headphones you can use it otherwise you will need headphones with the usb plug or a bluetooth set. I find most of my Tilt accessories on EBAY.
Mar 09, 2009 | HTC Tilt 8900 Smartphone
Headphones wont turn on
battery is toast get a new one anything electronic if u do not upkeep the charging it will die qwik
Dec 03, 2008 | Sony Bluetooth Wireless Headphones - Black
62 people viewed this question
Top Jabra Audio Players & Recorders Experts
Tom Chichester
Mister Danger
Jeff Tilburn
Jeff Tilburn
Are you a Jabra Audio Player and Recorder Expert? Answer questions, earn points and help others
