Question about Sanyo Televison & Video
Is there a replaceable fuse in my sanyo DP42D24 television
Where can I buy a replacement remote control?
There are a number of vendors of replacement OEM remotes to be found on the internet.
Apr 02, 2016 | for SANYO Sanyo Replaced Remote MC42NS00...
How do I run a channel auto scan?
There are many different ways, because each TV manufacturer calls each menu option something different. In your TV menu there should be an option that says Set Up, or Channels, or something similar. Your TV should be, Menu, pan right to Channel, select whether you are using Air (air meaning antenna, picking up channels that are broadcast free over the air) or Cable (only if you use cable with no box). Then the option below should be auto scan. Allow to run completely. Sanyo DP42D24 User Manual Channel
Apr 06, 2015 | Sanyo DP55D44 55" 1080p 60Hz LED HDTV
How do I find the remote code for a sanyo tv
The code is in your unidentified remote.
Oct 23, 2014 | Sanyo Televison & Video
The code for Sanyo TV
0101 0102 0107 0131. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Oct 23, 2014 | Televison & Video
I HAVE A SANYO LCD TV dp42d24. wANT TO ENHANCE SOUND WITH EXTERNAL SPEAKERS. THE RED/WHITE ON THE TV BACK SAYS audio input. i WANT AUDIO OUTPUT
There's probably a digital audio output you can use if you have a digital receiver. If you don't have a digital receiver you can take the audio out from the cable box or satellite box. Since I have an old analog receiver it's the way I connect my equipment. I use a hdmi cable for the TV so it frees up the rca output jacks on my cable box. Works great.
Aug 25, 2014 | Televison & Video
My sanyo model CLT2054 will not power up
Hi Please check the fuse of your television.It is located at the power supply near the ac cord just fallow the ac cord in to the board.Unplug first the your TV to avoid electric shock.Remove the back cover to see the fuse of your TV,then check if the fuse is busted.Replace the same value or amphere of fuse.Then try to power again.Thank u..
Jul 12, 2011 | Sanyo Televison & Video
Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
Televison & Video Logo
47 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
