Question about John Deere Garden
I am trying to find the correct air pressures for my John Deere 170 riding lawn mower can you help with this? front tires 15x6 and back is 18x8.5
    Top Expert:
  • John Deere Master
  • 44,148 Answers
The correct pressures may be indicated on the tires.
Posted on Apr 17, 2017
Diagram for John Deere series 100 riding lawn mower
type question into google and click images
May 07, 2016 | John Deere Garden
What is the correct tyre pressure for
NICE TRACTOR!
Tires
Front Dimensions15x6-6 turf
Air Pressure 110-138 kPa (16-20 psi)
Rear Dimensions26 x 12-12 turf
Air Pressure 96.5-110 kPa (14-16 psi)
Here is a link to the manual - very useful!:
http://manuals.deere.com/cceomview/omtcu29065_j0/Output/Index.html?tM=
Jan 03, 2015 | John Deere Garden
John deere 170 will not level
Check the air in your tires.
Aug 29, 2014 | John Deere Garden
John deere d140 ont move
there is a small handle on the back of most riders allowing you to free wheel the machine. If you can push your machine freely now then push the handle in and it should drive
Aug 04, 2014 | John Deere Riding Lawn Mower. D140 48 in....
How to level the cut hight of a L130 Jphn Deere Lawn mower
Inflate all tires to the proper air pressure using a high quality gauge such as a digital, not the $3.00 ones but a good quality from say Napa. Make sure the tires are within the same wear of tread and inflated to + - 1/2 PSI of the proper pressure. Find a nice clean and flat surface to park and using a "Tee" square check the left and right rear "corners" of the deck. If you do not own a "Tee" square I've used large wood wedges that taper from 0" to 3" (such as a wedge made from a 2X4), slide the wedge until the tapered part just touches the rear corners of the deck and mark it with a pencil, do the same on the other side and then adjust the rear hangers until the deck is level within 1/8" or less side to side. Then adjust the front hanger to set the front of the deck 1/8" lower than the rear and you are there. From then on simply keep the tires inflated using the example above and your deck should go right back to level again.
If the out of level cut still persists check to ensure the blade tips are even with each other, one blade higher than the other could be a bend blade or a distorted deck and possibly a bad spindle bearing.
Aug 02, 2014 | John Deere Garden
Is there any manual for a john deere riding lawn mower model # la115
if you look up "john derre riding mower" blog or club, I'm pretty sure you will eventuality find a bunch of lawn mower enthusiast, with alot of time and resources on their hands. Most of the time you can find rare parts, paint, manuals and lots of extras.
Jul 16, 2014 | John Deere Garden
Change rear tire on john deere lawn tractor lt-150
i guess the wheels are stuck you will damage the wheels and axle trying to get them off just pop the beads and change it right on the mower
Apr 16, 2012 | John Deere Garden
Overheating JD Model 170
Before you put it out to pasture you could try rebuilding the carburator.Its 20 years old and I bet its got dirt inside it.
The only other thing I would suggest is, when it stalls and back fires, stop and pull out the spark plug and watch the spark while you turn it over to be sure it has a good strong consistant spark.The coil might be tired.
These are my only suggestions.
I hope this helps!
Sep 22, 2009 | Garden
Left front tire riding on outside edge.
Yes, adjust it. On lawn and garden equipment the set the tires as straight as possible. Because of there low speed the equipment it's not a huge deal. So just adjust it as best you can without any worrying.
Mar 29, 2009 | Garden
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
