Question about Home
How to get the alarm and key tone to operate on the ULTRONIC Model TD00552, Touch Screen Thermo Alarm Clock? All other functions operate properly, but alarm does not sound or key tones.
SOURCE: I cant find the alarm clock on N79? I have looked
Go into your phones menu, press applications, then press clock and there, your alarm menu is hiding. Hope this helps.
Posted on Mar 17, 2009
SOURCE: HTC Touch HD alarm problem ?
click on the alarm icon, click on the bell which takes you to where you need to be able to change the tone
Posted on May 05, 2009
  • 52 Answers
SOURCE: i cant change my message alert tone and alarm tone
I contacted LG about the same thing. The only message tones are the 4 that are on the phone. This phone cannot use mp3's as message tones ot alarm tones.
Posted on May 26, 2009
SOURCE: Timex T301B
Time zone 7 is Hawaii. They don't do daylight savings. I think I fixed the clock by changing it to time zone 7 and then resetting the time so it was correct in my own time zone.
I'll know for sure next daylight savings day (by the old schedule).
Posted on Apr 03, 2010
SOURCE: Need to set an Ultronic clock
Press the time (current time - numbers) to get to the date mode. Then hold-press "SET" to set it.
Posted on Aug 22, 2010
Setting an ultronic touch screen alarm clock
TD00552: 12 hr--military time toggle= tap time set button. Set time= hold down time set button till up & down arrows show on r & l sides; set hour, tap time set button, then set minutes, repeat, seconds, repeat. Date change= tap hour if needed to show day & month; then hold set button on left till up & down buttons show at edges of screen. Up/down buttons to set year on lower right screen, tap set again to change # day of month, tap set again to change month, and the day will correct itself. Change temp c° -- f°= tap alarm button if needed to display temp b them tap set button next to it to change temp scale. Alarm- off/on= tap screen button if needed to show alarm time; tap alarm set button next to it- it will toggle on/off. To set= with alarm time showering, hold down alarm set button till up/down buttons show; follow same process as above.
You are all welcome ??
Jul 01, 2017 | Televison & Video
Ultronic td552
Press upper right box 'alarm' until alarm time shows, then press 'set' button and it will toggle between 'off' and 'on' for the alarm.
Jul 01, 2013 | Audio Players & Recorders
Good Morning, I bought a used Magic Chef stove. I don't have the manual. The alarm/bell keeps going off. The display shows "F-1" Would you please let me know how to turn off this alarm? I keep...
F1 Defective Touch Pad or Membrane
Replace Touch Pad or Membrane
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 20, 2010 | Magic Chef Kitchen Ranges
Ultronic Touch Screen Thermo Alarm Clock TD552 Desktop Model
This may be helpful, it's how I set mine.
1) Remove battery cover
2) Remove batteries
3) "Set" the clock and battery cover into the trash can.
There you go. No more problem !
Mar 15, 2010 | Computers & Internet
HOW DO U SET ALARM
To create an alarm follow the steps below:
  1. While in standby mode, press the Menu / OK button
  2. Select Tools
  3. Select Alarm Clock (9)
  4. Highlight the desired Alarm, using the navigation keys, from the following:
    • Alarm #1
    • Alarm #2
    • Alarm #3
  5. Press the Menu / OK button
  6. Set alarm to On, using the navigation keys
  7. Set alarm time, using the keypad
  8. Select either A for AM or P for PM, using the navigation keys
  9. Press Menu / OK button to choose the Ringer Type from the following:
    • Single Tones (1)
      • Tone 1 through Tone 9
    • Ring Tones (2)
      • Ring Tone 1 through Ring Tone 15
    • Melodies (3)
      • Ball (1)
      • Caribbean Cruise (2)
      • Chorus of Clocks (3)
      • Right Here (4)
      • Guitar Man (5)
      • Latin Lady (6)
      • Minuett (7)
      • Mixed up World (8)
      • Pressure (9)
      • Simply Blue (10)
    • My Content (4), for previously downloaded music
  10. Select desired Repeat frequency, using the navigation keys, from the following:
    • Daily
    • Once
    • Mon to Fri
    • Sat & Sun
  11. Select the Snooze Interval, using the navigation keys, from the following:
    • 5 Minutes
    • 10 Minutes
    • 15 Minutes
    • 20 Minutes
  12. Press the left soft key for Done to save the alarm changes
Dec 16, 2009 | Samsung SPH-M500 Cellular Phone
I want to change it so there are no key pad tones. also, i'd like my alarm clock to be on the right hand corner of my screen, not the web2go button...
Go to settings on your phone menu and go to sound and change key pad tones to silent or none or volume zero then for the buttons go to shortcuts and on the right soft key change from web to alarm clock! if not then this setting may not be available on your phone.
Nov 11, 2009 | Samsung Gravity SGH-T459 Cell Phone
Set time on Touch Screen Thermo Clock
Just in case you didn't manage to set the time / date on your tocuh screen thermo clock, I'll try to help you from my experience (no available manual at the moment!).
1. To set the time, touch the clock icon on the upper left corner;
2. Keep touching the screen for longer than 5 seconds, on the hour area;
3. Touch the hour area until you get what you want (if you prefer the 24 hour display style, touch repeatedly until you get the right hour without the AM / PM indicator next to it);
4. Touch the clock icon again to start the clock;
5. Repeat steps 1 to 4 to set up the minutes (the hour area will be replaced by the minutes area);
6. To set the date, tocuh the calendar icon on the left hand side;
7. Keep touching the screen for longer than 5 seconds, on the year area;
8. Touch the year area until you get what you want;
9. Touch the month area until you get what you want;
10. Touch the day area until you get what you want;
11. The screen will reverse to the time display after 5 seconds if no touch.
12. The TEMP (temperature) area, if touched, is toggling between C and Fahrenheit degrees.
P.S. I don't know if it is possible to set an earlier time / date, except touching. I mean, if 2009 is on the screen and you want 2007, you'll keep touching up to 2030 and then from 1901 up to 2007.
Hope it helped.
May 08, 2009 | Watches
Feb 19, 2009 | RIM BlackBerry Pearl 8100
Alarm clock won't ring - Verizon v3m
what you can do is go to ringtone settings and assign a specific tone to it....and then test it
May 26, 2008 | Motorola Mobility RAZR V3
Home Logo
32 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
