Question about Zoeller 1700078 Filter Septic Tank
Pump is not working - removed it and cleaned it -when I hold the pump and tun it on I get a shock. Help :(
    Habit-Forming:
  • 100 Answers
Isolate the pump from the electricity supply...!!!!
Could be a fault with the windings or the electrical connection. As you're getting a shock, that's the first place to look. If water is getting into the electrical side then the seals have failed and you might need to replace it...
Posted on Apr 17, 2017
SOURCE: rear shocks not working bad ride pump/? 1995 buick riveria
make sure you plug up the air ride shock.
Posted on Mar 19, 2009
SOURCE: No compression.
I opened the chamber and replaced a gasket. Problem solved.
Posted on Apr 11, 2009
  • 46 Answers
SOURCE: Shocks wont pump up. Can't give sis a ride
If you look on the shocks if the front there should be switch with an arm on it. These sometimes break or slip out of place.
Posted on Nov 14, 2009
miket756
  • 2702 Answers
SOURCE: Not draining. Aready removed pump, cleaned lines
the pump could have got stuck and burned out the drive motor,,,this can be tested,,,have you cleaned out the filters as well?
Posted on Jun 08, 2010
  • 5653 Answers
SOURCE: 98 expedition air shock pump by pass help is there
Hello, Check your fuse panel and the Airride switch in the cargo area. It is usually next to the fuelpump safety switch.
Here is how the system works. The vehicle is suppose to stay low for loading and for passengers to get in and out of the vehicle. Every opening (Doors, Rear cargo lid) has to be shut before the AirRide pump will work. Then the pump will work and level the vehicle.
For the doors, it uses the doorjam switches and there is a jam switch in the cargo area opening too! This switch may look more like the one on a refrigerator or can run off the hinge mechanism. For the most part, the door ajar warning will tell you there is a problem in the openings.
After the engine is started, a Relay will power the pump. It is probably your problem if a fuse has not blown. Check with Autozone or similar for an Airpump Relay. The Air release vent Solenoid is a different part and not your problem. If the vent Solenoid was stuck, your pump would run and the vehicle would not raise.
I hope my Solution is very helpful in fixing your Expedition. There is a Diagnostic plug which requires a better Scanner to read, but it is quick and accurate. You would have to call around for Service places having the special scanner for this job if the Relay does not fix your problem.
Posted on Apr 08, 2011
Pool has gone green . Shock treatment seems in effective.
if filter pump working clean filters if sand or DE filter back wash if doesn't help change sand clean DE grids and recharge and super shock pool see pool school.com
Dec 09, 2017 | Pool & Spa
Where is the coin catcher on a Kenmore Elite H3 washer
it is most likely the pump. you can remove the pump and debris trap easily, separate the pump from the debris trap by depressing a tab and turning the pump clockwise from the debris trap. the pump is a mag drive unit and is easily dis-assembled. ours had debris inside the pump, once taken apart there was some black colored fine sand inside that once cleaned out the pump returned to normal function. we bought a new pump but the old one still works since it was cleaned out, the rubber o ring had leaked letting the debris inside the impeller assembly. hope this helps out. it worked for ours
Dec 03, 2017 | Kenmore Washing Machines
Ge washing machine will not drain
Drain by lowering main drain hose below pump into shallow bucket, remove front lower panel , take large hose off back of pump clean out hose, may have to take 2 screws out of pump mount to look in pump mine was being stopped by a nail,the$6.75 in change was still in the hose
Jan 23, 2013 | GE Wsxh208a1ww Front Load Washer Washing...
Pump goes on for few seconds then dies. Reset fuse box several times. Pump still working.
THE LITTLE CAP ON THE TOP OF THE MOTOR IS THE RUN CAPACITOR, THE ONE IN THE BACK IS THE START TAKE IT OFF AND HAVE IT TESTED. BE CAREFUL THESE CAN HOLD VOLTAGE AND GIVE A NASTY SHOCK !SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING... CLICK HERE IS HOW TO REMOVE YOUR PUMP .JAY
May 30, 2011 | Hayward 1.5hp Pool Pump Motor Motor A O...
How do you replace the water pump?
Hello, ramrodsc2 Removal Procedure 1. Drain the cooling system untilthe coolant is below the level of the water pump. 2. Remove the drive belt guard. 3.Loosenthe waterpump pulley bolts. 4. Remove the drive belt. 5. Remove the water pump pulleybolts and remove the water pump pulley. 6. Remove thewater pump bolts then Remove the water pump. 7. Remove the water pump gasket 8. Clean the water pumpmating surfaces pay particular attention to the cleaning process and make surethe surfaces are clean. Installation Procedure 1. Install the water pump gasket. 2. Install the water pump; tighten the bolts to 10 Nm (89 inchlbs.). 3. Install the water pump pulley.Loosely install the mounting bolts. 4. Install the drive belt; this will help hold the pulley thentightening the pulley bolts. 5. Tighten the bolts to 25 Nm (18 inch lbs.). 6. Install the drive beltguard. 7. Fill the cooling system. 8. Inspect the cooling system for leaks. Regards, netvan
Mar 13, 2011 | 1999 Chevrolet Venture
Location and placement of a water pump
ok you will see a pulley with NO GROVES with FOUR 10mm bolts
that's the water pump
remove that pulley
then there are FIVE 8mm bolts holding the water pump to front cover
remove the 5 water pump bolts
then use a screwdriver and hammer and tap the pump to seperate the pump from the cover
clean the old gasket off and reassemble
hope this helps
Dec 01, 2009 | 1997 Chevrolet Venture
Need to replace my shocks and my water pump how should i start and the process of doing this
Greetings: Do you have your tools ready? You will need rachets, sockets, wrenches, DW4, breaker bar, new water pump with gasket sealer, a torque wrench and energy.
Let's get started on the shock absorbers first and loosen up your lug nuts and raise the rear of your truck and place it securely on jackstands. Remove the rear wheels. Position a floor jack under the differential and raise the jack just enough to take the weight off the axle. Remove the shock absorber top and bottom mounting nuts/bolts (you might need some WD4 Lubricant on the nuts and bolts) and remove the shock absorber. Installation is the reverse of removal but please make sure the spacer is installed on the inner side of the shock absorber. Tighten the mounting nuts and bolts to the proper torque for you truck. Do the same procedure for the front shock absorbers. That wasn't too hard was it.
Now let's change the water pump. First turn off your radio in the car so that when we disconnect the batter negative post and hook it back up we will not damage key components of the radio. Now disconnect the cable from the negative side of the battery. Next drain the cooling system coolant from the radiator into a pan. Remove the fan and shroud (that's the protection around the fan). Make a quick drawing on how the fan or drivebelts are hooked up and then remove the belts. Remove the pulley at the end of the water pump. Loosen the clamps on the water hoses and pull the hoses from the water pump. They might be tough to come off so use a pair of adjustable pliers and use them to grab each hose near the end and twist it to break the seal and then pull them off of the water pump. You might have to cut them off if they have been on too long and deteriorated. When you get read to reinstall put on new hoses.
Remove anything else such as a timing belt cover, if it is holding the water pump in. Remove the bolts from the water pump that locks the pump to the engine. Remove the water pump. Now its time to install the new pump. Clean the bolt threads and threaded holes in the engine, also the top of the engine where the old gasket was with a scraper, and lacquer thinner to remove gasket material, corrosion and old sealant. This is very important make sure the new pump matches the old one exactly or you will have to start all over after the pump is assembled and the car is ready to go because it will leak when the car is hot and under pressure. After all is clean, apply a thin coat of gasket sealant to the engine side of the new gasket. Next apply a thin layer of gasket sealant to the new water pump and then carefully mate the gasket and water pump. Install the water pump to the top of the engine (cylinder head) and carefully attach the pump, gasket and seal to the engine. Secure the water pump with two nuts, finger tight. Now this is important, pry the water pump up toward the cylinder head and install the remaining bolts. Tighten the bolts and nuts to the proper torque for your truck in 1/4-turn increments. (don't over tighten or you could cause damage or problems. Reinstall all parts removed earlier in reversed order. Make sure the radiator outlet is closed and add new antifreeze and part water. Check the drive-belt tension and crank your engine and let it run while you look for leaks. Hope I have been helpful and good luck.
Oct 10, 2009 | 1991 Chevrolet K1500
Hi! I have a Gibson Front Load washer, manufactured by Frigidaire I believe, Model # GWT645RHSO. It is leaking from below the drum. I opened the back for a better view of where the leak was coming...
Hi
Thanks for using FixYa. It is either leaking from drain pump joint or the drain pump has developed a crack. You'll need to remove the drain pump for any cracks or loose connections. Please see the steps to remove the drain pump---
Use a shop vacuum to **** all the water through the drainhose. Remove the bottom front panel held by two screws on bottom and twoplastic pins at the top. Locate drain pump in front right. Removedelectric connector on front of pump. Remove two screws holding pump down. Usedpliers to move spring clips back so hoses could be removed. Put hoses on newpump and squeeze the clamps with pliers to pull them back over the hoseconnection. The connection on the left will cause a little pain due to spacelimitations. Now put the screws back on the pump after checking and reconnectthe electric plug. Put the bottom cover back on and screw it into place.
This schematic will help you--
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Oct 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Please help!
remove bottom panel remove as much water as possible from tub ..have lots of towels handy remove clean out port on pump clean and reinstall...also ck as far into pump for something jammed in impeller ..pump may need to be removed to clean if unable to clear jam ..3 screws hold pump motor to pump body remove if necessary also ck to see if pump impeller is spinning freely on motor shaft should be some resistance when turning if impeller spins freely replace pump
Oct 04, 2008 | Kenmore Elite 45986 Front Load Washer
Rear shocks whirlpool duet GHW9200LQ front loading washer
ok its hard to remove the shocks without breaking the little tabs. You can tell which way they rotate out right?? There is a stop tab that stops the shock when its locked in. Rotate the other way, I use pump pliers (crescent wrench) and gently apply pressure until the tabs give. The new shock has new tabs and all..
Nov 24, 2007 | Whirlpool GHW9200L Front Load Washer
Zoeller 1700078 Filter Septic Tank Logo
Top Zoeller Plumbing Experts
Paul Nicholson
Gil Shultz
Are you a Zoeller Plumbing Expert? Answer questions, earn points and help others
