Question about Health & Beauty
Blood pressure reading from wrist cuff 94/62 heart84
SOURCE: Omron HEM 650 Wrist Blood Pressure
There are some instructions at this site. It was enough to get me going...
http://www.targetzone.net/HEM-650.html
Posted on Dec 09, 2008
Max J
  • 22 Answers
SOURCE: WITH AUTOMATIC CUFF BLOOD PRESSURE MONITOR GETTING ERROR
E might represents insufficient inflation for your mom. For automatic inflation monitors usually there is a mechanism to keep inflating the cuff to higher pressures for people with higher BP. Check how is done. In some auto monitors,while cuff is inflated you keep pressing on START button until pressure reaches to some 15 to 20 mmHg higher than the pressure that auto usually stops and displays E.
Posted on Sep 08, 2009
DrRonJupiter
  • 10 Answers
SOURCE: mabis automaic blood pressure cuff, pressure monitor
Dear Edward: Likely, either cuff not tight enough or not in correct location on your arm or not holding device at correct height. Make sure you use Lithium Ion batteries. Try it on someone else. Dr Ron Grassi,Jupiter,Florida.USA. www.DrGrassi.com 30ad4e8.jpg
Posted on Oct 13, 2009
SOURCE: How to clear memory on a ReliaMed wrist blood preassure machine
  • Make sure the unit is off
  • Hold down on the memory button until you see "CL" (clear)
  • Once you see CL appear on the screen release the memory button then tap memory once
  • You will hear a series of beeps
  • Memory is now cleared
  • Posted on May 14, 2010
    SOURCE: How do you set the time and date on a Welby Wrist
    I was able to do this by 1st pushing and holding the M button and then pushing and holding the on button and holding both for 3-4 sec. Once released you will see the month flashing. change by pushing the M key to desired month then toggle to day etc with the on button
    Posted on Oct 07, 2010
    User manual for equaline digital blood pressure monitor model BA-717A
    No, it is not able to be calibrated by the user. If your arm is too large for the cuff it will read high. Most cuffs are made for small framed people. Try wrapping it around your lower arm and position it about 2-3 inches above the wrist. use the wrist to take the b.p.
    Jan 12, 2016 | Health & Beauty
    Omron bp710
    I use Omron blood pressure monitors and I can say that they are up to the mark. Their readings are very accurate and have not caused any problems so far.
    Aug 03, 2012 | Omron Automatic Blood Pressure Monitor w/...
    WHAT IS THE P IN A CIRCLE FOR IN THE WRIST BP CUFF
    What does the circle with a P in it mean on walgren creen of cuff bold pressure monititor?
    Jul 30, 2012 | Walgreens By HoMedics Automatic Wrist...
    What is the m button for
    Hope this helps you out
    Sep 19, 2011 | Health & Beauty
    When the blood pressure monitor reads E- error. What is the reason? Not keeping the wrist still?
    It depends on which E-error you're getting.
    EE - indicates several things:
    • Cuff has been placed incorrectly. Always place cuff on wrist 1" above heal of hand.
    • Did you talk or move during measurement?
    • Shaking of the wrist with the cuff ON.
    E1 - Air circuit abnormality. Measure again.
    E2 - Inflation pressure exceeding 300 mmHg. Switch the unit OFF.Wait 1 minute, then measure again.
    E3 - Error determining measurement data. Measure again.
    Hope this helped you to determine which Error you're receiving. Please let me know.
    Apr 30, 2011 | Walgreens By HoMedics Automatic Wrist...
    My wrist cuff monitor seems to be reading low. Is there a way to get it checked or calibrated?
    The next time you go to your doctor, take the wrist cuff monitor with you. As they always do, the nurse or doctor will check you vital signs. After they do that and they've told you what your blood pressure and pulse readings are, correctly place the cuff monitor on your wrist and check you BP and Pulse with it. Compare the reading from the cuff monitor to what your doctor got. If it's within a few points, it's no big deal. If it's way off, than there's a problem with the cuff.
    Remember, whenever using a cuff monitor, always keep your wrist at heart level for the most accurate reading. Once it's activated, remain completely still and don't move your wrist, until it has finished cycling.
    Feb 23, 2011 | Walgreens Automatic Wrist Blood Pressure...
    I have a cuff like this and get an error saying EE
    According to the Owners Manual, the EE Message shown on the display or the blood pressure value is displayed when an excessively low (or high) reading is detected OR as a result of one of the following:
    1. Cuff has been placed incorrectly. Solution: Wrap cuff properly so that it's positioned correct.
    2. Did you talk or move during measurement? Solution: Measure again. Keep wrist steady at heart level during measurement.
    3. Shaking or moving of the wrist with the cuff on. Solution: Same as # 2.
    NOTE: Be sure the cuff is placed exactly as pictured on the face of the box, 1/2" above the heel of the hand.
    Jan 27, 2011 | Walgreens By HoMedics Automatic Wrist...
    What does EE mean?
    EE means one of 3 things:
    1. Cuff has been placed incorrectly. Solution: Wrap the cuff properly so that it is positioned correctly.
    2. Did you talk or move during measurement? Solution: Measure again. Keep wrist steady during measurement.
    3. Shaking of the wrist with the cuff on. Solution: Same as # 2.
    Jan 25, 2011 | Walgreens By HoMedics Automatic Wrist...
    Err 3 is displayed
    Wrist blood pressure monitors must be used with the arm above heart level. You can do the pledge of allegiance while doing a reading to make sure this is done. Usually this error occurs when inflation takes too long or the placement of cuff is wrong.
    Sep 10, 2009 | Walgreens Wrist Blood Pressure Monitor
    Reading are much too high, normal BP is 104/50, monitor reads 130/60
    if your arm is too large for the cuff it will read high. most cuffs are made for small framed people. try wrapping it around your lower arm and postion it about 2-3 inches above the wrist. use the wrist to take the b.p.
    Jul 27, 2009 | 3M Mabis Adult Aneroid Blood Pressure...
    Health & Beauty Logo
    20 people viewed this question
    Top Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you a Health and Beauty Expert? Answer questions, earn points and help others
