Looking for heater element for a Bendix WMN842B Washing machine. W2000 V230 4326.
  • 298 Answers
SOURCE: Looking for a manual for a Bendix Aquaria duomatic
i really dont know if they will have it but you can try appliancerepairplanet.vstore.ca and see if they can get you one. shane
Posted on Dec 18, 2010
  • 54 Answers
SOURCE: Tricity Bendix washing machine AW 1000 W
remove the rear panel 4 screws and you will see it on the lower of the drum.
Posted on Feb 12, 2008
Macmarkus
  • 2605 Answers
SOURCE: Hi,
First of all, if you have checked the element with a meter an it indicates it's "open" then yes it is faulty.
Second, it can be a challenge to change the element and you might want to consider an expert.
**unplug the unit from the power source**
Note where the wires are attached to the heater and remove them. Now you'll see there is a single nut in the center, likely about a 5/16 or 3/8, or similar in metric. Once that nut is off, the heater should pull straight back and out. It may need some firm pulling. The tricky part is lining it up properly when re-installing it as to get in the bracket which keeps it from contacting the basket.
You can do a trial run if you're not sure, If once you start you think it isn't going well, phone a certified tech.
Hope that helps.
good Luck :)
Posted on Oct 29, 2009
Testimonial: "Perfect response and answer I was looking for. Many Thanks"
barkencoa
  • 3463 Answers
SOURCE: Washing machine heater not working
Only way to be sure if it is the heater, is to test it with a meter.
They are a fairly straightforward job to replace
Please rate my solution.
Thanks..
Posted on Nov 17, 2009
  • 389 Answers
SOURCE: Location of the heater element relay
hi the heater relay is located on the module board you may have to take it out and check circuit for dry joints somtimes commen problem but also check your heater ellement for continuity or open circuit there is allso a heater cut out to check check the heater and then the cut out first
Posted on Nov 07, 2011
Blown fuse
check heater element
May 09, 2014 | Tricity Bendix Washing Machines
Looking for a manual for a Bendix Aquaria duomatic washing machine
Dec 18, 2010 | Tricity Bendix AW1000W Front Load Washer
Tricity bendix aw1001w has an unknown error code, the led labled end flashing 3 times, any ideas?
It could be one of the E30 codes which would relate to the pressure switch or an earth fault on the heating element there could be a wiring fault or p.c.b. fault check wires off heater at bottom rear of machine,remove back plate 4 screws.Hope this helps.
Good Luck.
May 07, 2010 | Tricity Bendix AW1200 Front Load Washer
Tricity Bendix tumble dryer Tm540
More likely to be heater element failure, you need to test element and or stat(s) with a meter.
Plz rate this solution
Dec 14, 2008 | Tricity Bendix AW1054 Front Load Washer
Bendix 1500 series Washer is leaking from bottom
It is now Tricity Bendix, and comes under the ZANNUSI name.
Try looking under Zannusi in your directory
Nov 25, 2008 | Tricity Bendix AW1054 Front Load Washer
Error code tricity bendix aw1200w washing machine
I think this is a problem with the thermister (built in to the heating element assembly).
Feb 21, 2008 | Tricity Bendix AW1200 Front Load Washer
Feb 09, 2008 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix 1000 washer
you need to replace the element. remove the rear panel and you can access it
Oct 22, 2007 | Tricity Bendix AW1000W Front Load Washer
Dishwasher stuck in cycle tricity bendix DH 104
if this is stopping early in the cycle, the timer has just moved a little before it stops then it is highly likely to be a heater fault, check the element for open circuit, this can be accessed from under the machine, work with safety,
Sep 16, 2007 | Tricity Bendix AW1000W Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
