How to fix split fingernails - Televison & Video
Best treatment for cracking, splitting and peeling fingernails?
change your diet
wear gloves when using detergents or chemicals
Feb 21, 2015 | Cars & Trucks
Just bought a emerson EM744 tablet and the screen show 3xs everything even when chargeing it has 3 batterys like the screen is split is there a way to fix this or should I just take it back?
I fixed this triple screen issue by opening the unit (slide fingernail around the edge), then reseat the video connector, it's the largest connector, flip up the locking tab, then reseat the connector & flip the tab back down. Test it, then close it up.
Dec 25, 2013 | Tablets & eReaders
LG keyboard keys mixed up
If you mean like the "h" is where the "j" is supposed to be or whatever, ththen just put you fingernails or something else underneath of your keys and just pry them off. when you have them both off, pop them into the right place again... simple fix
Feb 25, 2013 | LG Computers & Internet
I was playing jak x on ps2 and it froze while it was saving so i had to hit reset button and the data is courupted and i try to delete it and it wont go away and the game won't let me start a new profile...
The best way to stop freezing games is fingernail polish remover.You will need a soft cloth and fingernail polish remover.STEP1 take the remover and add a little remover to it but not to much it could screw up your game.STEP2 rub it one the game all around but not to fast.STEP3 let it air dry for 30 min.If its still a little wet dry it off with a soft cloth and what 5 min then it should work.
Dec 21, 2010 | Sony PlayStation 2 (PS2) Console
LG VX5300 Flip Phone broke in half.
Your phone can work again, all you need to do is to get the flexi cable and fix it back in place.
It is not expensive.
It is about $15.
To fix this, these are the processes to follow;
  1. Get the appropriate screwdriver,
  2. Turn your phone over so the battery cover is facing you. Remove the battery cover and battery.
  3. Next remove the 2 rubber stoppers and unscrew the aerial.
  4. Remove the 6 screws,
  5. Next remove the 2 rubber stoppers & screws above the main screen,
  6. Prise the back part away from the rest of the phone by running your fingernail between where the two parts meet,
  7. Unclip the ribbon,
  8. After removing the ribbon cable, carefully lift the metal part that is beneath the phone. Another ribbon will be attached which should be carefully removed.
  9. Take the circuit board & keypad out and you'll be left with what's below it.
  10. Next remove the top part of the phone by pushing the housing in whilst pulling the hinge, which the top part is attached via, away from the phone. This is the hardest part and you'll need to bend and manipulate the housing the get the hinge out. Be firm but be careful so you don't snap the housing.
  11. To open the top half of the phone and get to the screen, run your fingernail between where the two parts of the housing meets,
  12. Try to open up the top part by splitting it open with a credit card,
  13. replace the ribbon and,
  14. Reverse the procedure for reassembly and it's finished.
Take care
Jun 21, 2010 | LG VX5300 Cellular Phone
TAKING APART
if its under warranty, i suggest you call garmin to have it fixed for free....if its out of warranty, use a hair drier to heat up the sticker on the bottom of the gps and remove the sticker.
then youll see two screws that were hidden by the sticker...remove those two screws, then use your fingernail and slide it around the seam that seperate the front case from the back case to un snap the locking tabs.
becareful, because the speaker and the battery wires are attached to the rear.
split the two halfs and desconnect the wires before pulling the two halfs completely apart.
bill
Apr 16, 2010 | Garmin nuvi 205W GPS Receiver
How do I open the hdd casing up to get the hdd out?
It depends - there are a couple of options. Some models have some hidden screws and some just have a clipped on case. Force a fingernail between the cover and the pages (as it were) if you an get your fingernail all the way around the cover then it is probabky a clip on - you just have to locate the clips and spring them - a stripping knife is a good tool to use. If you get to a point where your fingernail will not pass, then you probably have a screwed case and the screw is very close to where your fingernail is - (near the bottom back corner I think) - even so I think there is still a clip or two that has to be sprung.
Sep 23, 2009 | Western Digital MY BOOK HOME 1TB EXT...
How do I ''Replace the Battery'' on a Honeywell 97-3893 Thermostat. The unit is blinking ''replace battery'' and I don't want to force opening anything.
the unit has a split line where to top meets the base plate pull on the bottom side with your fingernails at the split line and it will pop free it will take some force batteries are accessable after that, just line up and push to reinstall
Jul 08, 2009 | Heating & Cooling
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
