Question about The Audio Players & Recorders
I have a technics SX-EX600 stereo receiver and on all the channels except tuner are one sided and the other side sounds quiet.
This also happens with VCR 1 and VCR 2 its flipped sides from right to left and left to right i already tried to rearrange the speakers reset the receiver i really don't know what to do to fix this.
  • 518 Answers
SOURCE: Pioneer SX-750 Old School Need Help
It could be a dirty control or switch, working them back and forth could prove that. Other than that, It's likely bad outputs. A unit that old may have transistors for outputs but might be IC's. Transistors can be tested with an ohm meter to see if they're good or not. Also if it has transistor outputs, they may have a small value resistor on the Emitters, check those as well.
Hope that helps...
Posted on Mar 07, 2008
  • 156 Answers
SOURCE: I have the 2442 fx behringer
Check you assign buttons and bottom (three black square buttons) and play with them. It sounds as if you are not sending to that side. You should use mono cables into left and right. I set pan on left all the way left and right, all the way right. Hope this helps.
Posted on Jul 06, 2009
  • 691 Answers
SOURCE: one of my DJ turntables = only left side stereo sound
need to narrow it down, using 1 turn table ONLY with the mixer on channel 1 (the chanel that is working) to test reciever is working properly and sound working on both side of the speakers, this eliminate the first turn table. Next, disconnect the working turn table (1) and connect your second turn table to the same chanel and see if you getting the sound coming chanel 1 just as your first turn table did. If you getting sound coming out from turn table on ch1 than is not the turn table issue. It will be you mixer having problems. You cant solve the problems having everything connected. Testing one turn table at a time using working chanel on the mixer to see if both turn table working properly. If you use the same chanel testing both turn table and the second one does not work than it will be one of your turn table is faulty. Note: if you find and test both of your turn table is working properly than it will be your mixer. good luck and hope that help..
Posted on Aug 06, 2009
SOURCE: i have a Pioneer SX 203 stereo reciever which
Had the same problem. Another website suggested that the problem was that my speaker wires were too close to power cords. Turns out, my speaker wire was actually crossing over the surge protector!
I moved my speaker wires so that they were as far from power cords as possible and the problem disappeared. Not sure if this is a permanent solution but so far it has worked. By the way, this problem was driving me crazy. I originally thought it was due to a bad CD lens. Got the CD player cleaned was almost ready to buy a new receiver. Try this first before wasting money!
Posted on Aug 30, 2009
SOURCE: I have a Technics SA-EX600 stereo receiver and
I have the same reciever for sale. Make me offer 909 9289515 Chris
Posted on Nov 17, 2011
Am antenna technics st-z550
Loop antenna is directional.
But you can extend the wires so as to find a good spot.
Jul 29, 2012 | Panasonic Technics St-z550 Quartz...
We have a VIP 722 and the second channel is now without sound. We have sound on channel 1 but not 2. Any ideas?
Step 1: Check that TV or Stereo is not muted
Make sure that your TV or Stereo has not beed muted and that the volume is turned up loud enough to hear.
Step 2: Reset Receiver
If the issue is only on ONE receiver, unplug the DISH receiver for 10 seconds and plug back in.
Please note: It may take up to 5 minutes for the reset process to be completed.
Step 3: Check Receiver-to-TV Configuration
Check that the wiring between your DISH receiver and your TV is configured properly.
Step 4: Secure Receiver-to-TV Connections
Check that the connections between your DISH receiver, your TV, and any component(s) (VCR, DVD Player, etc.) in between are secure.
Mar 10, 2011 | DISH Network ViP722 DTV Receiver /...
Only getting sound through 1 channel, think i blew the left side. Technics stereo receiver is 15 years old. Is this reparable?
yes, it is repairable. Its just a matter of changing whatever that blew and it will work again.
I wish you good luck.
Mar 07, 2010 | Audio Players & Recorders
Can I connect my pioneer SX-255R stereo receiver
Yes, but it depends on your laptop hardware and software. We'd need to know a lot more about that side.
Jan 17, 2010 | Pioneer SX-255R Receiver
No surround Technics SA-AX530
There is likely separate gain controls for your surround channels on this receiver and they are probably set at -10dB. Enter the setup menu labled "level" and increase the amount for each channel equally.
Jun 18, 2009 | Technics SA-AX530 Receiver
23 people viewed this question
Top The Audio Players & Recorders Experts
Jose Ma DM.
Jose Ma DM.
Level 1 Expert
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
