Question about Numark Avm02 Audio/Video Mixer with Effects
The crossfader switch is not cutting in or fading out
Peavey special 112 solo amp cuts out.
Unfortunatly, there could be a few different causes for this and without the amp in frony of me it would be impossible to diagnose it. The best bet would be to have a qualified repairman look at it. Here is a link to the Peavey Contact page which has a link to their service centers.
Peavey com
Feb 26, 2015 | Peavey Music
HOw do you use the crossfader if all your music is coming through one port???
The crossfader is to gently fade from one source to another. If you only have one, the crosfader isn't useful... it would act like a plain fader with one side being dead and the other at full volume.
Aug 06, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
My vmx1000 mixer the crossfader only cuts out one side the other just contiues to play no matter what side u put it on
I suspect that one element of the crossfader pot (slider) is broken. Possible cause is if something fell on the knob or wear from use.
If one end breaks on one channel, the opposite end side will remain on full while the other channel will behave normally.
Replacement of the dual pot will LIKELY involve removing all panel knobs to remove the circuit board to replace the pot after disassembly of the unit. Not for the casual DIY person.
Nov 17, 2010 | Behringer Pro Mixer VMX1000USB...
Faded out the sound and will not turn power up
Make sure the STANDBY switch is not pressed. It will fade sound out on the first 8 channels and keep it off.
Sep 07, 2010 | Yamaha Emx312s Stereo Powered Mixer...
What lube can i use to clean numark nuvj crossfader. i'm gettin a leak while using the fader.
Usually a "leak" from one side to the other is an indication of a cracked resistance element. The fader would have to be replaced.
I lube the faders on my mixers using CRC226 availablle in the electrical dept at Home Depot. Use sparingly.
Aug 12, 2010 | Numark Nuvj DJ Video Mixer
I think my crossfader stop working for some reason. when im on side B i get sound then i slide over to side A and i still get sound from side be,,, all the assign are right also the bass mid and hi kill...
I suspect one end of the crossfader pot has broken from the element. The fader probably costs less than $5.
You likely will have to remove all the knobs and some screws to seperate the board with the fader from the front panel so you can replace the fader.
VERIFY the pot is bad with an ohmmeter before dis-assembling however.
You MAY be in luck. It looks like the cross fader has a connector which MIGHT allow you to remove it or certainly only a small board for replacement, seeing these take abuse.
It appears that the cross fader is a dual 100K type B taper.
Apr 26, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
About a month ago while on a gig, I noticed that the amp was cutting out when I played solos at a high volume. I play at barely half volume now, and if I go any louder, the same thing happens, it cuts...
Not likely preamp tubes. If they cut out they would fade slowly then come back slowly...
First check for marginal input jack. These take a beating and get loose and poor contacts. The vibration can cause the contact to be lost.
Also volume controls can get marginal...
Try to catch it in the act and tweek things to find someting that is affected.
Another common problem is contacts on jacks meant for effects inserting. These pass the signal through switch contacts when nothing plugged in and those contacts are "junky" to say the least.
Mar 08, 2010 | Fender Hot Rod Deluxe Guitar Combo...
How do i set the control for the crossfader on the djx700
u should b able to use it so long as you change the mode from stereo to split, then you can just use the panel at the bottom that says "crossfader:" :P
Feb 11, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Numark Avm02 Audio/Video Mixer with Effects Logo
75 people viewed this question
Top Numark Music Experts
Matthew Spark
Matthew Spark
Pieter Vleeshouwers
Pieter Vleeshouwers
J.D. Browning
J.D. Browning
Are you a Numark Music Expert? Answer questions, earn points and help others
