Question about Keurig Coffee Makers & Espresso Machines
My Keurig is leaking from the bottom, but only while brewing. The I rings are fine and I tried silicone grease, but it looks like the leak is coming from somewhere up inside towards the back. Ideas?
SOURCE: maytag neptune mah5500bww leaking water
Here is the solution I found that worked for me, there is a small drain hole at the bottom of the boot that is connected to a drain hose. Remove the hose and clean out to make sure that it has not become plagged. replace hose and reattach boot. Mine stoped leaking imediately.
Posted on Aug 20, 2008
  • 29 Answers
SOURCE: Starbucks Saeco Italia multiple leaks diagnosed ...
http://www.starbucks.com/customer/faq_qanda.asp?name=brewequip
maybe u can get some help here or at least download the manual which may hepl u find parts
Posted on Feb 27, 2009
SOURCE: Water leaking
The silicon seal inside the coffee maker tends to disintergrate. Bunn Inc. does not sell parts for the inside of the coffee makers, but a seal kit can be purchased through a small appliance repair center or repaired for a small cost. Kit is about $8.00 at most places.
Posted on Apr 13, 2009
  • 271 Answers
SOURCE: My 2002 Jetta GLS 2.0 is leaking coolant from near
Change the thermostat housing.
Posted on Jun 28, 2010
heatman101
  • 43501 Answers
SOURCE: My keurig leaks from the
Here is a tip that I wrote about Keurigcoffee brewers and the Keurigleaking problems
Keurig OneCup Coffee Brewer leaking
heatman101
Posted on Sep 04, 2011
The "O" ring seems to be leaking
Most softener heads are tightened to a minimum of 20 ft. lbs. to seal and not leak. If yours leaks after you tighten it (a quick sharp clock-wise twist will do fine) you should see your brand's local dealer and buy a new tank O ring. This must be lubricated with silicone grease. Petroleum based lubricants will degrade rubber. If you are looking for a new dealer or a more knowledgeable dealer visit wqa.org and find your local Certified Water Specialist.
Sep 03, 2014 | Water Dispensing & Filtration
Keurig coffee maker model b70
Not to be coy, but the best way to repair this problem is to take your Keurig back to Bed Bath & Beyond and exchange it for a brand new one!
As for your problem, your description was not detailed, but I would guess that the leak you are referring to is not coming out of the reservoir at all, but is actually coming from the bottom of your machine. The reason for this is that there is a solenoid located in the back of the unit that is notorious for leaking over time. The only way to repair it is to completely disassemble the unit and replace it. This solenoid is also responsible for your Keurig to "short-cup" you, meaning your Keurig brews, but you only get a partial cup of coffee. If your unit has not done this yet, it will start shortly.
So back to what I said at the beginning, your best option is to simply return it to BBB for a new one. You do not need a receipt, nor have had purchased it there in the first place. If you are interested in this option (& I highly recommend it), please send me an email at tom.morgan451@gmail.com. And I will send you al the information you need on how to return it for free. If you decide to send me an email to learn about this, please let me know in the email that you were from Fixya.com. If you want to know more about why the Keurig leaks and how to repair it, please search You Tube for my video series call Keurig Operation and Repair. It's long, tedious and extremely boring, but skip around and then send me an email. You will be happy you did. Good luck and IO hope this helps.
Jul 27, 2014 | Keurig Platinum B70 Coffee Maker
Keurig Leaks Water Before Brewing
If it is in warranty, this unit needs factory services. Unfortunately the cheap labor and rapid production rates are more important to the company than Quality.
Feb 16, 2014 | Keurig B60 Coffee Maker
Water leaks when in brewing mode
If you are having problems with leaks while brewing, do the following: Under the top lid there is a needle that punches the hole in the k-cup, this needle has an o-ring on it. Move the o-ring about 1/8 to 1/4 down towards the sharp point. This will allow the o-ring to seal against the k- cup.
Dec 25, 2011 | Keurig Elite B40 Coffee Maker
My keurig is leaking from bottom
My Keurig B60 had the same issue. The water reservoir has a valve in a nipple on the bottom that slides into a clear plastic fitting within the base of the unit. Water from the reservoir is supposed to pass through the fitting and into the pump, which is also in the base. Over time, hard water deposits can build up on the nipple or the mating fitting (or both) such that a good seal is not made when the reservoir is in place and water slowly leaks out the bottom. To fix this, I removed the five screws on the bottom of the Keurig and then removed the two screws which hold the fitting in place. I gently cleaned both the clear plastic fitting and the nipple in the bottom of the reservoir with white vinegar. After rinsing both with clean water and drying both, I applied a small amount of silicon faucet grease (available at any hardware store) to both parts. I haven't had any more leaks since, although I assume I will have to repeat this operation periodically.
Oct 02, 2011 | Keurig B60 Coffee Maker
I have a puddle of water that is leaving out of the coffee maker from the bottom. (underneath)
Here's what I discovered about my Keurig B60: The water reservoir has a valve in a nipple on the bottom that slides into a clear plastic fitting within the base of the unit. Water from the reservoir is supposed to pass through the fitting and into the pump, which is also in the base. Over time, hard water deposits can build up on the nipple or the mating fitting (or both) such that a good seal is not made when the reservoir is in place and water slowly leaks out the bottom. To fix this, I removed the five screws on the bottom of the Keurig and then removed the two screws which hold the fitting in place. I gently cleaned both the clear plastic fitting and the nipple in the bottom of the reservoir with white vinegar. After rinsing both with clean water and drying both, I applied a small amount of silicon faucet grease (available at any hardware store) to both parts. I haven't had any more leaks since, although I assume I will have to repeat this operation periodically.
Aug 28, 2011 | Keurig B60 Coffee Maker
My keurig leaks from the bottom only when brewing coffee. Can it be fixed?
heatman101
Jul 17, 2011 | Keurig B50 Coffee Maker
Moisture in headlight?
Take out the head light bulb partially and turn on the brights. the water will dry out in seconds. The seal for the head light is leaking so take the headlight assembly out and look for where is leaking use clear silicon for the housing and look at where the bulb fits into it and make sure its sealed up also. Use lithium or silicon grease. if it has a o ring seal
Jan 28, 2011 | 2002 Buick LeSabre
Leaking goosneck base. How Do I repair?
Amost guarantee it's a problem with the sealing O-Ring(s) that sits between the faucet body and the spout (or gooseneck). Fixing this requires disassembling the faucet. Allen keys, pliers, Screwdrivers required for this operation.
After you have the faucet apart, use open mesh grit cloth to sand the inside body of the spout, wipe it clean and grease it with silicone grease. New O-Rings may be indicated as well, but if the old ones looks ok (eg. the don't come off black on your fingers and they don't look compressed or kinked) grease them as well and reassemble faucet.
Sep 08, 2009 | American Standard Plumbing
Coffee Makers & Espresso Machines Logo
43 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
